Rely on test extension to report profiling.
output.
Do not use sprintf() in thread dispatch critical sections to avoid
corruption of profiling samples. Update test to reflect thread the life
cycle changes.
Invalidation of entire data cache might cause data written to the stack
to get lost.
Increment by cache line size to allow more cycles per second.
Use interrupt critical section test support. Do not print end of test
message in case of failure.
This avoids test durations of more than one hour on fast targets, since
fast targets can count a lot during one clock tick period, so the minor
loop iteration count was quite high. Estimate now the test body
duration to iterate only through the interesting time window.
Add and use interrupt_critical_section_test().
This is necessary to use the <atomic> header file used for the atomic
operations.
expectations
This prevents infinite test runs on SMP due to the recursive interrupt
lock acquire.
Add rtems_clock_tick_later(), rtems_clock_tick_later_usec() and
rtems_clock_tick_before().
l.nop instruction.
Invokes SMP cache management routines under different scenarios.
Simplify _RBTree_Insert() and _RBTree_Extract(). Remove more
superfluous NULL pointer checks. Change _RBTree_Is_root() to use only
the node. Add parent parameter to _RBTree_Sibling(). Delete
_RBTree_Grandparent() and _RBTree_Parent_sibling().
Add and use _RBTree_Direction().
Simplify _RBTree_Find_control(). Avoid superfluous NULL pointer checks.
Only use the parent pointer, since this pointer is never NULL for nodes
which are part of a tree.
Rename functions from *_off_rbtree() to *_off_tree().
The test sptests/sp35 showed a NULL pointer access due to an invalid
maximum node field (e.g. a tree with one element and NULL as the maximum
node).
This lays the proper structure for doing future work on
time adjustment algorithms. Any TOD adjustments should be
requested at the API level and performed at the SCORE level.
Additionally updated a test.
Remove compare function and is unique indicator from the control
structure. Rename RBTree_Compare_function to RBTree_Compare. Rename
rtems_rbtree_compare_function to rtems_rbtree_compare. Provide C++
compatible initializers. Add compare function and is unique indicator
to _RBTree_Find(), _RBTree_Insert(), rtems_rbtree_find() and
rtems_rbtree_insert(). Remove _RBTree_Is_unique() and
rtems_rbtree_is_unique(). Remove compare function and is unique
indicator from _RBTree_Initialize_empty() and
rtems_rbtree_initialize_empty().
tm02 and tm03 were modified to be reused for multiple configurations
of RTEMS Classic API Semaphores. This added tm31-36. The messages for
tm02 and tm03 were modified to indicate the semaphore attributes.
tm31 - tm36 were added. This resulted in the following cases:
tm02 - rtems_semaphore_obtain: Counting/FIFO not available caller blocks
tm03 - rtems_semaphore_release: Counting/FIFO task readied preempts caller
tm31 - rtems_semaphore_obtain: Counting/priority not available caller blocks
tm32 - rtems_semaphore_release: Counting/priority task readied preempts caller
tm33 - rtems_semaphore_obtain: Binary/FIFO not available caller blocks
tm34 - rtems_semaphore_release: Binary/FIFO task readied preempts caller
tm35 - rtems_semaphore_obtain: Binary/priority not available caller blocks
tm36 - rtems_semaphore_release: Binary/priority task readied preempts caller
This test verifies priority is inherited from a high priority
semaphore by a lower priority task.
