path: root/testsuites (follow)
* tools: Remove rtems-bin2cSebastian Huber2018-06-142-2/+2
| | | | | | This tool is now included in the RTEMS tools repository. Close #3380.
* Add RTEMS_FATAL_SOURCE_INVALID_HEAP_FREESebastian Huber2018-06-058-10/+78
| | | | | | | | An invalid heap usage such as a double free is usually a fatal error since this indicates a use after free. Replace the use of printk() in free() with a fatal error. Update #3437.
* Update rtems_fatal_source_text()Sebastian Huber2018-06-052-2/+3
| | | | | | Add RTEMS_FATAL_SOURCE_PANIC to rtems_fatal_source_text(). Update #3244.
* capture: Use unlimited objectsSebastian Huber2018-06-041-3/+2
| | | | Avoid resource allocation problems with unlimited objects.
* Fix and extend error message in posix timer testMartin Erik Werner2018-05-301-2/+12
| | | | | | | | | | _Timespec_Equal_to() does not set errno, hence avoid using perror(), instead use fprintf() to stderr, and extend the error message to provide information about what the error is (measured timer value after re-arming is not equal to the configured interval), and how large of a difference was measured. Signed-off-by: Martin Erik Werner <martin.werner@aacmicrotec.com>
* sptests: Remove CONFIGURE_MILLISECONDS_PER_TICKSebastian Huber2018-05-282-4/+0
| | | | This configuration define is not supported.
* dltests-broken-on-this-bsp.tcfg: Add dl06Joel Sherrill2018-05-211-0/+1
* libtests/block05: Use rtems_blkdev_create()Sebastian Huber2018-05-181-22/+25
| | | | Update #3358.
* libblock: Init deps in rtems_blkdev_create()Sebastian Huber2018-05-181-2/+8
| | | | Update #3358.
* spcpucounter01: Enable floating-point outputSebastian Huber2018-05-141-0/+1
* ftpfs: Always build FTP clientSebastian Huber2018-05-021-1/+1
| | | | | | Move FTP client filesystem to separate library libftpfs.a. Update #3419.
* libdebugger: Move to separate librarySebastian Huber2018-05-021-0/+1
| | | | | | | | | | Always build remote TCP support since it depends only on the POSIX socket API. It works with the legacy network stack and libbsd. Move it to a separate libdebugger.a library to allow an easy use with libbsd via "-ldebugger -lbsd" otherwise we would have a cyclic dependency between libbsd.a and librtemscpu.a. Update #3419.
* tests: Move rtems-test-check.pySebastian Huber2018-05-022-1/+161
| | | | Remove shell script variant.
* tests: Remove difftest and sorttimes toolsSebastian Huber2018-05-026-358/+0
| | | | Close #3418.
* tests: Remove configure feature checksSebastian Huber2018-05-0223-334/+11
| | | | Update #3409.
* Drop executable permissions on .[ch] filesJoel Sherrill2018-04-301-0/+0
* smptests/smpschededf02: Add test caseSebastian Huber2018-04-271-3/+8
* bsps: Move make/custom/* files to bspsSebastian Huber2018-04-231-1/+1
| | | | | | | | | Adjust various build files. Remove automatic generation of the c/src/lib/libbsp/*/acinclude.m4 files from bootstrap script. This patch is a part of the BSP source reorganization. Update #3285.
* smptests/smpschedaffinity02: Fix configurationSebastian Huber2018-04-231-0/+2
* sptests/sp36: Remove obsolete test programSebastian Huber2018-04-225-212/+0
| | | | | | | | It tests the (never really working) strict order mutex option. That option does not exist any more. Mutexes by other good means (spmutex01, spsem*). Update #3406.
