* | Use linker set for libio initialization | Sebastian Huber | 2016-02-03 | 2 | -17/+27 |
| | | | | Update #2408. | ||||
* | Use linker set for root file system initialization | Sebastian Huber | 2016-02-03 | 1 | -0/+24 |
* | Optional POSIX Keys initialization | Sebastian Huber | 2016-02-03 | 1 | -0/+17 |
* | Optional CPU Set Handler initialization | Sebastian Huber | 2016-02-03 | 1 | -0/+13 |
* | Optional POSIX Spinlock initialization | Sebastian Huber | 2016-02-03 | 1 | -0/+17 |
* | Optional POSIX RWLock initialization | Sebastian Huber | 2016-02-03 | 1 | -0/+17 |
* | Optional POSIX Barrier initialization | Sebastian Huber | 2016-02-03 | 1 | -0/+17 |
* | Optional POSIX Timer initialization | Sebastian Huber | 2016-02-03 | 1 | -0/+17 |
* | Optional POSIX Semaphore initialization | Sebastian Huber | 2016-02-03 | 1 | -0/+17 |
* | Optional POSIX Message Queue initialization | Sebastian Huber | 2016-02-03 | 1 | -0/+17 |
* | Optional POSIX Mutex initialization | Sebastian Huber | 2016-02-03 | 1 | -0/+17 |
* | Optional POSIX Condition Variable initialization | Sebastian Huber | 2016-02-03 | 1 | -0/+17 |
* | Optional POSIX Cleanup initialization | Sebastian Huber | 2016-02-03 | 1 | -0/+26 |
* | Optional POSIX Threads initialization | Sebastian Huber | 2016-02-03 | 1 | -0/+21 |
* | Optional POSIX Signals initialization | Sebastian Huber | 2016-02-03 | 1 | -0/+36 |
* | Optional Classic Barrier initialization | Sebastian Huber | 2016-02-03 | 1 | -0/+17 |
* | Optional Classic Rate Monotonic initialization | Sebastian Huber | 2016-02-03 | 1 | -0/+17 |
* | Optional Classic Dual-Ported Memory initialization | Sebastian Huber | 2016-02-03 | 1 | -0/+17 |
* | Optional Classic Region initialization | Sebastian Huber | 2016-02-03 | 1 | -0/+17 |
* | Optional Classic Partition initialization | Sebastian Huber | 2016-02-03 | 2 | -0/+18 |
* | Optional Classic Semaphore initialization | Sebastian Huber | 2016-02-03 | 1 | -0/+17 |
* | Optional Classic Message Queue initialization | Sebastian Huber | 2016-02-03 | 1 | -0/+17 |
* | Optional Classic Event initialization | Sebastian Huber | 2016-02-03 | 1 | -0/+13 |
* | Optional Classic Signal initialization | Sebastian Huber | 2016-02-03 | 1 | -0/+13 |
* | Optional Classic Timer initialization | Sebastian Huber | 2016-02-03 | 3 | -5/+28 |
* | Optional Classic Tasks initialization | Sebastian Huber | 2016-02-03 | 1 | -0/+15 |
* | Optional Extensions initialization | Sebastian Huber | 2016-02-03 | 1 | -0/+17 |
* | Optional Initial Extensions initialization | Sebastian Huber | 2016-02-03 | 1 | -0/+17 |
* | score: Create idle threads via linker set | Sebastian Huber | 2016-02-03 | 1 | -20/+56 |
| | | | | | | This allows a more fine grained rtems_initialize_data_structures(). Update #2408. | ||||
* | fstests/fsdosfsname01: Fix Makefile.am | Sebastian Huber | 2016-01-27 | 1 | -14/+2 |
* | sptests/spsyslock01: Disable POSIX dependent parts | Sebastian Huber | 2016-01-26 | 1 | -0/+8 |
* | psxtests: Disable POSIX only psxcleanup02 | Sebastian Huber | 2016-01-26 | 1 | -1/+1 |
* | score: Delete obsolete CPU_TIMESTAMP_* defines | Sebastian Huber | 2016-01-25 | 1 | -7/+2 |
| | | | | Update #2271. | ||||
* | rhealstone/rhtaskpreempt/taskpreempt.c: Fix warning due to oddly placed ↵ | Joel Sherrill | 2016-01-24 | 1 | -2/+2 |
