* | Ensure security of default user environment | Sebastian Huber | 2014-11-20 | 6 | -0/+214 |
* | shell: Do chroot() after successful login | Sebastian Huber | 2014-11-20 | 2 | -2/+44 |
* | shell: Get supplementary group IDs in login check | Sebastian Huber | 2014-11-20 | 1 | -0/+13 |
* | Add supplementary groups to user environment | Sebastian Huber | 2014-11-20 | 1 | -0/+171 |
* | samples/fileio: Use unlimited objects | Sebastian Huber | 2014-11-20 | 1 | -8/+1 |
* | samples/fileio: Fix warning | Sebastian Huber | 2014-11-20 | 1 | -0/+2 |
* | libcsupport: Implement getgroups() | Sebastian Huber | 2014-11-20 | 4 | -8/+103 |
* | libcsupport: Use POSIX key for getgrent() | Sebastian Huber | 2014-11-20 | 2 | -0/+4 |
* | shell: Use crypt_r() in rtems_shell_login_check() | Sebastian Huber | 2014-11-20 | 7 | -4/+188 |
| | | | | | | | Use '*" to disable shell login instead of '!' according to the Linux man page. Use getpwnam_r() instead of getpwnam(). Do not access the user environment directly. Update the user environment only after a successful login check. | ||||
* | libcsupport: Minimal /etc/passwd and /etc/group | Sebastian Huber | 2014-11-20 | 2 | -106/+30 |
| | | | | | Create a minimal /etc/passwd and /etc/group with user root and group root only with no passwords. | ||||
* | libcsupport: Avoid TOCTOU and format errors | Sebastian Huber | 2014-11-20 | 6 | -0/+178 |
* | Add crypt_r(), etc. | Sebastian Huber | 2014-11-20 | 6 | -0/+374 |
| | | | | | Add crypt_add_format(), crypt_r(), crypt_md5_r(), crypt_sha256_r() and crypt_sha512_r(). | ||||
* | Add SHA256 and SHA512 support | Sebastian Huber | 2014-11-20 | 6 | -0/+245 |
* | Add NXP PCA9548A 8-channel switch I2C driver | Sebastian Huber | 2014-11-20 | 1 | -1/+79 |
* | Add NXP PCA9535 16-bit GPIO I2C driver | Sebastian Huber | 2014-11-20 | 1 | -1/+150 |
* | Add generic EEPROM I2C device driver | Sebastian Huber | 2014-11-20 | 1 | -1/+141 |
* | Add I2C driver framework | Sebastian Huber | 2014-11-20 | 6 | -0/+320 |
| | | | | | | | | | | | | | | | | | This I2C driver framework has some major differences compared to libi2c. * It is compatible to the Linux I2C user-space API. * It uses generic IMFS nodes and thus reduces the levels of indirection. * The drivers don't have to mess around with minor numbers to get their state information. * No arbitrary bus controller model is assumed. The main task of an I2C bus controller driver is to process I2C messages. How this is done is private to the driver. * Scatter/gather operations are supported (I2C_M_NOSTART). | ||||
* | libtests/top: End test after some time if no input | Sebastian Huber | 2014-11-20 | 1 | -0/+23 |
* | libdl: Disable building libdl for the NIOS2. No relocation support. | Chris Johns | 2014-11-06 | 1 | -1/+1 |
| | | | | This should have been added. | ||||
* | libtests: Add libdl test dl02. | Chris Johns | 2014-11-04 | 11 | -1/+413 |
| | | | | Loads 2 interdependent ELF object files. | ||||
* | libtests: Update dl01 documentation. | Chris Johns | 2014-11-04 | 3 | -1/+40 |
* | dl01/dl-load.c: Add missing const | Joel Sherrill | 2014-11-02 | 1 | -1/+1 |
* | cpukit: Add libdl with the Runtime Loader (RTL) code. | Chris Johns | 2014-10-31 | 9 | -1/+278 |
| | | | | This is a merge of the RTL project. | ||||
* | top: Add new test. | Jennifer Averett | 2014-10-28 | 9 | -1/+388 |
* | capture01: Remove capture task tracking. | Jennifer Averett | 2014-10-27 | 1 | -27/+85 |
| | | | | | This involved adding a new variable record to the capture buffer and modifing the trace method to read those records. | ||||
* | smptests/smpfatal03: Wait for end of test msg | Sebastian Huber | 2014-10-24 | 1 | -0/+2 |
* | tests/smptests: Normal use of test extension | Sebastian Huber | 2014-10-24 | 2 | -4/+4 |
* | tests/smptests: Use barriers in smpfatal0{12} | Sebastian Huber | 2014-10-23 | 2 | -4/+18 |
