path: root/tools/build/binpatch.c (unfollow)
1998-06-27PC386 BSP enhancements from Aleksey Romanov (Quality QuorumJoel Sherrill1-0/+168
<qqi@world.std.com>). Unfortunately after merging these, the pc386 will not boot using grub for for. It still does not work using netboot for me. Here is his summary of changes: rtems/c/src/lib/libbsp/i386/pc386/Makefile.in Added support for new sub-directory rtems/c/src/lib/libbsp/i386/pc386/bsp_specs Made possible to build COFF image rtems/c/src/lib/libbsp/i386/pc386/console/console.c Added support for serial consoles, selectable by patching binary image, added __assert(), use _IBMPC_inch_sleep() instaed of _IMBPC_inch() rtems/c/src/lib/libbsp/i386/pc386/console/inch.c Added _IMBPC_inch_sleep() rtems/c/src/lib/libbsp/i386/pc386/console/outch.c Oops - just formatting rtems/c/src/lib/libbsp/i386/pc386/include/Makefile.in Added support for new files rtems/c/src/lib/libbsp/i386/pc386/include/bsp.h Added support for new features rtems/c/src/lib/libbsp/i386/pc386/include/pc386uart.h New file: definitions for serial ports rtems/c/src/lib/libbsp/i386/pc386/include/pcibios.h New file: definitions for PCI BIOS rtems/c/src/lib/libbsp/i386/pc386/pc386dev/Makefile.in New file: makefile in new directory rtems/c/src/lib/libbsp/i386/pc386/pc386dev/i386-stub-glue.c New file: i386-stub interface rtems/c/src/lib/libbsp/i386/pc386/pc386dev/i386-stub.c New file: i386-stub itself rtems/c/src/lib/libbsp/i386/pc386/pc386dev/pc386uart.c New file: serial ports rtems/c/src/lib/libbsp/i386/pc386/pc386dev/pcibios.c New file: PCI BIOS support rtems/c/src/lib/libbsp/i386/pc386/start/start.s Commented out DEBUG_EARLY stuff, everything is working fine rtems/c/src/lib/libbsp/i386/pc386/start/start16.s Cleaned up rtems/c/src/lib/libbsp/i386/pc386/startup/bspstart.c Added call to console_resereve_resources rtems/c/src/lib/libbsp/i386/pc386/startup/exit.c Added support for serial console rtems/c/src/lib/libbsp/i386/pc386/startup/ldsegs.s Fixed typo in comments rtems/c/src/lib/libbsp/i386/pc386/tools/Makefile.in Changed to reflect cnages in code rtems/c/src/lib/libbsp/i386/pc386/tools/bin2boot.c Trivialized, problem - I do not know how to make patch remove obsolete files - there are a lot of them there rtems/c/src/lib/libbsp/i386/pc386/tools/binpatch.c New file: utility to do binary patches rtems/c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in Added support for new directory rtems/make/custom/pc386.cfg Add COFF image building
