path: root/testsuites (follow)
* score: New thread queue implementationSebastian Huber2015-05-195-67/+54
| | | | | | | | | Use thread wait flags for synchronization. The enqueue operation is now part of the initial critical section. This is the key change and enables fine grained locking on SMP for objects using a thread queue like semaphores and message queues. Update #2273.
* score: Add Thread_queue_OperationsSebastian Huber2015-05-191-2/+2
| | | | | | | | Replace the Thread_Priority_control with more general Thread_queue_Operations which will be used for generic priority change, timeout, signal and wait queue operations in the future. Update #2273.
* score: Generalize _Event_Timeout()Sebastian Huber2015-05-191-3/+3
| | | | | | | Add a thread wait timeout code. Replace _Event_Timeout() with a general purpose _Thread_Timeout() watchdog handler. Update #2273.
* score: Reduce thread wait statesSebastian Huber2015-05-191-3/+3
| | | | | | | | | | Merge THREAD_WAIT_STATE_SATISFIED, THREAD_WAIT_STATE_TIMEOUT, THREAD_WAIT_STATE_INTERRUPT_SATISFIED, and THREAD_WAIT_STATE_INTERRUPT_TIMEOUT into one state THREAD_WAIT_STATE_READY_AGAIN. This helps to write generic routines to block a thread. Update #2273.
* score: New timer server implementationSebastian Huber2015-05-192-110/+59
| | | | | | | | Use mostly the standard watchdog operations. Use a system event for synchronization. This implementation is simpler and offers better SMP performance. Close #2131.
* score: Add Watchdog_IteratorSebastian Huber2015-05-192-3/+115
| | | | | | | | | | Rewrite the _Watchdog_Insert(), _Watchdog_Remove() and _Watchdog_Tickle() functions to use iterator items to synchronize concurrent operations. This makes it possible to get rid of the global variables _Watchdog_Sync_level and _Watchdog_Sync_count which are a blocking point for scalable SMP solutions. Update #2307.
* score: Add header to _Watchdog_Remove()Sebastian Huber2015-05-192-2/+2
| | | | | | | | Add watchdog header parameter to _Watchdog_Remove() to be in line with the other operations. Add _Watchdog_Remove_ticks() and _Watchdog_Remove_seconds() for convenience. Update #2307.
* score: _Thread_queue_Extract()Sebastian Huber2015-05-191-25/+4
| | | | | Remove thread queue parameter from _Thread_queue_Extract() since the current thread queue is stored in the thread control block.
* smptests/smpcache01: RestructureSebastian Huber2015-05-152-109/+105
| | | | Restructure to avoid large maximum thread dispatch disabled times.
* score: Fix scheduler helping protocolSebastian Huber2015-05-112-250/+478
| | | | | | Account for priority changes of threads executing in a foreign partition. Exchange idle threads in case a victim node uses an idle thread and the new scheduled node needs an idle thread.
* sptests/spcontext01: Check FPU task combinationsAlexander Krutwig2015-05-072-12/+43
* sptests/spstkalloc02: Fix namespace issueSebastian Huber2015-04-271-3/+3
| | | | Avoid collision with <sys/param.h> defined PAGE_SIZE.
* sp13/system.h: Account for all message buffersJoel Sherrill2015-04-231-2/+2
| | | | | | | There may be a way to reduce the memory requirements but it will require time to ensure the math is right and it passes on all targets. At the current time, it fails on 22 BSPs which run on simulators.
* score: Delete Thread_queue_Control::stateSebastian Huber2015-04-231-1/+1
| | | | | Use a parameter for _Thread_queue_Enqueue() instead to reduce memory usage.
* smptests/smpcache01: Enable interrupts before waiting for other CPUsDaniel Cederman2015-04-221-2/+2
| | | | | Otherwise there is a risk that a CPU misses a cache manager message from another CPU and the test hangs.
* score: Add _Thread_Get_interrupt_disable()Sebastian Huber2015-04-211-6/+6
| | | | | | | | | | Remove _Thread_Acquire() and _Thread_Acquire_for_executing(). Add utility functions for the default thread lock. Use the default thread lock for the RTEMS events. There is no need to disable thread dispatching and a Giant acquire in _Event_Timeout() since this was already done by the caller. Update #2273.
