path: root/testsuites (follow)
* 2005-03-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-03-072-8/+12
| | | | * sp13/task1.c: Removed warnings.
* 2004-01-06 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-062-0/+7
| | | | * aclocal/prog-cxx.m4: Re-add am__fastdepCXX conditional.
* 2004-01-06 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-062-11/+4
| | | | * aclocal/rtems-flags.m4: Remove (Unused).
* 2004-01-06 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-064-13/+15
| | | | | | | | | | * aclocal/env-rtemsbsp.m4: Remove CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V. * aclocal/prog-cc.m4: Don't invoke _RTEMS_FLAGS to set up RTEMS_CFLAGS. * aclocal/prog-cxx.m4: Let CXXFLAGS default to CFLAGS. Don't invoke _RTEMS_FLAGS to set up RTEMS_CXXFLAGS. Remove am__fastdepCXX conditional.
* 2004-01-06 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-062-3/+6
| | | | | * automake/compile.am: Remove CLEANDIRS (Unused). Remove DEFS (Implicitly handled by automake).
* Remove duplicate CCAS.Ralf Corsepius2005-01-061-1/+0
* 2004-01-06 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-062-57/+13
| | | | | | | | * automake/compile.am: Remove CONFIG.CC (Unused). Remove CPPFLAGS, CFLAGS, CXXFLAGS, ASFLAGS (Implicitly handled by automake). Add CCAS. Use AM_*FLAGS = RTEMS_*FLAGS. Remove LIB_VARIANT from LINK_*. Cleanup comments.
* 2004-01-06 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-062-57/+8
| | | | | * automake/compile.am: Remove AS, ASCOMPILE, make-rel (Unused). Remove build-variants. Hard-code ARCH=o-optimize.
* 2005-01-06 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-063-3/+8
| | | | | * base_mp/node1/Makefile.am, base_mp/node2/Makefile.am: Remove LIB_VARIANT.
* 2005-01-06 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-062-1/+5
| | | | * rtems++/Makefile.am: Remove LIB_VARIANT.
* 2005-01-06 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-0629-28/+46
| | | | | | | | | | | | | | | | | | * mp01/node1/Makefile.am, mp01/node2/Makefile.am, mp02/node1/Makefile.am, mp02/node2/Makefile.am, mp03/node1/Makefile.am, mp03/node2/Makefile.am, mp04/node1/Makefile.am, mp04/node2/Makefile.am, mp05/node1/Makefile.am, mp05/node2/Makefile.am, mp06/node1/Makefile.am, mp06/node2/Makefile.am, mp07/node1/Makefile.am, mp07/node2/Makefile.am, mp08/node1/Makefile.am, mp08/node2/Makefile.am, mp09/node1/Makefile.am, mp09/node2/Makefile.am, mp10/node1/Makefile.am, mp10/node2/Makefile.am, mp11/node1/Makefile.am, mp11/node2/Makefile.am, mp12/node1/Makefile.am, mp12/node2/Makefile.am, mp13/node1/Makefile.am, mp13/node2/Makefile.am, mp14/node1/Makefile.am, mp14/node2/Makefile.am: Remove $(LIB_VARIANT).
* 2004-01-02 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-022-3/+4
| | | | * Makefile.am: Remove DIST_SUBDIRS.
* Cosmetics.Ralf Corsepius2004-12-302-6/+6
* 2004-11-22 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2004-11-223-44/+7
| | | | | * aclocal/enable-itron.m4, aclocal/check-itron.m4: Allow building itron for unix.
* 2004-11-22 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-11-222-1/+6
| | | | | * include/buffer_test_io.h: Use iprintf iff _NEWLIB_VERSION is defined.
* 2004-11-22 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-11-224-7/+11
| | | | | | | * configure.ac: Remove -ansi to prevent folks from further damaging the code with broken prototypes. * putenvtest/init.c: Remove broken putenv prototype. * termios/init.c (print_c_cc): Don't loop over NCCS.
* 2004-11-22 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2004-11-222-1/+6
| | | | | PR 721/tests * itronsem01/init.c: Fix bogus assert.
* 2004-09-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-09-292-19/+4
| | | | * spsize/size.c: i960 obsoleted and all references removed.
* Fix typo in previous change.Ralf Corsepius2004-09-2412-12/+12
* 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-09-2424-12/+60
| | | | * configure.ac: Require automake > 1.9.
* 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-09-242-29/+4
| | | | * aclocal/rtems-cpu-subdirs.m4: Remove (unused).
* 2004-09-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-09-242-2/+4
| | | | * * configure.ac: Remove RTEMS_CPU_SUBDIRS.
* 2004-07-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-07-281-0/+4
| | | | * aclocal/version.m4: Updated to rtems-4.6.99.1.
* Back off version again.Joel Sherrill2004-07-281-4/+0
* Back off version.Joel Sherrill2004-07-281-4/+0
* 2004-07-28Joel Sherrill2004-07-282-1/+5
* 2004-05-10 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-05-109-37/+60
| | | | | | | | | * configure.ac: Add CXX-checks. New conditionals CXXTESTS, MPTESTS, NETTESTS. Add iostream/. * Makefile.am, base_mp/node1/Makefile.am, base_mp/node2/Makefile.am cdtest/Makefile.am, loopback/Makefile.am, pppd/Makefile.am: Reflect changes above. * cdtest/main.cc: Adaptation to new C++ standards.
* 2004-05-10 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-05-107-0/+139
| | | | | | * iostream/Makefile.am, iostream/init.cc, iostream/iostream.doc, iostream/iostream.scn, iostream/system.h: New (C++ variant of hello).
