* loopback/init.c: Fix exit paths in client thread and main test
thread.
* aclocal/check-cpuopts.m4: Check rtems/system.h instead of
rtems/score/cpuopts.h.
* tm09/task1.c, tm10/task1.c, tm11/task1.c, tm12/task1.c, tm13/task1.c,
tm14/task1.c, tm22/task1.c: Address size_t/uint32_t typing issues in
message queue tests.
* sp09/screen07.c, sp09/task3.c, sp13/task1.c, sp13/task2.c,
sp13/task3.c: Address size_t/uint32_t typing issues in message queue
tests.
* rtems++/Task1.cc, rtems++/Task3.cc: Address size_t/uint32_t typing
issues in message queue tests.
* itronmbf01/init.c: Address size_t/uint32_t typing issues in message
queue tests.
fixed synchronization bug between ata.c and bdbuf.c
* psxrwlock01/main.c, psxrwlock01/test.c: Improve rwlock test to
include normal blocking and unblocking on timeout.
* sp33/init.c: Improve barrier test to include normal blocking with
manual release and unblocking in barrier deletion.
* sp27/init.c, sp27/sp27.scn: Correct configured number of semaphores
and make output more compliant with other tests.
* psxsem01/init.c: Account for change in POSIX semaphore time handling.
Previously the timeout was not absolute time and checked BEFORE
attempting to lock semaphore.
* sp09/screen12.c, sp16/task2.c, sp16/task3.c: Ensure tests generate
cases intended on all targets possible with new heap algorithm.
* itrontask04/init.c, itrontask04/itrontask04.scn: Cannot print with
dispatching disabled so fix test not to print while dispatching is
disabled.
* psxbarrier01/main.c: New file.
* Makefile.am, configure.ac: Adding Classic API Barriers.
* sp33/.cvsignore, sp33/Makefile.am, sp33/init.c, sp33/sp33.scn:
New files.
* psxrwlock01/.cvsignore, psxrwlock01/Makefile.am, psxrwlock01/main.c,
psxrwlock01/psxrwlock01.scn, psxrwlock01/test.c,
psxspin01/.cvsignore, psxspin01/Makefile.am, psxspin01/main.c,
psxspin01/psxspin01.scn, psxspin01/test.c: New files.
* Makefile.am, configure.ac: Adding POSIX barriers, POSIX spinlocks,
and partial implementation of POSIX rwlocks.
* psxbarrier01/.cvsignore, psxbarrier01/Makefile.am,
psxbarrier01/psxbarrier01.scn, psxbarrier01/test.c: New files.
PR 841/rtems
* psxsem01/init.c: Make sem_timedwait more conformant to Open Group
specification.
* aclocal/rtems-top.m4: Remove RTEMS_API.
* aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8.
* aclocal/prog-cxx.m4: Add AC_PROG_CXXCPP.
* aclocal/version.m4: Bump version to 4.7.99.0.
PR 1162/rtems
* unlimited/system.h: Reserve enough memory for the stacks wanted.
* mp01/node1/Makefile.am, mp01/node2/Makefile.am,
mp02/node1/Makefile.am, mp02/node2/Makefile.am,
mp03/node1/Makefile.am, mp03/node2/Makefile.am,
mp04/node1/Makefile.am, mp04/node2/Makefile.am,
mp05/node1/Makefile.am, mp05/node2/Makefile.am,
mp06/node1/Makefile.am, mp06/node2/Makefile.am,
mp07/node1/Makefile.am, mp07/node2/Makefile.am,
mp08/node1/Makefile.am, mp08/node2/Makefile.am,
mp09/node1/Makefile.am, mp09/node2/Makefile.am,
mp10/node1/Makefile.am, mp10/node2/Makefile.am,
mp11/node1/Makefile.am, mp11/node2/Makefile.am,
mp12/node1/Makefile.am, mp12/node2/Makefile.am,
mp13/node1/Makefile.am, mp13/node2/Makefile.am,
mp14/node1/Makefile.am, mp14/node2/Makefile.am: Eliminate scndir,
docdir. Use rtems_testsdir instead.
* tm01/Makefile.am, tm02/Makefile.am, tm03/Makefile.am,
tm04/Makefile.am, tm05/Makefile.am, tm06/Makefile.am,
tm07/Makefile.am, tm08/Makefile.am, tm09/Makefile.am,
tm10/Makefile.am, tm11/Makefile.am, tm12/Makefile.am,
tm13/Makefile.am, tm14/Makefile.am, tm15/Makefile.am,
tm16/Makefile.am, tm17/Makefile.am, tm18/Makefile.am,
tm19/Makefile.am, tm20/Makefile.am, tm21/Makefile.am,
tm22/Makefile.am, tm23/Makefile.am, tm24/Makefile.am,
tm25/Makefile.am, tm26/Makefile.am, tm27/Makefile.am,
tm28/Makefile.am, tm29/Makefile.am, tmck/Makefile.am,
tmoverhd/Makefile.am: Eliminate scndir, docdir. Use rtems_testsdir
instead.
* tmitronsem01/Makefile.am: Eliminate scndir, docdir. Use
sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am,
spfatal/Makefile.am, spsize/Makefile.am: Eliminate scndir, docdir.
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am,
base_sp/Makefile.am, cdtest/Makefile.am, fileio/Makefile.am,
hello/Makefile.am, iostream/Makefile.am, loopback/Makefile.am,
minimum/Makefile.am, paranoia/Makefile.am, ticker/Makefile.am,
unlimited/Makefile.am: Eliminate scndir, docdir. Use rtems_testsdir
instead.
* cpuuse/Makefile.am, malloctest/Makefile.am, rtems++/Makefile.am,
rtmonuse/Makefile.am, stackchk/Makefile.am: Eliminate scndir,
psx13/Makefile.am, psxcancel/Makefile.am, psxchroot01/Makefile.am,
psxfile01/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am,
psxreaddir/Makefile.am, psxsem01/Makefile.am, psxstat/Makefile.am,
psxtime/Makefile.am, psxtimer/Makefile.am: Eliminate scndir, docdir.
* itronhello/Makefile.am, itronmbf01/Makefile.am,
itronmbox01/Makefile.am, itronsem01/Makefile.am,
itrontask01/Makefile.am, itrontask02/Makefile.am,
itrontask03/Makefile.am, itrontask04/Makefile.am,
itrontime01/Makefile.am: Eliminate scndir, docdir. Use
* aclocal/version.m4: Updated to rtems-4.6.99.3.
Victor V. Vengerov <Victor.Vengerov@oktetlabs.ru>
* spsize/size.c: Victor spotted the problem that
_MPCI_Receive_server_tcb and _Thread_MP_Receive were duplicate
variables and needed to be set to the same value. I took that
idea and just removed _Thread_MP_Receive. All uses are now
_MPCI_Receive_server_tcb.
* rtems++/Task1.cc: Fix warnings.
* cdtest/main.cc: Fix warnings.
