* block01/init.c, block02/init.c, block03/init.c, block04/init.c,
block05/init.c, block06/init.c, block07/init.c, block09/init.c,
block10/init.c: Changed CONFIGURE_MAXIMUM_SEMAPHORES defines.
* Makefile.am: Move POSIX in front of other tests.
* support/include/tmacros.h: Changed check_dispatch_disable_level() to
treat all non-zero values of _Thread_Dispatch_disable_level equally.
* psxfile01/test.c: Add check for errno on chdir(NULL).
* psxrdwrv/test.c: Use SIZE_MAX not SSIZE_MAX.
* psx07/init.c, psx07/task.c: Introduce enough of a delay so the Init()
thread can reliably reach the pthread_join() call.
* psxreaddir/psxreaddir.scn, psxreaddir/test.c: Do not test for
rewinddir(NULL) since we are now using newlib's implementation and it
does not check for NULL. This causes a fault on some targets.
* bspcmdline01/init.c: Fix assert conditional.
* POSIX/flockfile.c, POSIX/funlockfile.c, POSIX/ftrylockfile.c: New.
* POSIX/Makefile.am: Add flockfile, funlockfile, ftrylockfile.
* capture/init.c: Remove unused variable "out".
* psx07/init.c, psx09/init.c, psx12/init.c, psxhdrs/pthread11.c,
psxhdrs/pthread22.c, psxhdrs/sched01.c, psxhdrs/sched03.c:
Reflect POSIX changes to sched_param.
* sp62/init.c, sp65/init.c: #include <unistd.h>.
* psxhdrs/proc01.c, psxhdrs/proc02.c, psxhdrs/proc07.c,
psxhdrs/proc08.c, psxhdrs/proc09.c, psxhdrs/proc10.c,
psxhdrs/proc11.c, psxhdrs/proc12.c, psxhdrs/proc13.c,
psxhdrs/proc14.c, psxhdrs/signal20.c, psxhdrs/signal21.c:
* sp43/init.c: Readdress use of ctype methods per recommendation from
D.J. Delorie on the newlib mailing list. We should pass an unsigned
char into these methods.
* fileio/init.c: Remove deprecation warnings.
* fileio/init.c: Fix warnings for ctype methods.
* Makefile.am, configure.ac: Add new fatal error for configuring
unlimited and maximum of 0.
* spfatal13/.cvsignore, spfatal13/Makefile.am, spfatal13/spfatal13.doc,
spfatal13/spfatal13.scn, spfatal13/testcase.h: New files.
* block10/.cvsignore: New file.
* block08/.cvsignore, block09/.cvsignore: New files.
* block08/init.c: Remove warning.
* block08/block08.scn, block08/init.c: Add starting and ending messages
so the scripts detect successful exit.
* sp43/init.c: Fix warning.
* psx13/test.c, psx13/psx13.scn Added new routine PipeTestNull()
to cover the trivial NULL case for pipe function.
* bspcmdline01/init.c, bspcmdline01/bspcmdline01.scn: Added test case
to cover the bsp_cmdline_get_param() routine.
* block06/init.c: Update for disk device API change. Changed EBADRQC
to EINVAL.
* sp69/init.c: Fixed warnings.
* termios01/init.c: Increase number of termios ports by 1.
* sp14/sp14.doc, sp14/sp14.scn: doc file have scn contents. Fix and
update.
* sp69/init.c, sp69/sp69.doc, sp69/sp69.scn: Add test for statistics on
expired periods. This detected the recently introduced PR1480.
* sp69/.cvsignore: New file.
* termios01/termios_testdriver.c:
Reflect changes to rtems_termios_callbacks->write.
* Makefile.am, configure.ac: Added a test for rate_monotonic_get_status
to ensure that all paths are tested.
* sp69/Makefile.am, sp69/init.c, sp69/sp69.doc, sp69/sp69.scn: New files.
* support/include/test_support.h, support/include/tmacros.h,
support/src/test_support.c: Added support functions to spin for a
number of ticks and to spin until the next tick.
* support/src/spin.c: New file.
* psxrwlock01/test.c, psxspin01/test.c, psxspin02/test.c: Fix spacing
and compilation issues. Initial test build was accidentally without
POSIX enabled.
* sp31/task1.c: Fixed spacing.
* support/include/tmacros.h: Use rtems_test_assert() consistently
instead of system assert(). rtems_test_assert() is designed to
integrate into the RTEMS test suite infrastructure.
* tm20/task1.c: Use rtems_test_assert() consistently instead of system
assert(). rtems_test_assert() is designed to integrate into the RTEMS
* tmitronsem01/system.h: Use rtems_test_assert() consistently instead
of system assert(). rtems_test_assert() is designed to integrate into
* sp18/init.c, sp31/task1.c, sp43/init.c, sp63/init.c, sp64/init.c,
spfatal10/testcase.h, spfatal11/testcase.h, spobjgetnext/init.c,
spwkspace/init.c: Use rtems_test_assert() consistently instead of
