* Makefile.am, configure.ac: Add psxaio01/, psxaio02/.
* psxaio01/Makefile.am, psxaio01/init.c, psxaio01/psxaio01.scn,
psxaio01/system.h: New.
* psxaio02/Makefile.am, psxaio02/init.c, psxaio02/psxaio02.scn,
psxaio02/system.h: New.
PR 1658/cpukit
* Makefile.am, configure.ac: If the system is not up, consider it a
fatal error. This eliminated sp61 and added spfatal23.
* spfatal23/.cvsignore, spfatal23/Makefile.am, spfatal23/spfatal23.doc,
spfatal23/spfatal23.scn, spfatal23/testcase.h: New files.
* sp61/.cvsignore, sp61/Makefile.am, sp61/init.c, sp61/sp61.doc,
sp61/sp61.scn: Removed.
PR 1661/testing
* termios01/init.c, termios01/termios01.scn: Added a test case to
hit a case in rtems_termios_read.
PR 1663/testing
* spmkdir/init.c: New cases to get the error path in rtems_mkdir
routine.
PR 1598/testing
* psxpasswd02/init.c, psxpasswd02/psxpasswd02.scn: New test case
added to improve coverage of getpwent.c.
PR 1664/testing
* termios01/init.c: Use INT_MAX instead of hard-coded number for error
case to avoid warning on 16-bit targets.
PR 1665/testing
* psximfs02/init.c: Fix uninitialized variable warning.
PR 1661/testing
* malloc04/init.c: Add public methods to get/set malloc heap pointer so
the tests do not have to peer behind the API.
PR 1661/testing
* psximfs02/init.c: Changes to improve coverage of
imfs_initsupp.c, by using a bad value for
CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK
PR 1661/testing
* termios01/init.c, termios01/termios_testdriver.c,
termios01/termios01.scn: Changes to improve coverage of
rtems_termios_open routine.
PR 1661/testing
* spfifo02/init.c, spmountmgr01/init.c, spprivenv01/init.c: Eliminate
most references to RTEMS_Malloc_Heap.
PR 1661/testing
* psxchroot01/test.c, psximfs01/init.c, psximfs02/init.c,
psxpipe01/init.c: Eliminate most references to RTEMS_Malloc_Heap.
* sp09/screen12.c: Update for rtems_region_create() changes.
* sp09/sp09.scn: Update.
* psxpasswd02/init.c: Remove unused variable.
PR 1647/testing
* spsize/size.c: Remove redundant initialize uninitialized to 0.
PR 1654/testing
* deviceio01/init.c, deviceio01/deviceio01.doc,
deviceio01/deviceio01.scn, deviceio01/test_driver.c,
deviceio01/test_driver.h, deviceio01/Makefile.am: New test added.
* Makefile.am, configure.ac: Changes to added above test.
* tar02/init.c, tar02/tar02.scn: New test case added: IMFS_dump().
PR 1654/testing
* psx13/test.c, psx13/psx13.scn: Test case to improve testing of
dup2 routine.
* psxfile01/test.c, psxfile01/psxfile01.scn: New test to improve
testing of fcntl routine.
* psximfs01/init.c, psximfs01/psximfs01.scn: Improve testing of
imfs routines.
* psximfs02/init.c, psximfs02/psximfs02.scn: Improve coverage of
imfs routines.
* psxpasswd02/init.c, psxpasswd02/psxpasswd02.scn: New tests to
PR 1652/GCC:
* psxpipe01/init.c: Expand incomplete initializers triggering
powerpc-gcc -msdata breakdown.
PR 1652/GCC:
PR 1642/testing
* psximfs02/init.c, psximfs02/psximfs02.scn,
psximfs02/psximfs02.doc: Added test cases to exercise chmod(),
chown() and routines in imfs_debug.c.
* Makefile.am, configure.ac: Add test for rtems_print_buffer().