| | | | | semi-colon | ||||
* | Remove AVR port | Joel Sherrill | 2016-01-19 | 1 | -3/+1 |
| | | | | closes #2443. | ||||
* | psxtests: Fix link-time errors | Sebastian Huber | 2016-01-19 | 6 | -93/+2 |
| | | | | | | | Fix link-time errors introduced by e39cdb875ce7458787b0be173f2f7893a774a673. Update #2531. | ||||
* | libtests/devfs: Inc max dev to support more BSPs | Sebastian Huber | 2016-01-19 | 2 | -1/+6 |
* | sptests/sp37: Fix interrupt level usage | Sebastian Huber | 2016-01-19 | 1 | -8/+9 |
* | sptests/sp37: Enable interrupts after test case | Sebastian Huber | 2016-01-15 | 2 | -5/+10 |
| | | | | This avoids a test failure on ARMv7-M targets. | ||||
* | score: Statically initialize TOD handler | Sebastian Huber | 2016-01-12 | 1 | -3/+55 |
* | score: Introduce Thread_Entry_information | Sebastian Huber | 2016-01-11 | 3 | -16/+8 |
| | | | | | | | This avoids potential dead code in _Thread_Handler(). It gets rid of the dangerous function pointer casts. Update #2514. | ||||
* | smptests/README: Delete obsolete information | Sebastian Huber | 2016-01-11 | 1 | -5/+0 |
* | score: Add fatal errors for NULL entry init tasks | Sebastian Huber | 2016-01-08 | 4 | -8/+15 |
| | | | | | | This simplifies the global construction. Update #2514. | ||||
* | Filesystem: Remove superfluous permission checks | Sebastian Huber | 2016-01-05 | 2 | -5/+20 |
| | | | | The permission is check by the upper layer. | ||||
* | Remove H8300 port | Joel Sherrill | 2016-01-04 | 2 | -4/+1 |
| | | | | updates #2452. | ||||
* | Remove M32R architecture | Joel Sherrill | 2016-01-04 | 1 | -2/+1 |
| | | | | updates #2446. | ||||
* | score: Fix watchdog insert | Sebastian Huber | 2016-01-04 | 1 | -4/+44 |
| | | | | | | | | | Under certain conditions a new watchdog was inserted with a wrong and very large delta interval due to a wrong iterator update. Bug was introduced by 1ccbd052910ed16131c74b0d5595c8a94066942d. Close #2507. | ||||
* | sptests/sp07: Fix test case | Sebastian Huber | 2016-01-04 | 2 | -13/+7 |
| | | | | | | Fix things broken by commit d5154d0f6a04f3b7ed59d9a09038576fe2640756. Update #2493. | ||||
* | api: Remove deprecated Notepads | Aun-Ali Zaidi | 2015-12-24 | 43 | -1002/+98 |
| | | | | | | | | | | | | | | | | | | | | | | | Notepads where a feature of RTEMS' tasks that simply functioned in the same way as POSIX keys or threaded local storage (TLS). They were introduced well before per task variables, which are also deprecated, and were barely used in favor of their POSIX alternatives. In addition to their scarce usage, Notepads took up unnecessary memory. For each task: - 16 32-bit integers were allocated. - A total of 64 bytes per task per thread. This is especially critical in low memory and safety-critical applications. They are also defined as uint32_t, and therefore are not guaranteed to hold a pointer. Lastly, they are not portable solutions for SMP and uniprocessor systems, like POSIX keys and TLS. updates #2493. | ||||
* | score: Fix watchdog removal | Sebastian Huber | 2015-12-21 | 1 | -5/+57 |
| | | | | | | | | | Under certain conditions a new watchdog was inserted with a wrong and very large delta interval due to an incomplete iterator update. Bug was introduced by 1ccbd052910ed16131c74b0d5595c8a94066942d. Close #2501. |