| | | | | | Call the test extension explicitly and wait for report output using a barrier. This avoids problems with an early shutdown of the system. | ||||
* | testsuites: Move include for C++ compatibility | Sebastian Huber | 2014-10-23 | 1 | -3/+2 |
* | Revert "fstests/mdosfs_fstime: Remove test" | Sebastian Huber | 2014-10-23 | 3 | -0/+35 |
| | | | | This reverts commit bdcf4102f71d1bc2a50f23d2d425d85c24ec0900. | ||||
* | testsuites: Avoid clock driver | Sebastian Huber | 2014-10-14 | 3 | -3/+3 |
* | nsecs/init.c: Use long to avoid overflow on 16-bit targets | Joel Sherrill | 2014-10-13 | 1 | -2/+3 |
* | score: Rework global construction | Sebastian Huber | 2014-10-13 | 17 | -2/+310 |
| | | | | | | Ensure that the global construction is performed in the context of the first initialization thread. On SMP this was not guaranteed in the previous implementation. | ||||
* | Eliminate use of /*PAGE and clean up formatting | Joel Sherrill | 2014-10-09 | 2 | -35/+5 |
* | samples/base_sp: Fix printf() warning | Joel Sherrill | 2014-10-09 | 1 | -2/+3 |
* | samples/unlimited: Fix printf() warning and clean up | Joel Sherrill | 2014-10-09 | 5 | -24/+33 |
* | IMFS: Avoid NULL pointer access | Sebastian Huber | 2014-10-08 | 1 | -0/+11 |
| | | | | | Avoid NULL pointer access in IMFS_is_imfs_instance(). File systems mounted via mount() always have a valid type string. | ||||
* | posix: Add auto initializaton for rwlock | Sebastian Huber | 2014-10-08 | 1 | -0/+37 |
* | termios: Partially hide rtems_termios_tty | Sebastian Huber | 2014-10-07 | 1 | -19/+33 |
| | | | | | | | Move interrupt lock to device context and expose only this structure to the read, write and set attributes device handler. This makes these device handler independent of the general Termios infrastructure suitable for direct use in printk() support. | ||||
* | termios: Separate flow control from normal handler | Sebastian Huber | 2014-10-07 | 1 | -7/+42 |
* | pppd: Fix warnings | Sebastian Huber | 2014-09-30 | 1 | -3/+1 |
* | sptests/spintrcritical22: New test | Sebastian Huber | 2014-09-19 | 6 | -0/+176 |
* | smptests/smpload01: Report profiling only once | Sebastian Huber | 2014-09-17 | 2 | -184/+0 |
| | | | | Rely on test extension to report profiling. | ||||
* | Use correct prototype of benchmark_timer_read() | Joel Sherrill | 2014-09-16 | 50 | -52/+50 |
| | | | | | | | | | | | | | | This change starts with removing the effectively empty file timerdrv.h. The prototypes for benchmark_timer_XXX() were in btimer.h which was not universally used. Thus every use of timerdrv.h had to be changed to btimer.h. Then the prototypes for benchmark_timer_read() had to be adjusted to return benchmark_timer_t rather than int or uint32_t. I took this opportunity to also correct the file headers to separate the copyright from the file description comments which is needed to ensure the copyright isn't propagated into Doxygen output. | ||||
* | sptests/sp07: Minimize thread dispatch latency | Sebastian Huber | 2014-09-16 | 11 | -157/+71 |
| | | | | | | Do not use sprintf() in thread dispatch critical sections to avoid corruption of profiling samples. Update test to reflect thread the life cycle changes. | ||||
* | smptests/smpcache01: Remove invalidation of data cache lines from test | Daniel Cederman | 2014-09-16 | 3 | -33/+33 |
| | | | | | Invalidation of entire data cache might cause data written to the stack to get lost. | ||||
* | sptests/spintrcritical_support: Optimize busy loop | Sebastian Huber | 2014-09-12 | 1 | -3/+4 |
* | sptests/spintrcritical10: Avoid undefined memory | Sebastian Huber | 2014-09-12 | 1 | -0/+3 |
* | tmtests/tmcontext01: Improve cache dirty function | Sebastian Huber | 2014-09-11 | 1 | -14/+24 |
| | | | | Increment by cache line size to allow more cycles per second. | ||||
* | sptests/spfatal07: Fix end of test message | Sebastian Huber | 2014-09-10 | 1 | -1/+1 |
