description follows:
Description:
config.h.ins)
acpolish
configure scripts
Remarks:
[$(prefix)].
are:
I have a few patches for the efi332 bsp. If you let me know when you
expect the next snapshot release, I will try to have them to you
before then. Also, the malloctest has some problems that I would think
would prevent it from running on almost any platform. I have enclose
patches below to fix (1) Task_id and Task_name dimensioning, (2) end
of test message, (3) the amount of memory malloc'ed, and (4) retry on
unsuccessful (out of memory) molloc's.
that are part of the addition of POSIX timers.
blocking protocol is used.
Updated scn files to match present expected test output.
PROBLEMS
can/will be fixed.
it work.
ports.
The array is too long and needs to be shortened.
problem and an English problem.
Fixed interface to cofndefs.h for initial extension set.
more accurate.
generated.
for them.
the CPU family name constants.
mode at the end of the test. This eliminates the possibility of IO
blocking a task unexpectedly and messing up the test.
enclose.
