* | 2009-10-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-29 | 1 | -0/+1 | |
| | | | | * psx11/task.c: Use long for nsecs. | |||||
* | Use long for nsecs. | Ralf Corsepius | 2009-10-29 | 1 | -7/+1 | |
* | 2009-10-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-29 | 1 | -1/+1 | |
| | | | | | * psx10/init.c: Pass 0x7FFF instead of 0xFFFFFF as invalid pshared attribute to pthread_condattr_setpshared for 16bit target compliance. | |||||
* | 2009-10-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-29 | 1 | -0/+5 | |
* | 2009-10-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-29 | 2 | -1/+5 | |
| | | | | * fileio/init.c: Use %zd to print ssize_t. | |||||
* | 2009-10-28 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-28 | 1 | -0/+2 | |
| | | | | * psxbarrier01/test.c: Include <tmacros.h> | |||||
* | 2009-10-28 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-28 | 1 | -0/+4 | |
* | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-27 | 1 | -0/+1 | |
| | | | | * support/include/tmacros.h: Add PRIxpthread_t. | |||||
* | Add PRIxpthread_t. | Ralf Corsepius | 2009-10-27 | 1 | -0/+4 | |
* | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-27 | 1 | -0/+10 | |
| | | | | | | | | | | * psx01/init.c, psx01/task.c, psx02/init.c, psx03/init.c, psx04/init.c, psx05/init.c, psx06/init.c, psx07/init.c, psx08/init.c, psx09/init.c, psx10/task.c, psx10/task2.c, psx10/task3.c, psx11/init.c, psx12/init.c, psxalarm01/init.c, psxbarrier01/test.c, psxkey01/init.c, psxkey01/task.c, psxmsgq02/init.c, psxsignal01/init.c, psxualarm/init.c: Use PRIxpthread_t to print pthread_t's. | |||||
* | Use PRIxpthread_t to print pthread_t's. | Ralf Corsepius | 2009-10-27 | 22 | -31/+31 | |
* | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-27 | 1 | -0/+2 | |
| | | | | | * sp29/init.c: Include "tmacros.h". Misc. changes related to rtems_intervals. | |||||
* | Include "tmacros.h". | Ralf Corsepius | 2009-10-27 | 1 | -4/+6 | |
| | | | | | * sp14/asr.c: Add PRIxrtems_signal_set. Use PRIxrtems_signal_set to print rtems_signal_set's. | |||||
* | Add PRIxrtems_signal_set. | Ralf Corsepius | 2009-10-27 | 1 | -2/+5 | |
| | | | | * sp13/task3.c: Use PRIu32 to print "count". | |||||
* | Use PRIu32 to print "count". | Ralf Corsepius | 2009-10-27 | 1 | -1/+1 | |
* | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-27 | 1 | -0/+7 | |
| | | | | | | | * termios01/init.c: Fix parity_table_Entry type. Correct parity_table initialization. Add PRIdrtems_termios_baud_t. Use PRIdrtems_termios_baud_t to print rtems_termios_baud_t's. | |||||
* | Fix parity_table_Entry type. | Ralf Corsepius | 2009-10-27 | 1 | -8/+11 | |
* | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-27 | 1 | -1/+3 | |
| | | | | | * sp09/screen12.c: Segment sizes are uintptr_t's. * sp09/screen11.c: Use size_t for "size". | |||||
* | Segment sizes are uintptr_t's. | Ralf Corsepius | 2009-10-27 | 1 | -1/+1 | |
* | Use size_t for "size". | Ralf Corsepius | 2009-10-27 | 1 | -2/+2 | |
| | | | | * sp62/init.c: segment sizes are uintptr_t's. | |||||
* | segment sizes are uintptr_t's. | Ralf Corsepius | 2009-10-27 | 1 | -1/+1 | |
