* tar01/Makefile.am, tar02/Makefile.am: Apply TARTESTS.
* tar01/Makefile.am:
Apply $LN_S, $PAX. Use subshell for tarball creation.
Don't add initial_fs to CLEANFILES.
* tar02/Makefile.am:
* configure.ac: Add AC_PROG_LN_S.
Add AC_PATH_PROG([PAX]).
Add AM_CONDITIONAL(TARTESTS).
Eliminate stamp-filesystem.
Add BUILT_SOURCES.
* configure.ac: autoconf >= 2.65, automake >= 1.11.
PR 1642/testing
* psximfs02/init.c, psximfs02/psximfs02.scn,
psximfs02/psximfs02.doc, psximfs02/Makefile.am: New test added.
* configure.ac, Makefile.am: Changes to accommodate psximfs02
test.
PR 1633/testing
* psximfs01/init.c, psximfs01/psximfs01.scn,
psximfs01/psximfs01.doc: New cases to exercise
IMFS_memfile_remove.
PR 1621/testing
* Makefile.am, configure.ac: Improve coverage of private environment.
* spprivenv01/.cvsignore, spprivenv01/Makefile.am, spprivenv01/init.c,
spprivenv01/spprivenv01.doc, spprivenv01/spprivenv01.scn: New files.
* tar01/Makefile.am, tar02/Makefile.am: Fix dependencies for parallel
build.
* tar01/Makefile.am, tar02/Makefile.am: Replace mkdir cascade
with $(MKDIR_P).
* tar01/Makefile.am, tar02/Makefile.am: Misc. fixes.
* tar01/Makefile.am, tar03/Makefile.am: Remove MANAGERS.
* sp43/init.c, sp43/sp43.scn: Add code to exercise case where an API
pointer is NULL when getting an object name.
* psxobj01/Makefile.am, psxobj01/init.c, psxobj01/psxobj01.scn: Add
test for runnign out of workspace when setting object name as string.
* sp11/sp11.scn, sp11/task1.c: Add test case for receiving all events
no wait but the condition is only partially satisfied.
PR 1532/testing
* aclocal/project-root.m4: Add initial tests for untar capabilities.
PR 1532/testing
* Makefile.am, configure.ac: Add initial tests for untar capabilities.
* tar01/.cvsignore, tar01/Makefile.am, tar01/init.c, tar01/tar01.doc,
tar01/tar01.scn, tar02/.cvsignore, tar02/Makefile.am, tar02/init.c,
tar02/tar02.doc, tar02/tar02.scn: New files.
PR 1629/cpukit
* psx04/init.c: sigsuspend() was not completely following the POSIX
specification.
PR 1631/testing
* gxx02/init.c, gxx02/gxx02.scn, gxx02/gxx02.doc,
gxx02/Makefile.am, gxx02/gxx_wrappers.h: New test added
* Makefile.am, configure.ac: Changes to accommodate new tests
PR 1632/testing
* Makefile.am, configure.ac: Make dedicated fatal error test for
/dev/null already registered. Using code from Bharath in new test
framework.
* devnullfatal01/.cvsignore, devnullfatal01/Makefile.am,
devnullfatal01/devnullfatal01.doc, devnullfatal01/devnullfatal01.scn,
devnullfatal01/testcase.h: New files.
PR 1632/testing
* devfs04/init.c, devfs04/test_driver.c: Added cases to exercise
null_initialize() and null_write().
* Makefile.am, configure.ac: Add test to extract a task blocked with
timeout on a priority ordered thread queue.
* sp72/.cvsignore, sp72/Makefile.am, sp72/init.c, sp72/sp72.doc,
sp72/sp72.scn: New files.
* gxx01/gxx01.scn, gxx01/init.c: Remove local _exit().
* gxx01/gxx01.scn, gxx01/init.c: Add test f0r rtems_gxx_key_dtor().
* gxx01/gxx01.scn, gxx01/init.c: Add more testcases.
