Update #3117.
Update #3182.
Move it from the configuration to a separate variable.
Update #3117.
Update #3182.
Update #3117.
Update #3182.
This value is frequently used. Avoid the function call overhead and the
integer division at run-time.
Update #3117.
Update #3182.
Update #3182.
Reduce test context size in non-SMP configurations.
Close #3200.
Updates #3170.
call to printk.
Updates #3170.
Ensure that the time flow of CLOCK_REALTIME and CLOCK_MONOTONIC is close to
the clock driver ticks time flow.
Update #2674.
Update #3112.
Update #3113.
Update #3114.
Update #3115.
Move sporadic server scheduler parameters to
POSIX_API_Control::Sporadic. Remove redundant scheduler priority
parameter.
Update #2514.
The thread POSIX API control must be fully initialized in
_POSIX_Threads_Create_extension(), otherwise a pthread_setschedparam()
is broken for all threads not created with pthread_create().
Rename PER_CPU_WATCHDOG_RELATIVE in PER_CPU_WATCHDOG_MONOTONIC to
highlight the corresponding POSIX CLOCK_MONOTONIC.
Rename PER_CPU_WATCHDOG_ABSOLUTE in PER_CPU_WATCHDOG_REALTIME to
highlight the corresponding POSIX CLOCK_REALTIME.
Update #3117.
Update #3182.
This solves a build dependency issue, e.g. building tests before
librtemsbsp.a exists.
Close #3079.
Closes #3181.
Closes #3084.
Update #2514.
Use Processor_mask instead.
Update #2514.
Update #2514.
Set default thread processor affinity to all processors of the
pre-allocated set. This allows to constify the
_POSIX_Threads_Default_attributes.
Update #2514.
Simplify
* pthread_attr_setstack(), and
* pthread_attr_setstacksize().
Update #2514.
Update #2514.
Close #3174.
Return stack area via pthread_getattr_np().
Simplify
* pthread_attr_setaffinity_np(), and
* pthread_attr_getaffinity_np()
and let the scheduler do the more sophisticated error checks.
Make
* pthread_setaffinity_np(),
* pthread_getaffinity_np(),
available in all configurations.
Update #2514.
Close #3145.
Close #3168.
Update #3111.
POSIX mutexes are now available in all configurations and no longer
depend on --enable-posix.
Update #2514.
Update #3112.
POSIX condition variables are now available in all configurations and no
longer depend on --enable-posix.
Update #2514.
Update #3113.
POSIX rwlocks are now available in all configurations and no longer
Update #2514.
Update #3115.
POSIX barriers are now available in all configurations and no longer
Update #2514.
Update #3114.
For semaphore object pointer and object validation see
POSIX_SEMAPHORE_VALIDATE_OBJECT().
Destruction or close of a busy semaphore returns an error status. The
object is not flushed.
POSIX semaphores are now available in all configurations and no longer
Update #2514.
Update #3116.
Close #3153.
closes #3148.
Close #3137.
Close #3126.
Close #3125.
Update #3136.
Check iop reference count in close() and return -1 with errno set to
EBUSY in case the file descriptor is still in use.
Update #3132.
This simplifies error handling later.
Update #3132.
Since we have only one process, sharing between processes is trivial.
Close #3124.
Close #3003.
Update #2132.
Close #3088.
Update #3082.