| | | | | | * sp25/task1.c: Use PRIuPTR to print segment_size's. * sp21/task1.c: Add PRIurtems_device_major_number. | |||||
* | Use PRIuPTR to print segment_size's. | Ralf Corsepius | 2009-10-27 | 1 | -2/+2 | |
* | Add PRIurtems_device_major_number. | Ralf Corsepius | 2009-10-27 | 1 | -1/+4 | |
| | | | | | * psxmsgq02/init.c: Remove cast in call to fatal_posix_service_status_errno. | |||||
* | Remove cast in call to fatal_posix_service_status_errno. | Ralf Corsepius | 2009-10-27 | 1 | -1/+1 | |
| | | | | | * sp11/task1.c, sp11/task2.c: Use PRIxrtems_event_set to print rtems_event_set's. | |||||
* | Use PRIxrtems_event_set to print rtems_event_set's. | Ralf Corsepius | 2009-10-27 | 2 | -14/+14 | |
* | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-27 | 2 | -2/+11 | |
| | | | | | * support/include/tmacros.h: Add PRIxrtems_event_set. (fatal_posix_service_status_errno) Add local "long" var "statx". | |||||
* | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-27 | 2 | -2/+5 | |
| | | | | | | * sp09/screen13.c: Revert previous change. Remove broken extraneous line seemingly having crept into in 2009-08-10 patch. | |||||
* | Remove extraneous argument to print. | Ralf Corsepius | 2009-10-27 | 1 | -1/+1 | |
| | | | | * spsize/size.c: Use PRIu32 to print sys_req. | |||||
* | Use PRIu32 to print sys_req. | Ralf Corsepius | 2009-10-27 | 1 | -2/+3 | |
| | | | | * sp37/init.c: Add missing argument to printf. | |||||
* | Add missing argument to printf. | Ralf Corsepius | 2009-10-27 | 1 | -1/+1 | |
* | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-27 | 1 | -0/+5 | |
| | | | | | * base_sp/apptask.c, unlimited/init.c: Use PRIdrtems_task_argument to print rtems_task_argument's. | |||||
* | Use PRIdrtems_task_argument to print rtems_task_argument's. | Ralf Corsepius | 2009-10-27 | 8 | -18/+18 | |
* | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-27 | 1 | -0/+6 | |
| | | | | | | * sp44/init.c, sp35/priinv.c, sp33/init.c, sp28/init.c, sp12/pritask.c, sp34/changepri.c: Use PRIdrtems_task_argument to print rtems_task_argument's. | |||||
| | | | | | * support/include/tmacros.h: Add PRIdThread_Entry_numeric_type. Add PRIdrtems_task_argument. | |||||
* | Add PRIdThread_Entry_numeric_type. | Ralf Corsepius | 2009-10-27 | 1 | -0/+5 | |
| | | | | | * sp25/task1.c: segment_size is uintptr_t. * spfatal06/testcase.h: Add missing return. | |||||
* | segment_size is uintptr_t. | Ralf Corsepius | 2009-10-27 | 1 | -3/+3 | |
* | Add missing return. | Ralf Corsepius | 2009-10-27 | 1 | -0/+1 | |
| | | | | | * psxenosys/init.c: Add missing args in calls to execl, execlp, execle. | |||||
* | Add missing args in calls to execl, execlp, execle. | Ralf Corsepius | 2009-10-27 | 1 | -3/+3 | |
* | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-27 | 1 | -0/+4 | |
| | | | | | | | | | * psxhdrs/pthread36.c: Use HAVE_DECL_PTHREAD_ATTR_GETCPUTIME. * psxhdrs/pthread35.c: Use HAVE_DECL_PTHREAD_ATTR_SETCPUTIME. * psx07/init.c: Use HAVE_DECL_PTHREAD_ATTR_GETCPUTIME, HAVE_DECL_PTHREAD_ATTR_SETCPUTIME. * configure.ac: Add AC_CHECK_DECLS pthread_attr_getcputime, pthread_attr_setcputime. | |||||
* | Use HAVE_DECL_PTHREAD_ATTR_GETCPUTIME. | Ralf Corsepius | 2009-10-27 | 1 | -0/+6 | |