* dumpbuf01/.cvsignore, dumpbuf01/Makefile.am, dumpbuf01/dumpbuf01.doc,
dumpbuf01/dumpbuf01.scn, dumpbuf01/init.c: New files.
* bspcmdline01/bspcmdline01.scn, bspcmdline01/init.c: Add test cases to
improve coverage.
* automake/compile.am: Remove clean-local:.
Use CLEANFILES for cleaning up make-exe by-products.
* tar01/Makefile.am, tar02/Makefile.am: Apply clean-local to remove
intital_fs directory.
PR 1599/cpukit
* tm26/task1.c, tm27/task1.c: Rename _Context_Switch_necessary to
_Thread_Dispatch_necessary to more properly reflect the intent.
PR 1599/cpukit
* spsize/size.c: Rename _Context_Switch_necessary to
* tar01/Makefile.am, tar02/Makefile.am: Apply TARTESTS.
* tar01/Makefile.am:
Apply $LN_S, $PAX. Use subshell for tarball creation.
Don't add initial_fs to CLEANFILES.
* tar02/Makefile.am:
* configure.ac: Add AC_PROG_LN_S.
Add AC_PATH_PROG([PAX]).
Add AM_CONDITIONAL(TARTESTS).
Eliminate stamp-filesystem.
Add BUILT_SOURCES.
* configure.ac: autoconf >= 2.65, automake >= 1.11.
PR 1642/testing
psximfs02/psximfs02.doc, psximfs02/Makefile.am: New test added.
* configure.ac, Makefile.am: Changes to accommodate psximfs02
test.
PR 1633/testing
* psximfs01/init.c, psximfs01/psximfs01.scn,
psximfs01/psximfs01.doc: New cases to exercise
IMFS_memfile_remove.
PR 1621/testing
* Makefile.am, configure.ac: Improve coverage of private environment.
* spprivenv01/.cvsignore, spprivenv01/Makefile.am, spprivenv01/init.c,
spprivenv01/spprivenv01.doc, spprivenv01/spprivenv01.scn: New files.
* tar01/Makefile.am, tar02/Makefile.am: Fix dependencies for parallel
build.
* tar01/Makefile.am, tar02/Makefile.am: Replace mkdir cascade
with $(MKDIR_P).
* tar01/Makefile.am, tar02/Makefile.am: Misc. fixes.
* tar01/Makefile.am, tar03/Makefile.am: Remove MANAGERS.
* sp43/init.c, sp43/sp43.scn: Add code to exercise case where an API
pointer is NULL when getting an object name.
* psxobj01/Makefile.am, psxobj01/init.c, psxobj01/psxobj01.scn: Add
test for runnign out of workspace when setting object name as string.
* sp11/sp11.scn, sp11/task1.c: Add test case for receiving all events
no wait but the condition is only partially satisfied.
PR 1532/testing
* aclocal/project-root.m4: Add initial tests for untar capabilities.
PR 1532/testing
* Makefile.am, configure.ac: Add initial tests for untar capabilities.
* tar01/.cvsignore, tar01/Makefile.am, tar01/init.c, tar01/tar01.doc,
tar01/tar01.scn, tar02/.cvsignore, tar02/Makefile.am, tar02/init.c,
tar02/tar02.doc, tar02/tar02.scn: New files.
PR 1629/cpukit
* psx04/init.c: sigsuspend() was not completely following the POSIX
specification.
PR 1631/testing
* gxx02/init.c, gxx02/gxx02.scn, gxx02/gxx02.doc,
gxx02/Makefile.am, gxx02/gxx_wrappers.h: New test added
* Makefile.am, configure.ac: Changes to accommodate new tests
PR 1632/testing
* Makefile.am, configure.ac: Make dedicated fatal error test for
/dev/null already registered. Using code from Bharath in new test
framework.
* devnullfatal01/.cvsignore, devnullfatal01/Makefile.am,
devnullfatal01/devnullfatal01.doc, devnullfatal01/devnullfatal01.scn,
devnullfatal01/testcase.h: New files.
