All tools should be removed from the RTEMS source repository at some
point in time. Tools with a BSD-style license will be moved to the
RTEMS tools repository. Unfortunately, this tool has no license
information.
Remove all uses of this tool from the code base. Users of HEX files
should consider to use ELF instead.
Close #3379.
upgrade to that version.
Close #3387.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
for details.
tools/build/Makefile.am, tools/build/README, tools/build/binpatch.c,
tools/build/cklength.c, tools/build/config.h.in,
tools/build/configure.ac, tools/build/cvsignore-add.sh,
tools/build/doxy-filter, tools/build/eolstrip.c,
tools/build/install-if-change.in, tools/build/multigen,
tools/build/packhex.c, tools/build/rtems-bin2c.c,
tools/build/search-id.sh, tools/build/unhex.c, tools/cpu/.cvsignore,
tools/cpu/ChangeLog, tools/cpu/Makefile.am, tools/cpu/configure.ac,
tools/cpu/generic/.cvsignore, tools/cpu/generic/ChangeLog,
tools/cpu/generic/Makefile.am, tools/cpu/generic/configure.ac,
tools/cpu/generic/size_rtems.in, tools/cpu/nios2/.cvsignore,
tools/cpu/nios2/ChangeLog, tools/cpu/nios2/Makefile.am,
tools/cpu/nios2/README, tools/cpu/nios2/bridges.c,
tools/cpu/nios2/bridges.h, tools/cpu/nios2/clocks.c,
tools/cpu/nios2/clocks.h, tools/cpu/nios2/configure.ac,
tools/cpu/nios2/devices.c, tools/cpu/nios2/devices.h,
tools/cpu/nios2/linkcmds.c, tools/cpu/nios2/linkcmds.h,
tools/cpu/nios2/memory.c, tools/cpu/nios2/memory.h,
tools/cpu/nios2/nios2gen.c, tools/cpu/nios2/output.c,
tools/cpu/nios2/output.h, tools/cpu/nios2/ptf.c,
tools/cpu/nios2/ptf.h, tools/cpu/nios2/sample.ptf,
tools/cpu/sh/.cvsignore, tools/cpu/sh/AUTHORS, tools/cpu/sh/COPYING,
tools/cpu/sh/ChangeLog, tools/cpu/sh/Makefile.am, tools/cpu/sh/TODO,
tools/cpu/sh/configure.ac, tools/cpu/sh/sci.c, tools/cpu/sh/sci.h,
tools/cpu/sh/shgen.c: New files.
* tools/build/.cvsignore, tools/build/ChangeLog,
tools/build/cklength.c, tools/build/configure.ac,
tools/build/cvsignore-add.sh, tools/build/doxy-filter,
tools/build/eolstrip.c, tools/build/install-if-change.in,
tools/build/multigen, tools/build/packhex.c,
tools/build/rtems-bin2c.c, tools/build/search-id.sh,
tools/build/unhex.c, tools/cpu/.cvsignore, tools/cpu/ChangeLog,
tools/cpu/sh/shgen.c, tools/schedsim/.cvsignore,
tools/schedsim/ChangeLog, tools/schedsim/Makefile.am,
tools/schedsim/README, tools/schedsim/configure.ac,
tools/schedsim/rtems/.cvsignore, tools/schedsim/rtems/ChangeLog,
tools/schedsim/rtems/Makefile.am, tools/schedsim/rtems/interr.c,
tools/schedsim/rtems/rtems_init.c,
tools/schedsim/rtems/rtems_sched.h, tools/schedsim/rtems/wkspace.c,
tools/schedsim/rtems/sched_cpu/cpu.c,
tools/schedsim/rtems/sched_cpu/cpu_asm.c,
tools/schedsim/rtems/sched_cpu/rtems/asm.h,
tools/schedsim/rtems/sched_cpu/rtems/stringto.h,
tools/schedsim/rtems/sched_cpu/rtems/score/cpu.h,
tools/schedsim/rtems/sched_cpu/rtems/score/cpu_asm.h,
tools/schedsim/rtems/sched_cpu/rtems/score/cpuopts.h,
tools/schedsim/rtems/sched_cpu/rtems/score/no_cpu.h,
tools/schedsim/rtems/sched_cpu/rtems/score/types.h,
tools/schedsim/shell/.cvsignore, tools/schedsim/shell/ChangeLog,
tools/schedsim/shell/Makefile.am,
tools/schedsim/shell/schedsim_priority/.cvsignore,
tools/schedsim/shell/schedsim_priority/Makefile.am,
tools/schedsim/shell/schedsim_priority/config.c,
tools/schedsim/shell/schedsim_priority/printheir_executing.c,
tools/schedsim/shell/schedsim_priority/schedsim.cc,
tools/schedsim/shell/schedsim_priority/wrap_thread_dispatch.c,
tools/schedsim/shell/scripts/script01,
tools/schedsim/shell/scripts/script02,
tools/schedsim/shell/scripts/script03,
tools/schedsim/shell/scripts/script04,
tools/schedsim/shell/scripts/script05,
tools/schedsim/shell/scripts/script06,
tools/schedsim/shell/shared/.cvsignore,
tools/schedsim/shell/shared/Makefile.am,
tools/schedsim/shell/shared/commands.c,
tools/schedsim/shell/shared/getopt.c,
tools/schedsim/shell/shared/lookup_semaphore.c,
tools/schedsim/shell/shared/lookup_task.c,
tools/schedsim/shell/shared/main_clocktick.c,
tools/schedsim/shell/shared/main_echo.c,
tools/schedsim/shell/shared/main_executing.c,
tools/schedsim/shell/shared/main_heir.c,
tools/schedsim/shell/shared/main_help.c,
tools/schedsim/shell/shared/main_rtemsinit.c,
tools/schedsim/shell/shared/main_semcreate.c,
tools/schedsim/shell/shared/main_semdelete.c,
tools/schedsim/shell/shared/main_semflush.c,
tools/schedsim/shell/shared/main_semobtain.c,
tools/schedsim/shell/shared/main_semrelease.c,
tools/schedsim/shell/shared/main_taskcreate.c,
tools/schedsim/shell/shared/main_taskdelete.c,
tools/schedsim/shell/shared/main_taskmode.c,
tools/schedsim/shell/shared/main_taskpriority.c,
tools/schedsim/shell/shared/main_taskresume.c,
tools/schedsim/shell/shared/main_tasksuspend.c,
tools/schedsim/shell/shared/main_taskwakeafter.c,
tools/schedsim/shell/shared/schedsim_shell.h,
tools/schedsim/shell/shared/shell_cmdset.c,
tools/schedsim/shell/shared/shell_makeargs.c,
tools/schedsim/shell/shared/include/shell.h,
tools/schedsim/shell/shared/include/newlib/_ansi.h,
tools/schedsim/shell/shared/include/newlib/getopt.h: Removed.
* configure.ac: RTEMS Scheduler Simulator is now in its own CVS module
named rtems-schedsim.
* configure.ac: Check for libgen.h, basename.
* rtems-bin2c.c: Use basename(3) instead of strrchr cascade.
Introduce ifbasename. Use ifbasename in generated files.
* ampolish3.in: Remove.
* Makefile.am: Remove ampolish3.
* configure.ac: Remove ampolish3, perl.
* configure.ac: Add ampolish3.
* Makefile.am: Add ampolish3.
* ampolish3.in: New.
* lock-directory.in, unlock-directory.in: Removed.
* Makefile.am, README, .cvsignore: Updated to reflect above.
* configure.ac: Remove AC_EXEEXT (obsolete).
* configure.in: Remove.
