path: root/tools/build/ChangeLog (follow)
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-111-0/+4
| | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-111-0/+13
* 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-111-0/+4
| | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]).
| | | | * configure.ac: AC_PREREQ(2.57).
* 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-211-0/+6
| | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache.
* 2002-10-02 Chris Johns <cjohns@cybertec.com.au>Joel Sherrill2002-10-041-0/+5
| | | | | * cvsignore-add.sh: Script to append a specific file to all .cvsignore files if the files exists is a specific directory.
* 2002-05-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-05-011-0/+5
| | | | | * lock-directory.in, unlock-directory.in: Removed. * Makefile.am, README, .cvsignore: Updated to reflect above.
* 2002-04-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-031-0/+4
| | | | * configure.ac: Remove AC_EXEEXT (obsolete).
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-281-0/+7
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-111-0/+6
* 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-241-0/+4
| | | | * config.h.in: Automatically generated. Remove from CVS.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-091-0/+4
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-021-0/+4
* 2000-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-311-0/+4
| | | | * Makefile.am: Switch to GNU-canonicalized autoconf macros.
* 2000-08-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-121-0/+4
| | | | * multigen: Fix BARE_CPU_CFLAGS.
* 2000-09-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-061-0/+4
| | | | * multigen: Fix usage.
