path: root/tools/build/cklength.c (follow)
* Switched from "extern int errno" to "#include <errno.h>".Joel Sherrill1998-03-031-1/+1
* Added autoconf support for strerror/sys_errlist per Ralf Corsepius'Joel Sherrill1998-01-211-8/+19
| | | | | direction. This fixes a problem reported by Steve Evans of Radstone since he is using glibc2.
* Corrected prototypes for main per Ralf Corsepius' report of warningsJoel Sherrill1998-01-211-2/+4
| | | | generated when egcs is used with "-Wall -pedantic".
* updates from Tony Bennett for PA and UNIX portsJoel Sherrill1996-01-151-15/+2
* changes remerged after disk crash -- history lostJoel Sherrill1995-12-191-0/+3
* SPARC merged and successfully tested w/o interrupt supportJoel Sherrill1995-10-061-0/+4
* moved to new development machine and went to gcc 2.7.0Joel Sherrill1995-10-061-0/+3
* fixing revisionJoel Sherrill1995-05-311-0/+3
* Initial revisionJoel Sherrill1995-05-111-0/+364
