* | added test case for pthread_mutexattr_init being passed a null pointer. | Joel Sherrill | 1996-08-09 | 1 | -0/+4 | |
* | changed style of output to match other tests | Joel Sherrill | 1996-08-09 | 1 | -40/+51 | |
* | system.h: initial cvs | Mark Johannes | 1996-08-09 | 1 | -0/+53 | |
* | lowered maximum number of threads to 2 to make test case easier. | Joel Sherrill | 1996-08-09 | 1 | -0/+3 | |
| | | | | include sched.h so test can invoke scheduler routines. | |||||
* | added test case for sched_yield. | Joel Sherrill | 1996-08-09 | 1 | -6/+14 | |
| | | | | changed format of some output. | |||||
* | added test cases for errors in sched_get_priority_min and | Joel Sherrill | 1996-08-09 | 1 | -5/+30 | |
| | | | | | | sched_get_priority_max. added test case for sched_yield. | |||||
* | Init: added condattr - destroy, init, set and get cases | Mark Johannes | 1996-08-09 | 1 | -5/+6 | |
* | added test cases for invalid key ids | Joel Sherrill | 1996-08-09 | 1 | -2/+16 | |
* | reduced maximum keys to 2 to more easily generate error | Joel Sherrill | 1996-08-09 | 1 | -1/+1 | |
* | changed printf's which could be puts's to puts | Joel Sherrill | 1996-08-09 | 3 | -6/+6 | |
* | new test to test scheduling policy and paremeter paths in pthread_create. | Joel Sherrill | 1996-08-08 | 4 | -0/+223 | |
* | Init: Original file - tests for condition variables. | Mark Johannes | 1996-08-08 | 1 | -0/+94 | |
* | split test into multiple tasks. | Joel Sherrill | 1996-08-08 | 3 | -1/+110 | |
* | added cases to increase coverage of pthread_create. cases added tested | Joel Sherrill | 1996-08-08 | 3 | -0/+98 | |
| | | | | error paths as well as inherit scheduling attributes. | |||||
* | added test to complete coverage of pthread_setschedparam and increase | Joel Sherrill | 1996-08-08 | 4 | -0/+251 | |
| | | | | coverage of pthread_create | |||||
* | Init: spacing | Mark Johannes | 1996-08-08 | 1 | -1/+0 | |
* | Task_1: changed comment and task name to task1. | Mark Johannes | 1996-08-08 | 1 | -2/+2 | |
* | Init.c: added priority ceiling task cases. | Mark Johannes | 1996-08-08 | 1 | -20/+204 | |
* | Added task2 and task3 prototypes and ids | Mark Johannes | 1996-08-08 | 1 | -2/+14 | |
* | Signal_info_handler: added multiple signal cases to finish out the test | Mark Johannes | 1996-08-08 | 1 | -2/+218 | |
* | changed phrase "RTEMS is support" to "RTEMS is supposed" | Joel Sherrill | 1996-08-08 | 12 | -12/+12 | |
* | print_current_time: added leading underscore to variables allocated | Joel Sherrill | 1996-08-08 | 1 | -8/+8 | |
| | | | | inside macros. | |||||
* | added complete test cases for pthread_once. | Joel Sherrill | 1996-08-08 | 3 | -16/+44 | |
* | added more error cases to complete testing of pthread_equal when | Joel Sherrill | 1996-08-07 | 1 | -0/+8 | |
| | | | | RTEMS_DEBUG is enabled. | |||||
* | added test cases for ESRCH from pthread_join and pthread_detach | Joel Sherrill | 1996-08-07 | 1 | -0/+9 | |
* | removed if 0 for basic sporadic server case accidentally left in. | Joel Sherrill | 1996-08-07 | 1 | -2/+1 | |
* | basic sporadic server test. | Joel Sherrill | 1996-08-07 | 3 | -0/+285 | |
| | | | | sporadic server with priority ceiling mutex test. | |||||
* | added complete test cases for pthread_attr_getschedparam, | Joel Sherrill | 1996-08-07 | 1 | -9/+137 | |
| | | | | | | pthread_attr_setschedparam, and pthread_getschedparam. added test cases for error paths for pthread_setschedparam. | |||||
* | join/detach basic tests pass | Joel Sherrill | 1996-08-02 | 4 | -0/+181 | |
* | removed unused prototypes | Joel Sherrill | 1996-08-02 | 1 | -9/+0 | |
* | test successfully exercises all of pthread_attr_* set and get routines | Joel Sherrill | 1996-08-01 | 3 | -0/+329 | |
* | added key test | Joel Sherrill | 1996-07-31 | 5 | -0/+271 | |
* | added test case for timeout using pthread_mutex_timedlock | Joel Sherrill | 1996-07-04 | 2 | -0/+19 | |
* | first test cases for mutex manager pass | Joel Sherrill | 1996-07-04 | 4 | -0/+277 | |
* | initial modifications to test sigtimedwait. | Joel Sherrill | 1996-06-15 | 1 | -0/+2 | |
* | first successful run. Has test cases for a simple sigtimedwait() timeout, | Mark Johannes | 1996-06-13 | 4 | -0/+347 | |
| | | | | | a sigtimewait() timeout because it was pthread_kill'ed with a blocked signal, and a sigtimedwait which is satisfied. | |||||
* | Added _Thread_Do_post_task_switch_extension variable. | Joel Sherrill | 1996-06-13 | 1 | -0/+1 | |
* | Added a macro for "empty_line" which will go between test cases. | Joel Sherrill | 1996-06-13 | 1 | -0/+2 | |
* | Added more test cases for kill() and alarm(). kill() now can unblock a | Joel Sherrill | 1996-06-13 | 1 | -23/+68 | |
| | | | | thread which has the signal unblocked. | |||||
* | new files | Joel Sherrill | 1996-06-12 | 3 | -0/+194 | |
* | Added test case which blocks a signal, sees what signals are pending, sends | Joel Sherrill | 1996-06-11 | 1 | -1/+44 | |
| | | | | | that same signal to the executing thread, sees what is pending, then unblocks that signal so the handler can execute. | |||||
* | modified to test pthread_kill() to self and pthread_kill() to a blocked | Joel Sherrill | 1996-06-11 | 2 | -8/+24 | |
| | | | | thread. nanosleep() can be interrupted and return the time remaining. | |||||
* | new files. | Joel Sherrill | 1996-06-10 | 4 | -0/+177 | |
| | | | | | This test does a basic checkout of signals with a thread-directed signal (pthread_kill()) used to interrupt a nanosleep(). | |||||
* | new file | Joel Sherrill | 1996-06-10 | 1 | -0/+83 | |
* | moved the time macros to pmacros.h. | Joel Sherrill | 1996-06-10 | 3 | -38/+4 | |
* | added include of <sched.h> and fixed warnings | Joel Sherrill | 1996-06-06 | 1 | -2/+3 | |
* | added cpu_time_budget field to Thread_Control and removed the global variable | Joel Sherrill | 1996-06-05 | 1 | -1/+0 | |
| | | | | _Thread_Ticks_remaining_in_timeslice. | |||||
* | added test case for sched_get_priority_min, sched_get_priority_max, | Joel Sherrill | 1996-06-04 | 1 | -0/+23 | |
| | | | | and sched_rr_get_interval. | |||||
* | added basic test cases for pthread_self and pthread_equal | Joel Sherrill | 1996-06-04 | 3 | -14/+28 | |
* | updated screen | Joel Sherrill | 1996-06-03 | 5 | -40/+34 | |
