* configure.in: Remove stubdr, wrapup, AC_INIT(include).
* Makefile.am: Remove stubdr, wrapup.
* stubdr/Makefile.am, stubdr/open.c, stubdr/close.c, stubdr/init.c,
stubdr/stubdrv.h, stubdr/cntrl.c, stubdr/.cvsignore, stubdr/read.c,
stubdr/write.c, wrapup/Makefile.am, wrapup/.cvsignore, stubdr/,
wrapup/: Remove.
* tm20/Makefile.am: Remove stubdir.rel
* sp21/Makefile.am: Remove libtest.
* psx01/psx01.scn: Corrected to reflect clock_getres() now working.
* psxstat/test.c, psxstat/psxstat.scn: Forced inode numbers
to remain consistant across platforms and bsps by forcing
a mount point in front of all paths.
2000-11-17 Jennifer Averret <jennifer@OARcorp.com>
* psxmount/test.c, psxmount/psxmount.scn: Improve output to report
expected error condition in one case.
* psxreaddir/test.c, psxreaddir.scn: Added test cases to exercise
readdir() of root of mounted filesystem. Also corrected the screen
file for some mistakes noticed in this effort.
* itrontask01/system.h: Configure enough stack memory.
* psxmount/psxmount.scn, psxmount/test.c: Correct spelling.
* stubdr/Makefile.am: Replace leaf.cfg w/ automake/lib.am.
* malloctest/task1.c: assoc.h, error.h, libio_.h, libio.h, and
libcsupport.h moved from libc to lib/include/rtems and now must
be referenced as <rtems/XXX.h>.
effects in RTEMS source code.
* paranoia/paranoia.c: Commented out incorrect and conflicting
prototype of read().
* itrontests.am: Remove DEFS.
* libtests.am: Remove DEFS.
* mptests.am: Remove DEFS.
* psxtests.am: Remove DEFS.
* sample.am: Remove DEFS.
* sptests.am: Remove DEFS.
* tmitrontests.am: Remove DEFS.
* tmtests.am: Remove DEFS.
* configure.in: Replace AC_CONFIG_SUBDIRS with
RTEMS_CONFIG_BUILD_SUBDIRS.
* psxmount/test.c, psxstat/test.c: Include <imfs.h> to get IMFS_ops.
It was formerly incorrectly prototyped in <libio.h>.
* sp20/sp20.scn: Corrected to reflect new addition.
* sp20/system.h: Removed comment reflecting history.
* sp20/getall.c, sp20/init.c, sp20/system.h, sp20/task1.c:
Added new task to test sequence of altering a period's length
while it is still active.
* stubdr/Makefile.am, wrapup/Makefile.am: Include compile.am
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am,
base_sp/Makefile.am, cdtest/Makefile.am, hello/Makefile.am,
minimum/Makefile.am, paranoia/Makefile.am, ticker/Makefile.am,
unlimited/Makefile.am: Include compile.am
* tmitronsem01/Makefile.am: Include compile.am
psx13/Makefile.am, psxcancel/Makefile.am, psxfile01/Makefile.am,
psxhdrs/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am,
psxreaddir/Makefile.am, psxsem01/Makefile.am, psxstat/Makefile.am,
psxtime/Makefile.am, psxtimer/Makefile.am: Include compile.am
* cpuuse/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am,
putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am,
stackchk/Makefile.am, termios/Makefile.am: Include compile.am
* itronhello/Makefile.am, itronmbf01/Makefile.am,
itronmbox01/Makefile.am, itronsem01/Makefile.am,
itrontask01/Makefile.am, itrontask02/Makefile.am,
itrontask03/Makefile.am, itrontask04/Makefile.am,
itrontime01/Makefile.am: Include compile.am
* mp01/node1/Makefile.am, mp01/node2/Makefile.am,
mp02/node1/Makefile.am, mp02/node2/Makefile.am,
mp03/node1/Makefile.am, mp03/node2/Makefile.am,
mp04/node1/Makefile.am, mp04/node2/Makefile.am,
mp05/node1/Makefile.am, mp05/node2/Makefile.am,
mp06/node1/Makefile.am, mp06/node2/Makefile.am,
mp07/node1/Makefile.am, mp07/node2/Makefile.am,
mp08/node1/Makefile.am, mp08/node2/Makefile.am,
mp09/node1/Makefile.am, mp09/node2/Makefile.am,
mp10/node1/Makefile.am, mp10/node2/Makefile.am,
mp11/node1/Makefile.am, mp11/node2/Makefile.am,
mp12/node1/Makefile.am, mp12/node2/Makefile.am,
mp13/node1/Makefile.am, mp13/node2/Makefile.am,
mp14/node1/Makefile.am, mp14/node2/Makefile.am: Include compile.am
* tm01/Makefile.am, tm02/Makefile.am, tm03/Makefile.am,
tm04/Makefile.am, tm05/Makefile.am, tm06/Makefile.am,
tm07/Makefile.am, tm08/Makefile.am, tm09/Makefile.am,
tm10/Makefile.am, tm11/Makefile.am, tm12/Makefile.am,
tm13/Makefile.am, tm14/Makefile.am, tm15/Makefile.am,
tm16/Makefile.am, tm17/Makefile.am, tm18/Makefile.am,
tm19/Makefile.am, tm20/Makefile.am, tm21/Makefile.am,
tm22/Makefile.am, tm23/Makefile.am, tm24/Makefile.am,
tm25/Makefile.am, tm26/Makefile.am, tm27/Makefile.am,
tm28/Makefile.am, tm29/Makefile.am, tmck/Makefile.am,
tmoverhd/Makefile.am: Include compile.am
psx10/Makefile.am, psx11/Makefile.am, psx11/Makefile.am,
psx12/Makefile.am, psxcancel/Makefile.am, psxmsgq01/Makefile.am,
psxsem01/Makefile.am, psxsem01/Makefile.am, psxtimer/Makefile.am:
Use AM_CPPFLAGS += instead of AM_CPPFLAGS =
is no such thing on the C4x.
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
that is a hack to workaround a switch generation compiler bug for the
SH2 and cleaned up some warnings.
significant things:
and PowerPC
same code base.
that contains:
* Removes MKLIB
handling)
