The IO library used a POSIX key to store an optional POSIX user
environment pointer. This pulled in the POSIX keys support in every
application configuration. Add a user environment pointer to the thread
control block (TCB) instead. Applications which do not need the POSIX
user environment will just get an overhead of one pointer per thread.
Close #3882.
The CONFIGURE_HAS_OWN_INIT_TASK_TABLE and
CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE are the last *_HAS_OWN_*
configuration options. These two options are probably unused, see also:
* https://lists.rtems.org/pipermail/users/2019-April/033129.html
* https://lists.rtems.org/pipermail/users/2019-April/033130.html
Removing them simplifies the configuration. If there is a real user need
which shows up after the removal, we can resurrect them on demand.
Using CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE would have required the
use of the undocumented CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME and
CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE configuration options.
Update #3874.
This improves API backward compatibility of RTEMS 5.1 to previous
versions.
Using CONFIGURE_HAS_OWN_INIT_TASK_TABLE would have required the use of
the undocumented CONFIGURE_INIT_TASK_TABLE and
CONFIGURE_INIT_TASK_TABLE_SIZE configuration options.
Update #3873.
Update #3875.
Update #3875.
Include <mpci.h> for MPCI_Print_statistics().
Update #3875.
Update #3870
Update #3838.
Allocate new thread queue heads during objects information extend. This
removes an error case and the last dependency on the workspace in
_Thread_Initialize().
Update #3835.
Update #3835.
Update #3835.
Place idle and MPCI stacks into extra linker sections. This can be
optionally used by applications to control the placement of the stacks.
Update #3835.
Make functions and data static.
Replace the BSP_DIRTY_MEMORY BSP option with a CONFIGURE_DIRTY_MEMORY
configuration option.
Update #3843.
Use a dedicate system initialization step to zero the memory used for
the workspace and C program heap.
This avoids dead code in case CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY is
not configured.
Canonicalize CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY and use
defined/undefined instead of TRUE/FALSE.
Close #3862.
Remove CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY since it is not needed and
just increases the boot time.
Update #3838.
Update #3861.
Update #3838.
The work area initialization was done by the BSP through
bsp_work_area_initialize(). This approach predated the system
initialization through the system initialization linker set. The
workspace and C program heap were unconditionally initialized. The aim
is to support RTEMS application configurations which do not need the
workspace and C program heap. In these configurations, the workspace
and C prgram heap should not get initialized.
Change all bsp_work_area_initialize() to implement _Memory_Get()
instead. Move the dirty memory, sbrk(), per-CPU data, workspace, and
malloc() heap initialization into separate system initialization steps.
This makes it also easier to test the individual initialization steps.
This change adds a dependency to _Heap_Extend() to all BSPs. This
dependency will be removed in a follow up change.
Update #3838.
Commit e22554535796fc29a7ed7c5e2338128e324a621d changed the error status
from ENOMEM to EAGAIN.
Update #3857.
Problem introduced by 77ac1519e863b7095f69c976353f7647c6f6f63b.
The FACE Technical Standard, Edition 3.0 and later require the definition
of the subcommand SOCKCLOSE in <devctl.h>.
Reference: ​https://www.opengroup.org/face
closes #3856.
Update #2408.
Make sure PER_CPU_DATA_OFFSET() is tested also in uniprocessor
configurations.
Use the user provided now handler of the test configuration to get the
time in T_now().
Use CONFIGURE_MAXIMUM_PROCESSORS to configure the EDF SMP scheduler
context. This avoids hard to debug configuration errors resulting in
memory corruptions.
Close #3815.
Update #3845.
Update #3753.
This function is unused.
Update #3735.
Replace the user MPCI configuration table with a system provided
_MPCI_Configuration.
Update #3735.
Update #3841.
Obsolete undocumented configuration options CONFIGURE_MAXIMUM_FIFOS and
CONFIGURE_MAXIMUM_PIPES. Replace these options with the new
CONFIGURE_IMFS_ENABLE_MKFIFO configuration option.
Update #3840.
Update #3818.
Two use cases were envisioned for this.
1) a BSP or application which desires to update a real-time clock
when the RTEMS TOD is set.
2) a paravirtualized BSP can use this to propagate setting the time
in an RTEMS application to the hosting environment. This enables
the entire set of applications in the virtualized environments
to have a single consistent TOD.
Use self-contained condition variables instead of Classic API barriers.
This simplifies the implementation and configuration.
Update #3840.
The MrsP semaphore implementation predates the addition of
self-contained synchronization objects. At this time, the potential
memory reduction was justified considering the more complex
configuration and additional use of the workspace. With the
availability of self-contained synchronization options, e.g. POSIX
mutexes, this is no longer justified. Memory constrained applications
should use the self-contained synchronization objects. Remove the
CONFIGURE_MAXIMUM_MRSP_SEMAPHORES configuration option. This has only an
impact on applications which use SMP and a large number of scheduler
instances.
Update #3833.
Use a system initialization handler instead of a legacy IO driver.
Update #3834.
Use separator character '_' for all test states.
The rtems_test_pause() and rtems_test_pause_and_screen_number() macros
had different implementations depending on the RTEMS_TEST_NO_PAUSE
define. This define was defined to 1 by default. The user was able to
change this via the undocumented --disable-test-no-pause configure
command line option.
Pausing tests and waiting for user input contradicts the goal of having
automated test runs. Remove this feature.
Update #3818.
This allows to use header includes in "config.h" to reduce the build
configuration checks.
Update #3818.
Update #3818.
Provide an init.c for each Ada test instead of the #include <config.h>
magic which works only due to hand crafted include paths.
Update #3818.
Close #3823.
