* | ada/sp19: Add m4 generated sptest.adb | Sebastian Huber | 2019-11-29 | 2 | -0/+2996 |
| | | | | Update #3818. | ||||
* | testsuites/ada: Introduce init.c files | Sebastian Huber | 2019-11-27 | 181 | -155/+155 |
| | | | | | | | Provide an init.c for each Ada test instead of the #include <config.h> magic which works only due to hand crafted include paths. Update #3818. | ||||
* | untar: Properly make parent path | Sebastian Huber | 2019-11-26 | 3 | -19/+19 |
| | | | | Close #3823. | ||||
* | libtests/dl*: Rename source files | Sebastian Huber | 2019-11-26 | 30 | -29/+29 |
| | | | | | | | | Rename source files to use a %.c -> %.o and %.cc -> %.o pattern. Use *.cc for C++ source files instead of *.cpp to be in line with other C++ source files. Update #3818. | ||||
* | libtests/dl*: Use rtems_tarfs_load() | Sebastian Huber | 2019-11-26 | 9 | -18/+18 |
| | | | | | Use rtems_tarfs_load() instead of Untar_FromMemory() to reduce the memory demands of the tests. | ||||
* | psxinttypes01: Remove invalid test cases | Sebastian Huber | 2019-11-26 | 3 | -30/+6 |
| | | | | | | The functions expect a valid string as input according to POSIX. On systems with a NULL pointer protection the test cases ended up in exceptions. | ||||
* | libtests: Use '-' for TAR file names | Sebastian Huber | 2019-11-25 | 4 | -29/+29 |
| | | | | | | | Use uniform pattern for all TAR file names. Use the dl* tests as a template. Update #3818. | ||||
* | libtests/dl*: Do not generate files via "echo" | Sebastian Huber | 2019-11-25 | 5 | -29/+18 |
| | | | | | | Add the static files to the repository. This simplifies the build. Update #3818. | ||||
* | libtests/tar0[12]:: Use static archive content | Sebastian Huber | 2019-11-25 | 4 | -20/+9 |
| | | | | | | | | This simplifies the build process. Do not generate the archive content through the build system. Let the version control system deal with symbolic links. Update #3818. | ||||
* | testsuite: Only include termios10/termios11 tests if compiled with POSIX | Hesham Almatary | 2019-11-21 | 1 | -0/+4 |
| | | | | Both need POSIX support | ||||
* | imfs: Add IMFS_make_linfile() | Sebastian Huber | 2019-11-19 | 1 | -31/+29 |
* | Remove BSP_SMALL_MEMORY BSP option | Sebastian Huber | 2019-11-15 | 2 | -8/+0 |
| | | | | | | Use the test state configuration instead. Update #3818. | ||||
* | testsuite/dl02: Fix bug to correctly check the handle of the second object file | Hesham Almatary | 2019-11-12 | 1 | -1/+1 |
* | riscv: preliminarily support for libdl | Hesham Almatary | 2019-11-12 | 1 | -1/+1 |
| | | | | Support for targets compiled with -fno-pic and -mno-relax | ||||
* | ada/mptests: Make them compile clean | Sebastian Huber | 2019-11-12 | 19 | -127/+195 |
| | | | | | | Fix all warnings. Update #3818. | ||||
* | sptests: Avoid include path magic | Sebastian Huber | 2019-11-12 | 29 | -111/+270 |
* | tests: Simplify fatal error test support | Sebastian Huber | 2019-11-12 | 7 | -191/+106 |
| | | | | | | Move system.h to shared init.c. Update #3818. | ||||
* | block08: Use local include | Sebastian Huber | 2019-11-12 | 14 | -14/+14 |
* | libtests: Remove superfluous include path | Sebastian Huber | 2019-11-12 | 1 | -2/+1 |
* | fstests: Use tmacros.h instead of pmacros.h | Sebastian Huber | 2019-11-12 | 16 | -17/+16 |
| | | | | | | This avoids an extra include path. Update #3818. | ||||
* | mptests: Avoid build system defined defines | Sebastian Huber | 2019-11-12 | 40 | -52/+104 |
* | ada/samples: Avoid build system defined defines | Sebastian Huber | 2019-11-12 | 4 | -8/+8 |
* | mptests/mp14: Make MAX_LONG_TEST_DURATION constant | Sebastian Huber | 2019-11-12 | 3 | -6/+8 |
| | | | | | | If there is a real need, it can be made a configuration option again. Update #3818. | ||||
* | tmtests: Avoid build system defined defines | Sebastian Huber | 2019-11-12 | 11 | -379/+395 |
* | samples/paranoia: Remove <bsp.h> include | Sebastian Huber | 2019-11-12 | 1 | -1/+0 |
| | | | | This include is superfluous. | ||||
* | samples: Avoid build system defined defines | Sebastian Huber | 2019-11-12 | 5 | -5/+13 |