* build: Remove subdir-objects from Ada testsSebastian Huber2018-04-201-1/+1
| | | | | | | | | | | Somehow it does not work. With this Automake option you get: gmake[6]: Entering directory '/build/sparc-rtems5/c/erc32/testsuites/ada/sptests' Making all-am in sp01 gmake[7]: Entering directory '/build/sparc-rtems5/c/erc32/testsuites/ada/sptests/sp01' gmake[7]: *** No rule to make target 'init.o', needed by 'ada_sp01.exe'. Stop. Update #3387.
* bsps: Move startup files to bspsSebastian Huber2018-04-202-3/+3
| | | | | | | | Adjust build support files to new directory layout. This patch is a part of the BSP source reorganization. Update #3285.
* Multiple BSP tcfg: Disable iconv files.Joel Sherrill2018-04-171-0/+7
* libdl: Fix the tests loading the correct filesChris Johns2018-04-126-18/+18
* testsuites/dl06: Add a test for RAP format.Chris Johns2018-04-1210-26/+428
| | | | | | | This test loads a RAP format file that contains calls that are not in the kernel and linked from libm. It uses and test rtems-ld. Update #2769
* build: Add support for automake's silent build support.Chris Johns2018-04-121-61/+61
* build: Fix make clean.Chris Johns2018-04-111-1/+2
| | | | Update #3254.
* configure: Add subdir-objects to all automake flags.Chris Johns2018-04-1115-15/+15
| | | | | | | | | | | This option silences warning with automake-1.16.1 allowing us to upgrade to that version. This change has been tested with automake-1.12.6 and automake-1.16.1. It seems version 1.16.1 configures slower than 1.12.6 for the same source and BSP. The newer versions is 6 second slower. Close #3387.
* Generate an error if a BSP in the --enable-rtemsbsp list is not validChris Johns2018-04-111-14/+0
| | | | | | | Also generate an error if the architecure does not match the --target architecture given to configure's command line. Close #2641.
* fstest/fsrfsbitmap01: Update RFS bitmap tests to test fixes.Chris Johns2018-04-111-0/+19
| | | | | | Add tests to check the patches for this ticket exist and are fixed. Close #3089
* sptests: Fix AM_CONDITIONALSebastian Huber2018-04-101-2/+2
| | | | Update #3382.
* testsuites: Remove the test check from the subdir support.Chris Johns2018-04-101-23/+3
| | | | | | Leave the parallel support so each test group builds in parallel. Update #3382
* testsuite/tmtests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-1043-1043/+437
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* testsuite/sptests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-10219-5001/+2257
* testsuite/smptests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-1057-1191/+691
* testsuite/samples: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-1022-372/+168
* testsuite/irhealstone: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-108-155/+78
* testsuite/psxtmtests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-1051-1370/+711
* testsuite/psxtests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-10105-2686/+1294
* testsuite/mptests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-1080-633/+262
* testsuite/fstests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-1097-1730/+702
* testsuite/libtests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-10100-2480/+1401
* testsuite/benchmarks: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-105-73/+51
* testsuite: Autoconf test check support.Chris Johns2018-04-101-0/+31
| | | | | | | | | The autoconf function checks the state of a test for the BSP and controls the building of the test. This change is part of the testsuite Makefile.am reorganisation. Update #3382
* build: Remove DISTCLEANFILESSebastian Huber2018-04-091-1/+0
| | | | | A "make distclean" is not supported. So, it makes no sense to have pure "make distclean" related stuff in the Makefile.am.
* build: Remove EXTRA_DISTSebastian Huber2018-04-047-30/+0
| | | | | A "make dist" is not supported. So, it makes no sense to have pure "make dist" related stuff in the Makefile.am.
* config: Use new scheduler configuration definesSebastian Huber2018-03-1219-308/+308
| | | | Update #3325.
* sptests/sp19: Fix test output methodsSebastian Huber2018-03-082-2/+14
| | | | Do not use fprintf() in non-fp tasks.
* libtests/capture01: Fix configurationSebastian Huber2018-03-071-0/+1
* smptests: Fix obsolete FIXME comments/codeSebastian Huber2018-03-072-4/+2
