* | 2005-11-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-08 | 1 | -0/+4 |
| | | | | | | | * aclocal/prog-cc.m4: Remove RTEMS_USE_GCC. Remove RTEMS_GCC_PIPE. Remove RTEMS_GCC_SPECS. * aclocal/gcc-pipe.m4: Remove (Unused). * aclocal/gcc-specs.m4: Remove (Unused). | ||||
* | Cleanup | Ralf Corsepius | 2005-11-08 | 1 | -1/+0 |
* | Remove RTEMS_USE_GCC. | Ralf Corsepius | 2005-11-08 | 1 | -7/+0 |
| | | | | Remove RTEMS_GCC_PIPE. Remove RTEMS_GCC_SPECS. | ||||
* | Remove (Unused). | Ralf Corsepius | 2005-11-08 | 2 | -41/+0 |
* | 2005-11-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-08 | 1 | -0/+8 |
| | | | | | | | | * aclocal/env-rtemsbsp.m4: Merge RTEMS_BSP_SPECS and GCC_SPECS into GCCSPECS. * automake/compile.am: Remove RTEMS_BSP_SPECS, GCC_SPECS. Don't manually set up GCCSPEC (Now setup from inside configure). Remove RTEMS_RELLDFLAGS (Used). | ||||
* | Remove RTEMS_BSP_SPECS, GCC_SPECS. | Ralf Corsepius | 2005-11-08 | 1 | -8/+0 |
* | Merge RTEMS_BSP_SPECS and GCC_SPECS into GCCSPECS. | Ralf Corsepius | 2005-11-08 | 1 | -5/+4 |
* | 2005-11-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-08 | 1 | -0/+1 |
| | | | | * automake/compile.am: Remove CCAS support. | ||||
* | Remove CCAS support. | Ralf Corsepius | 2005-11-08 | 1 | -4/+0 |
* | 2005-11-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-08 | 1 | -0/+7 |
| | | | | | | | * aclocal/multilib.m4: Remove (Unused). * aclocal/check-multiprocessing.m4: Don't require RTEMS_ENABLE_MULTILIB. * aclocal/env-rtemsbsp.m4: Don't provide MULTILIB conditional. | ||||
* | Don't provide MULTILIB conditional. | Ralf Corsepius | 2005-11-08 | 1 | -2/+0 |
* | Don't require RTEMS_ENABLE_MULTILIB. | Ralf Corsepius | 2005-11-08 | 1 | -1/+0 |
* | Remove (Unused). | Ralf Corsepius | 2005-11-08 | 1 | -16/+0 |
* | Fixed formatting. | Joel Sherrill | 2005-11-07 | 1 | -1/+1 |
* | changes | Ralf Corsepius | 2005-11-07 | 1 | -0/+8 |
* | New. | Ralf Corsepius | 2005-11-07 | 1 | -0/+1 |
* | Remove | Ralf Corsepius | 2005-11-07 | 1 | -1/+0 |
* | Rename TEST to spsize. | Ralf Corsepius | 2005-11-07 | 1 | -1/+1 |
* | 2005-11-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-07 | 1 | -2/+7 |
| | | | | | | | | * Makefile.am: Remove noinst_HEADERS. Remove POSIX_FILES_DIRS, POSIX_FILES_DIRS. * psx13/Makefile.am, psxcancel/Makefile.am, psxchroot01/Makefile.am, psxfile01/Makefile.am, psxmount/Makefile.am, psxreaddir/Makefile.am, psxstat/Makefile.am: Add ../include/pmacros.h | ||||
* | Add ../include/pmacros.h | Ralf Corsepius | 2005-11-07 | 15 | -15/+15 |
* | 2005-11-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-07 | 1 | -0/+2 |
| | | | | | * aclocal/check-posix.m4: Sync with cpukit. * configure.ac: Sync POSIX and ITRON magic with cpukit. | ||||
* | Sync POSIX and ITRON magic with cpukit. | Ralf Corsepius | 2005-11-07 | 1 | -3/+3 |
* | Sync with cpukit. | Ralf Corsepius | 2005-11-07 | 1 | -13/+0 |
* | 2005-11-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-07 | 1 | -0/+5 |
