BSP needs to be eliminated.
Disabled test of F_DUPFD since it does not work.
Added comment to indicate that seekdir(NULL) was being called.
was unnecessary. The real fix was an alignment error in the
object extend memory allocation scheme.
of space in the workspace.
removed.
the executive.
Charles-Antione Gauthier <charles.gauthier@iit.nrc.ca>.
and RTEMS configuration.
<rdasilva@connecttel.com>.
on BSPs that install there own tools.
tested that the same file could not be created twice.
description follows:
Description:
config.h.ins)
acpolish
configure scripts
Remarks:
[$(prefix)].
are:
I have a few patches for the efi332 bsp. If you let me know when you
expect the next snapshot release, I will try to have them to you
before then. Also, the malloctest has some problems that I would think
would prevent it from running on almost any platform. I have enclose
patches below to fix (1) Task_id and Task_name dimensioning, (2) end
of test message, (3) the amount of memory malloc'ed, and (4) retry on
unsuccessful (out of memory) molloc's.
that are part of the addition of POSIX timers.
blocking protocol is used.
Updated scn files to match present expected test output.