* devfs02/init.c, devfs02/devfs02.doc, devfs02/devfs02.scn,
devfs02/Makefile.am: New tests added
* devfs03/init.c, devfs03/devfs03.doc, devfs03/devfs03.scn,
devfs03/Makefile.am: New tests added
* devfs04/init.c, devfs04/devfs04.doc, devfs04/devfs04.scn,
devfs04/Makefile.am: New tests added
* Makefile.am, configure.ac: Changes to accommodate the above
newly added tests.
* Makefile.am, configure.ac, termios06/init.c: Add initial tests for
XON/XOFF and VMIN/VMAX cases.
* termios07/.cvsignore, termios07/Makefile.am, termios07/init.c,
termios07/termios07.doc, termios07/termios07.scn,
termios08/.cvsignore, termios08/Makefile.am, termios08/init.c,
termios08/termios08.doc, termios08/termios08.scn: New files.
PR 1623/testing
* psx13/test.c, psx13/psx13.scn: New cases to improve coverage of
utime() and fpathconf().
* psxfile01/test.c, psxfile01/psxfile01.scn: New cases to improve
coverage of rmdir(), unlink(), mknod(), link(), open(), read(),
write().
* psxstat/test.c, psxstat/psxstat.scn: New case to improve
coverage of readlink().
* Makefile.am, configure.ac: Add tar test for error cases.
* tar03/.cvsignore, tar03/Makefile.am, tar03/init.c, tar03/tar03.doc,
tar03/tar03.scn: New files.
* stringto01/init.c, stringto01/stringto01.scn,
stringto01/stringto_test_template.h: Attempt to pick up a few more
error paths.
PR 1622/testing
* psxchroot01/test.c, psxchroot01/psxchroot01.scn: Added two test
cases to completely cover chroot().
PR 1617/testing
* spmountmgr01/init.c, spmountmgr01/spmountmgr01.scn,
spmountmgr01/spmountmgr01.doc: Added cases to exercise
mount-mktgt.c.
* psxfile01/test.c: Avoid NULL pointer access.
PR 1617/testing
* psxfile01/test.c, psxfile01/psxfile01.scn: Added new cases to
exercise_link_r and _unlink_r
* psxstat/test.c, psxstat/psxstat.scn: Added new cases to exercise
_lstat_r and _stat_r.
* psxtime/test.c, psxtime/psxtime.scn: Added new cases to exercise
_gettimeofday.
PR 1617/testing
* malloctest/init.c: Added new case to exercise _realloc_r.
PR 1617/testing
* spmountmgr01/init.c, spmountmgr01/Makefile.am,
spmountmgr/.cvsignore, spmountmgr01/spmountmgr01.doc,
spmountmgr01/spmountmgr01.scn: New test which improves coverage
of mount-mgr.c under libcsupport.
* Makefile.am, configure.ac: Changes to accommodate the new test.
* malloctest/init.c: Added test for
rtems_heap_allocate_aligned_with_boundary().
* psxstat/test.c: Avoid NULL pointer access.
* Makefile.am, configure.ac: Add new test to exercise devFS_Show().
* devfs01/.cvsignore, devfs01/Makefile.am, devfs01/devfs01.doc,
devfs01/devfs01.scn, devfs01/init.c: New files.
malloc_get_statistics().
* malloc05/.cvsignore, malloc05/Makefile.am, malloc05/init.c,
malloc05/malloc05.doc, malloc05/malloc05.scn: New files.
PR 1535/tests
* malloc04/init.c, malloc04/malloc04.scn: Address issues in test. A mix
of work by Ralf and Joel.
* spprintk/init.c, spprintk/spprintk.doc, spprintk/spprintk.scn: Clean
up and add test of getchark().
* spfatal21/Makefile.am: Fix typo.
* support/include/test_support.h, support/src/test_support.c: Add
Allocate_majority_of_heap().
* Makefile.am, configure.ac: Add tests for sbrk fatal error case and
libio initialization fatal error case.
* spfatal21/.cvsignore, spfatal21/Makefile.am, spfatal21/spfatal21.doc,
spfatal21/spfatal21.scn, spfatal21/testcase.h, spfatal22/.cvsignore,
spfatal22/Makefile.am, spfatal22/spfatal22.doc,
spfatal22/spfatal22.scn, spfatal22/testcase.h: New files.
* termios01/init.c, termios01/termios01.scn: Fully exercise tcsetattr.
