1998-12-03 | Updated scn files to match present expected test output. | Jennifer Averett | 4 | -11/+267 | |
1998-12-03 | Insure that the same output occurs when multiprocessing is disabled. | Joel Sherrill | 5 | -1/+41 | |
1998-12-03 | Moved cpuuse.h to rtems subdirectory. | Joel Sherrill | 1 | -1/+1 | |
1998-12-01 | Include files now installed as <rtems/*.h>. | Joel Sherrill | 2 | -3/+3 | |
1998-11-23 | Added base version of file system infrastructure. This includes a major | Joel Sherrill | 1 | -5/+17 | |
overhaul of the RTEMS system call interface. This base file system is the "In-Memory File System" aka IMFS. The design and implementation was done by the following people: + Joel Sherrill (joel@OARcorp.com) + Jennifer Averett (jennifer@OARcorp.com) + Steve "Mr Mount" Salitasc (salitasc@OARcorp.com) + Kerwin Wade (wade@OARcorp.com) PROBLEMS ======== + It is VERY likely that merging this will break the UNIX port. This can/will be fixed. + There is likely some reentrancy/mutual exclusion needed. + Eventually, there should be a "mini-IMFS" description table to eliminate links, symlinks, etc to save memory. All you need to have "classic RTEMS" functionality is technically directories and device IO. All the rest could be left out to save memory. | |||||
1998-11-23 | Added new tests in support of the file system infrastructure. | Joel Sherrill | 3 | -0/+155 | |
1998-11-23 | Added tests in support of the file system infrastructure. | Joel Sherrill | 15 | -0/+4577 | |
1998-11-23 | Added --disable-multiprocessing flag and modified a lot of files to make | Joel Sherrill | 1 | -3/+35 | |
it work. | |||||
1998-10-05 | New file based on information from Eric Norum <eric@skatter.usask.ca>. | Joel Sherrill | 1 | -0/+42 | |
1998-10-05 | Fixed use of incorrect macro for minimum stack size. | Joel Sherrill | 1 | -1/+1 | |
1998-09-23 | IDLE task stack size now specified as a field in the CPU Table for all | Joel Sherrill | 1 | -1/+1 | |
ports. | |||||
1998-08-03 | Under allcoated task stacks. | Joel Sherrill | 1 | -1/+1 | |
1998-07-17 | Turned stack checker on. | Joel Sherrill | 1 | -0/+2 | |
1998-06-12 | Patch from Eric Norum to avoid printing from context switch user extension. | Joel Sherrill | 3 | -7/+37 | |
The array is too long and needs to be shortened. | |||||
1998-06-09 | Fixed comment block at the beginning of the file for a copyright date | Joel Sherrill | 135 | -271/+270 | |
problem and an English problem. | |||||
1998-05-04 | Fixed prototype of Fatal_Extension. | Joel Sherrill | 2 | -18/+15 | |
Fixed interface to cofndefs.h for initial extension set. | |||||
1998-04-27 | Added CONFIGURE_EXTRA_TASK_STACKS definition to make memory requirements | Joel Sherrill | 24 | -3/+49 | |
more accurate. | |||||
1998-04-27 | Fixed screen to match actual output. | Joel Sherrill | 1 | -3/+2 | |
1998-04-27 | Reset the pthread attributes structure so the proper error would be | Joel Sherrill | 1 | -1/+5 | |
generated. | |||||
1998-04-15 | Initial sets of user extensions now have memory allocated on the fly | Joel Sherrill | 1 | -2/+1 | |
for them. | |||||
1998-04-06 | Increased stack size so test would run in debug mode. | Joel Sherrill | 5 | -5/+6 | |
1998-03-24 | Rename hppa1_1 to hppa1.1 and switched to using __XXX__ macros for | Joel Sherrill | 2 | -9/+7 | |
the CPU family name constants. | |||||
1998-03-21 | Corrected typo in copyright notice. | Joel Sherrill | 1 | -1/+1 | |
1998-03-03 | Corrected to indicate test cases which were skipped. | Joel Sherrill | 1 | -2/+2 | |
1998-02-20 | Modified to reflect new restrictions on mutex being released. | Joel Sherrill | 1 | -1/+1 | |
1998-02-20 | Removed extra line. | Joel Sherrill | 1 | -1/+0 | |
1998-02-20 | Increased stack space to let test run to completion. | Joel Sherrill | 1 | -4/+4 | |
1998-02-19 | Increased stack space of tasks. | Joel Sherrill | 1 | -1/+1 | |
1998-02-19 | Increased stack size of initialization task. | Joel Sherrill | 1 | -0/+1 | |
1998-02-19 | Restructured so all times are placed in variables and printed in batch | Joel Sherrill | 1 | -163/+193 | |
mode at the end of the test. This eliminates the possibility of IO blocking a task unexpectedly and messing up the test. | |||||
1998-02-17 | updated copyright to 1998 | Joel Sherrill | 569 | -569/+569 | |
1998-02-17 | updated copyright to 1998 | Joel Sherrill | 1 | -1/+1 | |
1998-01-23 | Solaris port updates from Chris Johns | Joel Sherrill | 2 | -0/+5 | |
1998-01-16 | Ralf Corsepius reported a number of missing CVS Id's: | Joel Sherrill | 11 | -10/+12 | |
> RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose. | |||||
1997-11-18 | Removed warning. | Joel Sherrill | 1 | -1/+1 | |
1997-11-18 | New file. | Joel Sherrill | 1 | -0/+45 | |
1997-10-23 | Added new test for termios style consoles from Eric Norum. | Joel Sherrill | 1 | -0/+141 | |
1997-10-21 | Added test case for rtems_interrupt_catch checking that the pointer | Joel Sherrill | 2 | -1/+11 | |
for the returned old_isr_handler was non-NULL. | |||||
1997-10-09 | Fixed some spacing. | Joel Sherrill | 2 | -4/+4 | |
1997-10-08 | Fix from Eric Norum so FPSP is installed before any FP code is actually | Joel Sherrill | 1 | -0/+9 | |
exercise. | |||||
1997-10-08 | Fixed typo in the pointer to the license terms. | Joel Sherrill | 571 | -1142/+1142 | |
1997-10-06 | Fixed some weird line duplications. Thanks to Chris Johns. | Joel Sherrill | 1 | -18/+9 | |
1997-09-21 | Added Monitor test. | Joel Sherrill | 2 | -0/+131 | |
1997-08-26 | Patches from Chris Johns to clean up test. | Joel Sherrill | 5 | -19/+52 | |
1997-07-31 | Merged very large and much appreciated patch from Chris Johns | Joel Sherrill | 7 | -0/+1208 | |
<cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test. | |||||
1997-07-31 | Merged very large and much appreciated patch from Chris Johns | Joel Sherrill | 1 | -0/+6 | |
1997-07-31 | Added support for rtems_message_queue_get_number_pending. | Joel Sherrill | 4 | -0/+21 | |
1997-07-09 | Used macro instead of hard coded number. | Joel Sherrill | 1 | -1/+1 | |
1997-04-22 | updated with new license information per Tony Bennett. | Joel Sherrill | 1 | -13/+5 | |
1997-04-22 | headers updated to reflect new style copyright notice as part | Joel Sherrill | 563 | -2815/+2815 | |
of switching to the modified GNU GPL. |