* | libtests: Avoid build system defined defines | Sebastian Huber | 2019-11-12 | 20 | -609/+621 |
* | sptests: Remove obsolete semaphore consume driver | Sebastian Huber | 2019-11-12 | 3 | -75/+1 |
| | | | | | | This driver is no longer used by a test program. Update #3818. | ||||
* | spfatal16: Remove obsolete test program | Sebastian Huber | 2019-11-12 | 4 | -64/+1 |
| | | | | | The "TRrc" semaphore was removed in commit 2c12262f9a8fe7975556729f0574fab8d5a792f5. | ||||
* | sptests: Avoid build system defined defines | Sebastian Huber | 2019-11-12 | 25 | -980/+1010 |
* | psxtmtests: Avoid build system defined defines | Sebastian Huber | 2019-11-12 | 5 | -189/+193 |
* | psxtests: Avoid build system defined defines | Sebastian Huber | 2019-11-12 | 4 | -255/+241 |
* | tests: Remove superfluous SMPTESTS define | Sebastian Huber | 2019-11-12 | 3 | -17/+9 |
* | psxfenv01: Check FE_DIVBYZERO define | Sebastian Huber | 2019-11-12 | 1 | -0/+2 |
* | rtems-5: Improve heap fatal error information | sebastian.huber | 2019-11-05 | 2 | -1/+2 |
| | | | | Update #3806. | ||||
* | score: Add RTEMS_DEFINE_GLOBAL_SYMBOL_IN_SECTION() | Sebastian Huber | 2019-10-28 | 1 | -0/+7 |
| | | | | Update #3799. | ||||
* | ttest01: Check init/final run output | Sebastian Huber | 2019-10-11 | 1 | -0/+85 |
| | | | | Update #3199. | ||||
* | ttest01: Add test outputs all test cases | Mikail Yayla | 2019-10-11 | 15 | -0/+2880 |
* | ttest01: Add more test cases | Sebastian Huber | 2019-10-11 | 17 | -3/+4237 |
* | libtest: Do all output in test runner | Sebastian Huber | 2019-10-11 | 1 | -0/+4 |
| | | | | | | | | This ensures that lines are output atomically if they are produced by different other contexts, e.g. interrupts, other processors, other threads. Update #3199. | ||||
* | ttest01: Adjust SPDX-License-Identifier | Sebastian Huber | 2019-10-11 | 1 | -2/+7 |
* | termios: Add Capability to Generate SIGINTR and SIGQUIT | Joel Sherrill | 2019-10-08 | 7 | -1/+288 |
| | | | | | | | | | | | | | | This patch adds the ability for termios to send SIGINTR on receipt of VINTR and SIGQUIT for VKILL and return -1/EINTR from read() on a termios channel. Importantly, this patch does not alter the default behavior or force POSIX signal code in just because termios is used. The application must explicitly enable the POSIX behavior of generating a signal upon receipt of these characters. This is discussed in the POSIX standard: https://pubs.opengroup.org/onlinepubs/9699919799/basedefs/V1_chap11.html Closes #3800. | ||||
* | termios04/init.c: Remove dead copy of change_iflag() | Joel Sherrill | 2019-10-04 | 1 | -17/+0 |
* | score: Install timecounter according to quality | Sebastian Huber | 2019-10-02 | 1 | -22/+79 |
| | | | | | | This makes it possible to install higher quality timecounter in plug-and-play systems and helps to override the clock driver provided timecounter in some test scenarios. | ||||
* | score: Remove strange timecounter init step | Sebastian Huber | 2019-10-02 | 1 | -6/+6 |
| | | | | | The double call of the timecounter get method was added to FreeBSD in 2002 without a comment. It is not clear why this is needed. | ||||
* | score: Remove superfluous timecounter members | Sebastian Huber | 2019-10-02 | 1 | -2/+2 |
* | Revert "record: Add wrappers for malloc() functions" | Sebastian Huber | 2019-10-02 | 3 | -492/+230 |
| | | | | | | It was accidentally committed. This reverts commit a314544a278f1533ae001f742d7fe24fcee253e6. | ||||
* | libtests/ttest01: Fix typos | Sebastian Huber | 2019-10-02 | 1 | -3/+3 |
* | record: Add wrappers for malloc() functions | Sebastian Huber | 2019-10-01 | 3 | -230/+492 |
| | | | | | | | | | | Introduce new library librtemsrecordwrap.a which contains wrappers for operating system functions which produce entry/exit events. The wrappers can be selected during link time via the GNU ld --wrap option. Update #3665. | ||||
* | libtests/record01: Fix test failure | Sebastian Huber | 2019-10-01 | 1 | -2/+45 |
| | | | | Update #3665. |
