* | Added test case for rtems_interrupt_catch checking that the pointer | Joel Sherrill | 1997-10-21 | 2 | -1/+11 |
| | | | | for the returned old_isr_handler was non-NULL. | ||||
* | Fixed some spacing. | Joel Sherrill | 1997-10-09 | 2 | -4/+4 |
* | Fix from Eric Norum so FPSP is installed before any FP code is actually | Joel Sherrill | 1997-10-08 | 1 | -0/+9 |
| | | | | exercise. | ||||
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 571 | -1142/+1142 |
* | Fixed some weird line duplications. Thanks to Chris Johns. | Joel Sherrill | 1997-10-06 | 1 | -18/+9 |
* | Added Monitor test. | Joel Sherrill | 1997-09-21 | 2 | -0/+131 |
* | Patches from Chris Johns to clean up test. | Joel Sherrill | 1997-08-26 | 5 | -19/+52 |
* | Merged very large and much appreciated patch from Chris Johns | Joel Sherrill | 1997-07-31 | 7 | -0/+1208 |
| | | | | | <cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test. | ||||
* | Merged very large and much appreciated patch from Chris Johns | Joel Sherrill | 1997-07-31 | 1 | -0/+6 |
* | Added support for rtems_message_queue_get_number_pending. | Joel Sherrill | 1997-07-31 | 4 | -0/+21 |
* | Used macro instead of hard coded number. | Joel Sherrill | 1997-07-09 | 1 | -1/+1 |
* | updated with new license information per Tony Bennett. | Joel Sherrill | 1997-04-22 | 1 | -13/+5 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 563 | -2815/+2815 |
* | Modified to reflect change from 255 posix priority levels to 254. | Joel Sherrill | 1997-04-18 | 3 | -6/+6 |
* | enabled floating point and fixed confdef reference to initialization | Joel Sherrill | 1997-04-09 | 4 | -5/+9 |
| | | | | tasks table. | ||||
* | new test | Joel Sherrill | 1997-04-09 | 12 | -0/+742 |
* | corrected printf specifications and added casts as necessary to eliminate | Joel Sherrill | 1997-04-07 | 7 | -72/+79 |
| | | | | warnings. | ||||
* | added ifdef to avoid warning for unused variable. | Joel Sherrill | 1997-04-07 | 1 | -2/+6 |
* | corrected integer only definitions of "FP CHECK" routines to eliminate | Joel Sherrill | 1997-04-07 | 1 | -3/+10 |
| | | | | warnings. | ||||
* | corrected printf format to avoid warning | Joel Sherrill | 1997-04-02 | 7 | -11/+11 |
* | initialized variables or removed unused variables to remove warnings | Joel Sherrill | 1997-04-02 | 3 | -4/+3 |
* | Made stopping for the pause an option which can be configured in the | Joel Sherrill | 1997-01-29 | 1 | -0/+12 |
| | | | | targopts.h file. | ||||
* | _CPU_Trap_Table_area is now conditional based on whether or not | Joel Sherrill | 1997-01-08 | 1 | -2/+5 |
| | | | | the application requires rtems to allocate a trap table | ||||
* | new files | Joel Sherrill | 1996-09-18 | 3 | -0/+205 |
* | added cast | Joel Sherrill | 1996-09-18 | 1 | -1/+1 |
* | address arithmetic changed to be more portable | Joel Sherrill | 1996-09-18 | 1 | -3/+7 |
* | new test submitted by Craig Lebakken (lebakken@minn.net) and Derrick Ostertag | Joel Sherrill | 1996-09-18 | 3 | -0/+230 |
| | | | | (ostertag@transition.com) | ||||
* | extended Task_id and Task_name arrays to avoid indexing past end of array. | Joel Sherrill | 1996-09-17 | 1 | -2/+2 |
* | Fixed test to match change to pthread_cond_timedwait which now takes a wall | Mark Johannes | 1996-09-12 | 1 | -26/+32 |
| | | | | | | | time. Commented out calls to pthread_cond_wait and pthread_cond_timedwait without the mutex locked before calling. | ||||
* | modified test to take into account change in default value of | Joel Sherrill | 1996-09-06 | 1 | -0/+5 |
| | | | | | inheritsched pthread attribute from implicit to explicit scheduling parameters. | ||||
* | added printf of status when not successful | Joel Sherrill | 1996-09-05 | 1 | -1/+3 |
* | nanosleep no longer consider a negative value of tv_sec to be an error. | Joel Sherrill | 1996-09-05 | 1 | -6/+7 |
| | | | | Instead it is an indication of a request for a small delay. | ||||
* | Changed all EFAULTS to EINVALs | Mark Johannes | 1996-08-23 | 1 | -14/+20 |
* | filled in screen | Mark Johannes | 1996-08-23 | 1 | -0/+11 |
* | Filled in screen | Mark Johannes | 1996-08-23 | 2 | -0/+78 |
* | Filled in the screen | Mark Johannes | 1996-08-23 | 9 | -0/+479 |
* | Added build_time statement to provide a tm for the test | Mark Johannes | 1996-08-23 | 1 | -2/+4 |
* | Changed test 5 to test 10 at bottom | Mark Johannes | 1996-08-23 | 1 | -1/+1 |
* | Commented out the EINVAL for mutex not acquired befor cond_wait call | Mark Johannes | 1996-08-22 | 1 | -4/+9 |
* | updated to support ENOTSUP | Mark Johannes | 1996-08-21 | 1 | -10/+10 |
* | Added Einval case for mutex not initialized | Mark Johannes | 1996-08-20 | 1 | -0/+10 |
* | init: added tests for pthread_kill and kill errors. | Mark Johannes | 1996-08-15 | 1 | -32/+186 |
* | changed error code | Joel Sherrill | 1996-08-15 | 1 | -2/+2 |
* | changed error for too many threads to EAGAIN | Joel Sherrill | 1996-08-15 | 1 | -2/+2 |
* | pthread_mutex_init returns EAGAIN not ENOMEM when there are too many mutexes. | Joel Sherrill | 1996-08-14 | 1 | -2/+2 |
* | added test cases for NULL being passed to pthread attribute get routines | Joel Sherrill | 1996-08-14 | 1 | -0/+20 |
* | added test case for pthread_attr_getscope being passed a NULL contentionscope | Joel Sherrill | 1996-08-14 | 1 | -0/+4 |
* | system.h: added task3 and changed condition variable config to 1 | Mark Johannes | 1996-08-14 | 1 | -1/+6 |
* | task3: added to test error case in Wait_support for lock on mutex | Mark Johannes | 1996-08-14 | 1 | -0/+46 |
* | init: added error case for wait timedwait, and wait support | Mark Johannes | 1996-08-14 | 1 | -8/+153 |
