2005-11-09 | 2005-11-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
* tmitrontests.am: Set project_bspdir=$(PROJECT_ROOT) | |||||
* sptests.am: Set project_bspdir=$(PROJECT_ROOT) | |||||
* sample.am: Set project_bspdir=$(PROJECT_ROOT) | |||||
* psxtests.am: Set project_bspdir=$(PROJECT_ROOT) | |||||
* mptests.am: Set project_bspdir=$(PROJECT_ROOT) | |||||
* libtests.am: Set project_bspdir=$(PROJECT_ROOT) | |||||
* itrontests.am: Set project_bspdir=$(PROJECT_ROOT) | |||||
2005-11-09 | Remove (Merged into ..). | Ralf Corsepius | 4 | -233/+0 | |
2005-11-09 | Merge-in support/ChangeLog. | Ralf Corsepius | 1 | -215/+214 | |
2005-11-09 | 2005-11-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* Makefile.am: Merge-in support/Makefile.am * configure.ac: Add AMPOLISH3. Remove support/. | |||||
2005-11-09 | Add AMPOLISH3. Remove support/. | Ralf Corsepius | 1 | -1/+4 | |
2005-11-09 | New. | Ralf Corsepius | 1 | -0/+26 | |
2005-11-09 | Merge-in support/Makefile.am. | Ralf Corsepius | 1 | -0/+7 | |
2005-11-09 | 2005-11-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+7 | |
* aclocal/check-cpuopts.m4: Add config.cache support. * aclocal/check-cxx.m4: Remove CPLUS_LD_LIBS. * automake/compile.am: Eliminate PROJECT_LIB. Remove START_FILE, OBJS from LINK_FILES. | |||||
2005-11-09 | Eliminate PROJECT_LIB. | Ralf Corsepius | 1 | -4/+2 | |
2005-11-09 | Remove CPLUS_LD_LIBS. | Ralf Corsepius | 1 | -5/+0 | |
2005-11-09 | Add config.cache support. | Ralf Corsepius | 1 | -6/+8 | |
2005-11-09 | 2005-11-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -0/+15 | |
* aclocal/check-cpuopts.m4: New. | |||||
2005-11-09 | Remove stray comment | Ralf Corsepius | 1 | -2/+0 | |
2005-11-08 | changes | Ralf Corsepius | 1 | -0/+15 | |
2005-11-08 | Add ../include/systime.h | Ralf Corsepius | 31 | -31/+31 | |
2005-11-08 | Remove noinst_HEADERS | Ralf Corsepius | 1 | -2/+0 | |
2005-11-08 | 2005-11-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+2 | |
* automake/compile.am: Remove RTEMS_CPPFLAGS, RTEMS_CFLAGS, RTEMS_CXXFLAGS. | |||||
2005-11-08 | Remove RTEMS_CPPFLAGS, RTEMS_CFLAGS, RTEMS_CXXFLAGS. | Ralf Corsepius | 1 | -3/+3 | |
2005-11-08 | Cleanup. | Ralf Corsepius | 1 | -2/+0 | |
2005-11-08 | 2005-11-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+1 | |
* aclocal/gcc-isystem.m4: Remove (Unused). | |||||
2005-11-08 | Remove (Unused). | Ralf Corsepius | 1 | -25/+0 | |
2005-11-08 | 2005-11-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+6 | |
* aclocal/env-rtemsbsp.m4: Remove GCCSPECS. * aclocal/prog-cc.m4: Add GCCSPECS. Remove RTEMS_CPPFLAGS. Remove RTEMS_CFLAGS. | |||||
2005-11-08 | Remove RTEMS_CFLAGS | Ralf Corsepius | 1 | -8/+0 | |
2005-11-08 | Add GCCSPECS. Remove RTEMS_CPPFLAGS. | Ralf Corsepius | 1 | -6/+5 | |
2005-11-08 | Remove GCCSPECS. | Ralf Corsepius | 1 | -5/+0 | |
2005-11-08 | 2005-11-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* aclocal/prog-cc.m4: Remove RTEMS_USE_GCC. Remove RTEMS_GCC_PIPE. Remove RTEMS_GCC_SPECS. * aclocal/gcc-pipe.m4: Remove (Unused). * aclocal/gcc-specs.m4: Remove (Unused). | |||||
2005-11-08 | Cleanup | Ralf Corsepius | 1 | -1/+0 | |
2005-11-08 | Remove RTEMS_USE_GCC. | Ralf Corsepius | 1 | -7/+0 | |
Remove RTEMS_GCC_PIPE. Remove RTEMS_GCC_SPECS. | |||||
2005-11-08 | Remove (Unused). | Ralf Corsepius | 2 | -41/+0 | |
2005-11-08 | 2005-11-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+8 | |
* aclocal/env-rtemsbsp.m4: Merge RTEMS_BSP_SPECS and GCC_SPECS into GCCSPECS. * automake/compile.am: Remove RTEMS_BSP_SPECS, GCC_SPECS. Don't manually set up GCCSPEC (Now setup from inside configure). Remove RTEMS_RELLDFLAGS (Used). | |||||
2005-11-08 | Remove RTEMS_BSP_SPECS, GCC_SPECS. | Ralf Corsepius | 1 | -8/+0 | |
2005-11-08 | Merge RTEMS_BSP_SPECS and GCC_SPECS into GCCSPECS. | Ralf Corsepius | 1 | -5/+4 | |
* automake/compile.am: Remove CCAS support. | |||||
2005-11-08 | Remove CCAS support. | Ralf Corsepius | 1 | -4/+0 | |
2005-11-08 | 2005-11-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+7 | |
* aclocal/multilib.m4: Remove (Unused). * aclocal/check-multiprocessing.m4: Don't require RTEMS_ENABLE_MULTILIB. * aclocal/env-rtemsbsp.m4: Don't provide MULTILIB conditional. | |||||
2005-11-08 | Don't provide MULTILIB conditional. | Ralf Corsepius | 1 | -2/+0 | |
2005-11-08 | Don't require RTEMS_ENABLE_MULTILIB. | Ralf Corsepius | 1 | -1/+0 | |
2005-11-08 | Remove (Unused). | Ralf Corsepius | 1 | -16/+0 | |
2005-11-07 | Fixed formatting. | Joel Sherrill | 1 | -1/+1 | |
2005-11-07 | changes | Ralf Corsepius | 1 | -0/+8 | |
2005-11-07 | New. | Ralf Corsepius | 1 | -0/+1 | |
2005-11-07 | Remove | Ralf Corsepius | 1 | -1/+0 | |
2005-11-07 | Rename TEST to spsize. | Ralf Corsepius | 1 | -1/+1 | |
2005-11-07 | 2005-11-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -2/+7 | |
* Makefile.am: Remove noinst_HEADERS. Remove POSIX_FILES_DIRS, POSIX_FILES_DIRS. * psx13/Makefile.am, psxcancel/Makefile.am, psxchroot01/Makefile.am, psxfile01/Makefile.am, psxmount/Makefile.am, psxreaddir/Makefile.am, psxstat/Makefile.am: Add ../include/pmacros.h |