* 2004-04-23 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-232-1/+9
| | | | | | PR 610/bsps * tm27/task1.c: Use _RTEMS_RMTEST27 instead of RTEMS_TM27. Unconditionally include <tm27.h>.
* 2004-04-22 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-224-0/+13
| | | | | | | PR 613/bsps * configure.ac: Add AC_ARG_VAR([MAX_LONG_TEST_DURATION],...). * mp14/node1/Makefile.am, mp14/node2/Makefile.am: Add AM_CPPFLAGS += -DMAX_LONG_TEST_DURATION=$(MAX_LONG_TEST_DURATION).
* 2004-04-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-04-212-4/+6
| | | | | | PR 611/bsps * tm27/task1.c: Follow conventions for tm27 and do not add another macro definition.
* Remove stray white spaces.Ralf Corsepius2004-04-2075-356/+355
* Remove stray white spaces.Ralf Corsepius2004-04-16224-820/+820
* Remove stray white spaces.Ralf Corsepius2004-04-1533-98/+1
* 2004-04-14 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-142-1/+9
| | | | * aclocal/rtems-top.m4: Add project_top/with_project_top processing.
* * tm01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.Ralf Corsepius2004-04-0132-31/+65
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * tm02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm05/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm06/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm07/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm08/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm09/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm10/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm11/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm12/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm13/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm14/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm15/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm16/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm17/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm18/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm19/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm20/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm21/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm22/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm23/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm24/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm25/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm26/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm27/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm28/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm29/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tmck/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tmoverhd/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* * tmitronsem01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.Ralf Corsepius2004-04-012-1/+5
* * sp01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.Ralf Corsepius2004-04-0133-32/+67
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * sp02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp05/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp06/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp07/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp08/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp09/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp11/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp12/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp13/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp14/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp15/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp16/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp17/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp19/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp20/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp21/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp22/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp23/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp24/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp25/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp26/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp27/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp28/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp29/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp30/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp31/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp32/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * spfatal/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * spsize/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* * base_mp/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.Ralf Corsepius2004-04-0112-11/+25
| | | | | | | | | | | | | * base_sp/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * cdtest/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * fileio/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * hello/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * loopback/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * minimum/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * paranoia/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * pppd/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * ticker/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * unlimited/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* * psx01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.Ralf Corsepius2004-04-0124-23/+49
| | | | | | | | | | | | | | | | | | | | | | | | | * psx02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * psx03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * psx04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * psx05/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * psx06/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * psx07/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * psx08/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * psx09/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * psx10/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * psx11/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * psx12/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * psx13/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * psxcancel/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * psxchroot01/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * psxfile01/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * psxmount/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * psxmsgq01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * psxreaddir/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * psxsem01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * psxstat/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * psxtime/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * psxtimer/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* * mp01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.Ralf Corsepius2004-04-0115-14/+31
| | | | | | | | | | | | | | | | * mp02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * mp03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * mp04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * mp05/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * mp06/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * mp07/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * mp08/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * mp09/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * mp10/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * mp11/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * mp12/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * mp13/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * mp14/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* * cpuuse/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.Ralf Corsepius2004-04-019-8/+19
| | | | | | | | | | * malloctest/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * monitor/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * putenvtest/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * rtems++/System.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * rtmonuse/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * stackchk/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * termios/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* * itronhello/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.Ralf Corsepius2004-04-0110-9/+21
| | | | | | | | | | | * itronmbf01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * itronmbox01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * itronsem01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * itrontask01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * itrontask02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * itrontask03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * itrontask04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * itrontime01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-012-1/+5
| | | | * tmitronsem01/system.h: Include <rtems/itron.h> instead of <itron.h>.
| | | | * sp07/buffered_io.c: Include <rtems/ringbuf.h> instead of <ringbuf.h>.
| | | | * fileio/init.c: Include <rtems/dosfs.h> instead of <dosfs.h>.
* 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-015-4/+11
| | | | | | | * psxcancel/init.c: Include <rtems/console.h> instead of <console.h>. * psxmount/test.c: Include <rtems/imfs.h> instead of <imfs.h>. * psxreaddir/test.c: Include <rtems/imfs.h> instead of <imfs.h>. * psxstat/test.c: Include <rtems/imfs.h> instead of <imfs.h>.
* 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-0110-9/+21
| | | | | | | | | | | | * itronhello/system.h: Include <rtems/itron.h> instead of <itron.h>. * itronmbf01/system.h: Include <rtems/itron.h> instead of <itron.h>. * itronmbox01/system.h: Include <rtems/itron.h> instead of <itron.h>. * itronsem01/system.h: Include <rtems/itron.h> instead of <itron.h>. * itrontask01/system.h: Include <rtems/itron.h> instead of <itron.h>. * itrontask02/system.h: Include <rtems/itron.h> instead of <itron.h>. * itrontask03/system.h: Include <rtems/itron.h> instead of <itron.h>. * itrontask04/system.h: Include <rtems/itron.h> instead of <itron.h>. * itrontime01/system.h: Include <rtems/itron.h> instead of <itron.h>.
* 2004-03-30 David Querbach <querbach@realtime.bc.ca>Joel Sherrill2004-03-307-33/+30
| | | | | | | | | PR 595/tests * sp13/fillbuff.c, sp13/init.c, sp13/putbuff.c, sp13/system.h, sp13/task1.c, sp13/task2.c: Fill_buffer() in fillbuff.c overruns the supplied buffer due to confusion in the definition of MESSAGE_SIZE. Some files in the sp13 test treat MESSAGE_SIZE as a count of bytes, others treat it as a count of longs.
