The rtems_test_busy() is not accurate enough and may lead to sporadic
test failures.
Some time ago the Classic API object size related parameters were
changed to use size_t. Reflect this in the Ada bindings.
Update #3082.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Free deferred locations before the greedy memory allocation. This test
fails on powerpc/qoriq_e6500_64 otherwise.
Update #2843.
This test uses sprintf().
This test uses fprintf().
The fstests use snprintf().
This avoids blocking output and the use of the floating-point unit.
Update #3109.
Updates #3000.
Updates #3000.
If there is already a file with a long file name it isn't possible to
create a second file which has a name that ends on the first files name
(for example ets.beam and sets.beam). This patch fixes that.
Update #3258.
Update test documentation to include more cases.
Updates #3000.
This ensures that the configured semaphore maximum is not exceeded.
Take care that a file in the root directory with the same name as the
volume name can be found.
Update #3257.
Update #3256.
Use a self-contained recursive mutex for API_Mutex_Control. The API
mutexes are protected against asynchronous thread cancellation.
Add dedicated mutexes for libatomic and TOD.
Close #2629.
Close #2630.
A priority of zero is valid for the timer server.
Bug was introduced by d5154d0f6a04f3b7ed59d9a09038576fe2640756.
Updates #2493.
Most Ada tests fail otherwise.
Update #3020.
Reduce size of the big allocation block to account for the optional heap
protection (RTEMS_DEBUG).
maintain.
Update #3254.
Update #3082.
Update #3082.
