Some _Context_Switch() invocations end up in _Thread_Handler(). Create
the right context for this function.
New test smptests/smpfatal03.
Rename _SMP_Request_other_cores_to_perform_first_context_switch() into
_SMP_Request_start_multitasking() since this requests now a multitasking
start on all configured and available processors. The name corresponds
_Thread_Start_multitasking() and
_SMP_Start_multitasking_on_secondary_processor() actions issued in
response to this request. Move in source file to right place.
Rename PER_CPU_STATE_READY_TO_BEGIN_MULTITASKING into
PER_CPU_STATE_READY_TO_START_MULTITASKING.
Rename PER_CPU_STATE_BEGIN_MULTITASKING into
PER_CPU_STATE_REQUEST_START_MULTITASKING.
Rename _SMP_Request_other_cores_to_shutdown() into
_SMP_Request_shutdown().
Add a per-CPU state lock to protect all changes. This was necessary to
offer a controlled shutdown of the system (atomic read/writes alone are
not sufficient for this kind of synchronization).
Add documentation for Per_CPU_State.
Delete debug output.
New tests smptests/smpfatal01 and smptests/smpfatal02.
Add rtems_cache_get_data_cache_size() and
rtems_cache_get_instruction_cache_size().
A cache line cannot have a negative size.
Do not use _TLS_Size here since this will lead GCC to assume that this
symbol is not 0 and the later > 0 test will be optimized away.
Adjust test to work with clock driver based CPU counters. They have a
period equal to the clock tick interval.
Remove RTEMS_COMPILER_PURE_ATTRIBUTE from _SMP_Get_current_processor()
and all _CPU_SMP_Get_current_processor(). Make inline ASM statements
volatile again. Test smptests/smpmigration01 showed that GCC optimizes
too much otherwise.
Rename _Internal_error_Occurred() into _Terminate().
Use rtems_fatal() instead of _CPU_Fatal_halt() to shutdown processors in
SMP configurations since this allows intervention of BSP or application
specific fatal extensions.
Merge RTEMS_FATAL_SOURCE_BSP_GENERIC and RTEMS_FATAL_SOURCE_BSP_SPECIFIC
into new fatal source RTEMS_FATAL_SOURCE_BSP. This makes it easier to
figure out the code position given a fatal source and code.
This error case is no longer required since rtems_shutdown_executive()
can be called anytime, anywhere
Do not return to BSP context in the exit() shutdown path. This makes it
possible to re-use the initialization stack. It can be used for the
interrupt stack for example. On targets with a small RAM this is a
considerable benefit.
This change eliminates also some special cases and simplifies the code.
Delete _Thread_Set_global_exit_status(),
_Thread_Get_global_exit_status() and _Thread_Stop_multitasking().
Merge systems states SYSTEM_STATE_SHUTDOWN and SYSTEM_STATE_FAILED into
new system state SYSTEM_STATE_TERMINATED. This reflects that all system
termination paths end up in _Internal_error_Occurred().
Make it possible to use normal printf() if requested to allow output of
floating point numbers.
Rename rtems_internal_error_description() to
rtems_internal_error_text(). Rename rtems_fatal_source_description() to
rtems_fatal_source_text(). Rename rtems_status_code_description() to
rtems_status_text(). Remove previous implementation of
Tested and implemented on ARM, m68k, PowerPC and SPARC. Other
architectures need more work.
The lack of a line feed means the output from the test runs into
the MI protocol on GDB as the broken simulator output currently
is not passing through gdb's MI protocol layer.
Alter the output to avoid sending out what is the MI protocol. The SIS
simulator is currently broken and outputs directly to GDB's stdout and
so this output gets parsed as MI output.
From pull request at https://github.com/hazirguo/rtems/commit/fc07a4c501ffebe406464eb9b8dd2097adfd5e60
Fix the documentation for the sp16, sp17 and sp20 tests.
This makes them easier to spot as a group in wildcard searches.
