Update #3334.
Recursive usage of the same pthread_once_t results now in a deadlock.
Previously, an error of EINVAL was returned. This usage scenario is
invalid according to the POSIX pthread_once() specification.
Close #3334.
This file is unused and makes trouble on Windows.
Updates #3638.
- Add support for architecure sections that can be handled by the
architecture back end.
- Add trampoline/fixup support for PowerPC. This means the PowerPC
now supports large memory loading of applications.
- Add a bit allocator to manage small block based regions of memory.
- Add small data (sdata/sbss) support for the PowerPC. The support
makes the linker allocated small data region of memory a global
resource available to libdl loaded object files.
Updates #3687
Updates #3685
- Add trampolines to support relocs that are out of range on
support architectures.
- Support not loading separate text/data sections in an object
file if the symbol provided in the section is a duplicate.
A base image may have pulled in part of an object and another
part needs to be dynamically loaded.
- Refactor the unresolved handling to scale to hundreds of
unresolved symbols when loading large number of files.
Updates #3685
- Trampolines or fixups for veneers provide long jump support
for instruciton sets that implement short relative address
branches. The linker provides trampolines when creating a
static image. This patch adds trampoline support to libdl
and the ARM architecture.
- The dl09 test requires enough memory so modules are outside
the relative branch instruction ranges for the architecture.
Updates #3685
- Fix the handling of pending objects.
- Add a constructor flags in objects to track then being called.
Closes #2921
- Create 2 archives.
- Load 1 object file which loads 6 object files from the libraries.
Updates #3686
Updates #3686
Updates #3686
We must add/remove the priority queue to the FIFO of priority queues.
Update #3665.
Add low level event recording infrastructure for system and user
defined events. The infrastructure is able to record high frequency
events such as
* SMP lock acquire/release,
* interrupt entry/exit,
* thread switches,
* UMA zone allocate/free, and
* Ethernet packet input/output, etc.
It allows post-mortem analysis in fatal error handlers, e.g. the last
events are in the record buffer, the newest event overwrites the oldest
event. It is possible to detect record buffer overflows for consumers
that expect a continuous stream of events, e.g. to display the system
state in real-time.
The implementation supports high-end SMP machines (more than 1GHz
processor frequency, more than four processors).
Add a new API instead. The implementation uses per-processor data
structures and no atomic read-modify-write operations. It is uses
per-processor ring buffers to record the events.
The CPU counter is used to get the time of events. It is combined with
periodic uptime events to synchronize it with CLOCK_REALTIME.
The existing capture engine tries to solve this problem also, but its
performance is not good enough for high-end production systems. The
main issues are the variable-size buffers and the use of SMP locks for
synchronization. To fix this, the API would change significantly.
Update #3665.
This avoids link-time failures on some low memory BSPs.
Update #3384.
Ensure that interrupts are disabled while acquiring an ISR lock.
Do not rely on compiler optimizations to throw away empty loops.
Close #3673.
In case the robust thread dispatch is enabled by the CPU port, then the
interrupt level must not be changed through the task mode.
Update #3000.
Update #3000.
It is unnecessary to run these test cases with interrupts disabled.
This enables support for non-standard compiler names, e.g.
sparc-rtems6-gcc.
sparc-rtems6-gcc.
Checking of atime in psxfile01 (line 713) can fail since a delay for
rtems_clock_get_ticks_per_second (line 699) gives a delay of less than
one second, depending on when the last tick occurred. atime is measured
in whole seconds, and a fast processor might read the file before a new
second occurs. Add one tick to the delay will solve the problem.
Ensure that the C++17 aligned new operator works.
Close #3666.
Allocate the per-CPU data for secondary processors directly from the
heap areas before heap initialization and not via
_Workspace_Allocate_aligned(). This avoids dependency on the workspace
allocator. It fixes also a problem on some platforms (e.g. QorIQ) where
at this early point in the system initialization the top of the RAM is
used by low-level startup code on secondary processors (boot pages).
Update #3507.
Updated licenses of the files I wrote to the 2-Clause BSD License.
This work was part of GCI 2018.
Statically allocate the objects information together with the initial
set of objects either via <rtems/confdefs.h>. Provide default object
informations with zero objects via librtemscpu.a. This greatly
simplifies the workspace size estimate. RTEMS applications which do not
use the unlimited objects option are easier to debug since all objects
reside now in statically allocated objects of the right types.
Close #3621.
Use Objects_Information::objects_per_block to provide this information.
Add and use _Objects_Is_auto_extend().
Update #3621.
The Copyright clause has been changed to BSD-2-Clause for all the tests in the
header files math.h , utime.h , fmtmsg.h and sys/ipc.h .
The Google Code-In finished before I could submit this, so I thought I would submit this instead of letting it go to waste.
