were done by Joel.
were done by Joel.
must deal with a pending process oriented signal. Prior to the addition
of this testcase, sigtimedwait() did not return properly when a process
oriented signal was pending. The problem was reported by Wayne
Bullaughey <wayneb@cacdsp.com>.
RTEMS_TM27 is defined before the bsp.h is included.
to fail sporadically.
an array sizing coding error.
addition.
addition.
which ontains all what was left over from the other patches (Primarily
minor configuration cleanups).
patch -p1 < rtems-rc-19991203-9.diff
./bootstrap
which does minor cleanup for Makefile.ams below mptests, which only
removes some bogus comments from the Makefile.ams.
patch -p1 < rtems-rc-19991203-8.diff
./bootstrap
too small when OPERATION_COUNT is less than 10.
and his EPICS porting effort.
<corsepiu@faw.uni-ulm.de>:
The patch below provides
before)
rtems-rc-19991123-rc-2.diff
Attention:
the opportunity to work with it.
<corsepiu@faw.uni-ulm.de> which converted fiels to automake.
Addtional major bugs:
<corsepiu@faw.uni-ulm.de>.
in the previous commits.
to convert the psxtests directory from Makefile.in to Makefile.am.
to convert the tmtests directory from Makefile.in to Makefile.am.
to convert the sample tests to automake.
by the same application.
+ Added tests for sem_open, sem_close, and sem_unlink.
+ Yellow lined sem_open, sem_close, sem_unlink,
_POSIX_Semaphore_Delete, _POSIX_Semaphore_Name_to_id,
and _POSIX_Semaphore_Create_support. Except for MP, pshared
OBJECT_REMOTE, and out of memory paths.
can be included from the same file.