* score: Add _ISR_lock_ISR_disable/enable()Sebastian Huber2015-04-201-0/+6
* score: Refactor SMP cache manager supportSebastian Huber2015-04-201-17/+6
* sp13: Document message buffer usage and adjust configurationJoel Sherrill2015-04-171-5/+26
* sptests/sp52: Reduce clock tick intervalSebastian Huber2015-04-171-0/+2
| | | | This helps on slow simulators.
* score: Fix _TOD_Set_with_timestamp()Sebastian Huber2015-04-171-15/+20
| | | | | Update the current time before the watchdog adjust so that timer routines observe the new time.
* sptests/sp68: Avoid use of internal variablesSebastian Huber2015-04-161-10/+12
* score: Add _ISR_lock_Flash()Sebastian Huber2015-04-161-0/+2
* spcpuset01: Reduce output to reduce run-timeJoel Sherrill2015-04-144-4045/+12
* sp13: Update configuration to account for messages on fourth message queueJoel Sherrill2015-04-142-1/+6
* Add test assertion for allocator mutex being unlockedJoel Sherrill2015-04-143-20/+54
| | | | | | | | | | The Allocator Mutex should not be locked outside a tested service call. In an SMP test or heavily multithreaded test, this is possible since another thread could have the lock for an extended period of time but this is not the norm for the tests. updates 2319.
* score: Add Watchdog_HeaderSebastian Huber2015-04-133-8/+8
| | | | | | | This type is intended to encapsulate all state to manage a watchdog chain. Update #2307.
* rtems: Atomically suspend/resume tasksSebastian Huber2015-04-081-1/+1
* fstests/fsfseeko01: Fix for long == off_tSebastian Huber2015-04-081-4/+11
| | | | Close #2317.
* disable-intrcritical-tests.tcfg: New fileJoel Sherrill2015-04-011-0/+30
| | | | | | This file contains the list of interrupt critical section tests. There are some simulators these are unreliable on so they should just be ignored.
* psxtmtests: Use timeout in more distant futureAlexander Krutwig2015-03-311-2/+3
| | | | Adds future compatibility with strict monontonic software timestamps.
* fstests: Increase stack size for symlink loop testAlexander Krutwig2015-03-311-1/+1
* fstests/fssymlink: TypoAlexander Krutwig2015-03-311-1/+1
* testsuites: dl02 needs an FPU init task.Chris Johns2015-03-311-1/+1
* smpmigration01: Delete timing dependent assertSebastian Huber2015-03-251-3/+6
| | | | | | The cycles per runner depends too heavily on the hardware timing making the assert unreliable. Delete runner tasks before we print out the status.
* smptests/smpfatal08: Workaround for QorIQ BSPsSebastian Huber2015-03-241-0/+8
* score: Add thread priority change handlerSebastian Huber2015-03-241-2/+2
| | | | | | | | | | Since the thread current priority change and thread queue requeue is performed in one critical section it is possible to simplify the thread queue requeue procedure. Add a thread queue agnostic thread priority change handler so that we are able to use alternative thread queue implementations. Update #2273.
* testsuites/sptests/sp54/init.c: Add cast to avoid warningJoel Sherrill2015-03-241-1/+1
* samples/minimum/init.c: Add cast to avoid warningJoel Sherrill2015-03-241-1/+1
* sptls03/init.c: Make type and constants uint32_t to avoid overflow warningsJoel Sherrill2015-03-241-4/+4
* sptls01/init.c: Use larger data types for valuesJoel Sherrill2015-03-241-5/+5
* sptests/spwatchdog/init.c: Avoid integer overflowJoel Sherrill2015-03-241-2/+8
* sptests/spedfsched02: Reduce stack space usage to fix on smaller targetsJoel Sherrill2015-03-242-3/+1
* sptests/spatomic01/init.c: Avoid integer overflowJoel Sherrill2015-03-241-8/+11
* sptests/sp34/changepri.c: Correct printf() warningJoel Sherrill2015-03-241-4/+5
* sptests/sp33/init.c: Correct printf() warningJoel Sherrill2015-03-241-2/+3
* sptests/sp20: Reduce memory requirementsJoel Sherrill2015-03-242-3/+1
| | | | | This was checked on sparc/sis. If this fails on other targets, then the task stack sizes needs to be reevaluated.
* sptests/sp13/system.h: Fine tune message buffer configuration to avoid ↵Joel Sherrill2015-03-241-13/+17
| | | | integer overflow
* sptests/sp12/pritask.c: Correct printf() warningJoel Sherrill2015-03-241-3/+4
* psxconfig01/init.c: Correct pointer/integer size warningJoel Sherrill2015-03-241-1/+1
