* sample.am, base_sp/Makefile.am, cdtest/Makefile.am,
fileio/Makefile.am, hello/Makefile.am, iostream/Makefile.am,
loopback/Makefile.am, minimum/Makefile.am, paranoia/Makefile.am,
pppd/Makefile.am, ticker/Makefile.am, unlimited/Makefile.am:
s/SAMPLE/TEST/ for improved consistency with other tests.
* support/.cvsignore: New file.
* configure.ac: Add ampolish3.
* base_mp/Makefile.am: Remove redundant EXTRA_DIST.
* Makefile.am: Don't preinstall support/include headers.
* tm02/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tm03/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tm04/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tm05/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tm06/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tm07/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tm08/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tm09/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tm10/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tm11/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tm12/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tm13/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tm14/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tm15/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tm16/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tm17/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tm18/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tm19/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tm20/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tm21/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tm22/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tm23/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tm24/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tm25/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tm26/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tm27/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tm28/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tm29/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tmck/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tmoverhd/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* tmitronsem01/Makefile.am: AM_CPPFLAGS += -I..../support/include.
sp28/Makefile.am, sp29/Makefile.am, sp30/Makefile.am,
sp31/Makefile.am, sp32/Makefile.am, spfatal/Makefile.am,
spsize/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* mp01/node1/Makefile.am, mp01/node2/Makefile.am,
mp02/node1/Makefile.am, mp02/node2/Makefile.am,
mp03/node1/Makefile.am, mp03/node2/Makefile.am,
mp04/node1/Makefile.am, mp04/node2/Makefile.am,
mp05/node1/Makefile.am, mp05/node2/Makefile.am,
mp06/node1/Makefile.am, mp06/node2/Makefile.am,
mp07/node1/Makefile.am, mp07/node2/Makefile.am,
mp08/node1/Makefile.am, mp08/node2/Makefile.am,
mp09/node1/Makefile.am, mp09/node2/Makefile.am,
mp10/node1/Makefile.am, mp10/node2/Makefile.am,
mp11/node1/Makefile.am, mp11/node2/Makefile.am,
mp12/node1/Makefile.am, mp12/node2/Makefile.am,
mp13/node1/Makefile.am, mp13/node2/Makefile.am,
mp14/node1/Makefile.am, mp14/node2/Makefile.am:
* cpuuse/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am,
putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am,
stackchk/Makefile.am, termios/Makefile.am:
* itronhello/Makefile.am, itronmbf01/Makefile.am,
itronmbox01/Makefile.am, itronsem01/Makefile.am,
itrontask01/Makefile.am, itrontask02/Makefile.am,
itrontask03/Makefile.am, itrontask04/Makefile.am,
itrontime01/Makefile.am:
psx13/Makefile.am, psxcancel/Makefile.am, psxchroot01/Makefile.am,
psxfile01/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am,
psxreaddir/Makefile.am, psxsem01/Makefile.am, psxstat/Makefile.am,
psxtime/Makefile.am, psxtimer/Makefile.am:
* cdtest/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* configure.ac: Fix config-variables of conditionally built subdirs.
* aclocal/check-itron.m4, aclocal/check-multiprocessing.m4,
aclocal/check-networking.m4, aclocal/check-posix.m4,
aclocal/check-tests.m4, aclocal/enable-itron.m4,
aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4,
aclocal/enable-posix.m4: Remove (Unused).
* configure.ac: Apply RTEMS_CHECK_CPUOPTS.
* aclocal/prog-cc.m4: Apply cpukit_root, project_root to set up
GCCSPECS.
check cpuopts.h.
* aclocal/check-cpuopts.m4: Apply cpukit_root, project_root to set
up temporary CPPFLAGS to compile check cpuopts.h.
Fix --enable-rtems-root.
* aclocal/rtems-top.m4: Add --enable-cpukit-root,
--enable-project-root. Remove --with-project-root.
* automake/compile.am, aclocal/env-rtemsbsp.m4:
Assume PROJECT_ROOT to contain RTEMS_BSP.
* tmtests.am: Set project_bspdir=$(PROJECT_ROOT)
* tmitrontests.am: Set project_bspdir=$(PROJECT_ROOT)
* sptests.am: Set project_bspdir=$(PROJECT_ROOT)
* sample.am: Set project_bspdir=$(PROJECT_ROOT)
* psxtests.am: Set project_bspdir=$(PROJECT_ROOT)
* mptests.am: Set project_bspdir=$(PROJECT_ROOT)
* libtests.am: Set project_bspdir=$(PROJECT_ROOT)
* itrontests.am: Set project_bspdir=$(PROJECT_ROOT)
* Makefile.am: Merge-in support/Makefile.am
* configure.ac: Add AMPOLISH3. Remove support/.
* aclocal/check-cpuopts.m4: Add config.cache support.
* aclocal/check-cxx.m4: Remove CPLUS_LD_LIBS.
* automake/compile.am: Eliminate PROJECT_LIB.
Remove START_FILE, OBJS from LINK_FILES.