* | Remove noinst_HEADERS. Remove POSIX_FILES_DIRS, POSIX_FILES_DIRS. | Ralf Corsepius | 2005-11-07 | 1 | -6/+2 |
* | Add ../include/pmacros.h | Ralf Corsepius | 2005-11-07 | 7 | -7/+7 |
* | Add spfatal to DIST_SUBDIRS. | Ralf Corsepius | 2005-11-07 | 1 | -3/+2 |
* | Add spfatal/Makefile. | Ralf Corsepius | 2005-11-07 | 1 | -0/+1 |
| | | | | | * aclocal/config-subdirs.m4, aclocal/path-ksh.m4, aclocal/quoting.m4, aclocal/tool-paths.m4: Remove. | ||||
* | Remove. | Ralf Corsepius | 2005-11-07 | 4 | -112/+0 |
* | Misc. bugfixes. | Ralf Corsepius | 2005-11-07 | 47 | -65/+35 |
* | * sp27/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, | Ralf Corsepius | 2005-11-07 | 1 | -0/+2 |
| | | | | sp30/Makefile.am, sp31/Makefile.am: Misc. bugfixes. | ||||
* | * mp01/Makefile.am, mp01/node1/Makefile.am, mp01/node2/Makefile.am, | Ralf Corsepius | 2005-11-07 | 1 | -0/+15 |
| | | | | | | | | | | | | | | | | | mp02/Makefile.am, mp02/node1/Makefile.am, mp02/node2/Makefile.am, mp03/Makefile.am, mp03/node1/Makefile.am, mp03/node2/Makefile.am, mp04/Makefile.am, mp04/node1/Makefile.am, mp04/node2/Makefile.am, mp05/Makefile.am, mp05/node1/Makefile.am, mp05/node2/Makefile.am, mp06/Makefile.am, mp06/node1/Makefile.am, mp06/node2/Makefile.am, mp07/Makefile.am, mp07/node1/Makefile.am, mp07/node2/Makefile.am, mp08/Makefile.am, mp08/node1/Makefile.am, mp08/node2/Makefile.am, mp09/Makefile.am, mp09/node1/Makefile.am, mp09/node2/Makefile.am, mp10/Makefile.am, mp10/node1/Makefile.am, mp10/node2/Makefile.am, mp11/Makefile.am, mp11/node1/Makefile.am, mp11/node2/Makefile.am, mp12/Makefile.am, mp12/node1/Makefile.am, mp12/node2/Makefile.am, mp13/Makefile.am, mp13/node1/Makefile.am, mp13/node2/Makefile.am, mp14/Makefile.am, mp14/node1/Makefile.am, mp14/node2/Makefile.am: Misc bugfixes. | ||||
* | 2005-11-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-07 | 2 | -2/+6 |
| | | | | * tmtests.am: Remove LIB_VARIANT. | ||||
| | | | | * tmitrontests.am: Remove LIB_VARIANT. | ||||
| | | | | * sptests.am: Remove LIB_VARIANT. | ||||
* | 2005-11-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-07 | 2 | -4/+8 |
| | | | | * sample.am: Remove LIB_VARIANT. | ||||
| | | | | * psxtests.am: Remove LIB_VARIANT. | ||||
| | | | | * mptests.am: Remove LIB_VARIANT. | ||||
| | | | | * libtests.am: Remove LIB_VARIANT. | ||||
| | | | | * itrontests.am: Remove LIB_VARIANT. | ||||
* | Cleanup | Ralf Corsepius | 2005-11-07 | 2 | -2/+2 |
* | Cleanup | Ralf Corsepius | 2005-11-07 | 9 | -27/+9 |
| | | | | | * automake/compile.am: Remove depend. * automake/local.am: Remove depend-am. | ||||
* | Remove depend-am. | Ralf Corsepius | 2005-11-07 | 1 | -3/+2 |
* | Remove depend. | Ralf Corsepius | 2005-11-07 | 1 | -2/+0 |
* | 2005-11-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-07 | 1 | -0/+1 |
| | | | | * automake/subdirs.am: Remove depend-recursive. | ||||
* | Remove depend-recursive. | Ralf Corsepius | 2005-11-07 | 1 | -4/+0 |
* | Cleanup | Ralf Corsepius | 2005-11-07 | 31 | -94/+31 |
* | Remove SRC, PRINT_SRC. | Ralf Corsepius | 2005-11-07 | 133 | -264/+0 |
