PR 1460/cpukit
* sp43/init.c: Change return type on methods accessing portions of
RTEMS Ids to int. This allows -1 to be return on error.
PR 1460/cpukit
* psx14/init.c: Change return type on methods accessing portions of
* block02/.cvsignore, block03/.cvsignore, block04/.cvsignore,
block05/.cvsignore, block06/.cvsignore, block07/.cvsignore: New files.
* block02/Makefile.in, block03/Makefile.in, block04/Makefile.in,
block05/Makefile.in, block06/Makefile.in, block07/Makefile.in: Removed.
* spsize/Makefile.am: Fix broken install rule.
* rtems++/Task3.cc: Use %zu instead of %i to print size_t's.
Remove bogus cast.
* rtems++/Task1.cc: Use %zu instead of %i to print size_t's.
* rtems++/Task1.cc: Eliminate more warnings.
* rtems++/Task1.cc, rtems++/Task2.cc: Spray PRI* macros to eliminate
several dozens of warnings.
* block06/init.c: Add missing prototype.
PR 1466/tests
* Makefile.am, configure.ac, psxclock/init.c, psxclock/psxclock.doc,
psxclock/psxclock.scn, psxkey03/init.c, psxsignal02/init.c,
psxsignal03/init.c, psxstack01/init.c: Remove usleep() from tests.
Add test specifically to test it since it is deprecated as of
POSIX.1-2008.
* psxusleep/.cvsignore, psxusleep/Makefile.am, psxusleep/init.c,
psxusleep/psxusleep.doc, psxusleep/psxusleep.scn: New files.
* psxcancel01/init.c: Initialize start time.
* support/include/tmacros.h: Add service to check status returned by
POSIX methods which return a pointer which is -1 on error. This
eliminated some casts.
* psxmsgq01/init.c, psxsem01/init.c: Add service to check status
returned by POSIX methods which return a pointer which is -1 on
error. This eliminated some casts.
* psxenosys/Makefile.am: Add documentation file.
* psxenosys/psxenosys.doc: New file.
* spprintk/spprintk.scn: Add end of line at end of file.
* sp32/Makefile.am, sp33/Makefile.am, sp37/Makefile.am,
sp38/Makefile.am, sp39/Makefile.am, sp43/Makefile.am,
sp44/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am,
spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am,
spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am,
spfatal09/Makefile.am, spobjgetnext/Makefile.am,
spprintk/Makefile.am, spsize/Makefile.am, spwatchdog/Makefile.am,
spwkspace/Makefile.am: Add documentation files for multiple tests.
* sp32/sp32.doc, sp33/sp33.doc, sp37/sp37.doc, sp38/sp38.doc,
sp39/sp39.doc, sp43/sp43.doc, sp44/sp44.doc, spfatal01/spfatal01.doc,
spfatal02/spfatal02.doc, spfatal03/spfatal03.doc,
spfatal04/spfatal04.doc, spfatal05/spfatal05.doc,
spfatal06/spfatal06.doc, spfatal07/spfatal07.doc,
spfatal08/spfatal08.doc, spfatal09/spfatal09.doc,
spobjgetnext/spobjgetnext.doc, spprintk/spprintk.doc,
spsize/spsize.doc, spwatchdog/spwatchdog.doc,
spwkspace/spwkspace.doc: New files.
* support/include/tmacros.h: Include rtems/score/thread.h.
Remove _Thread_Dispatch_disable_level.
* tmoverhd/testtask.c: Apply RTEMS_GCC_NOWARN_USED.
* tmoverhd/dumrtems.h: Rework undef/define cascade.
Add RTEMS_GCC_NOWARN_USED.
* tmoverhd/system.h: Add prototype for Empty_directive();
* psxsignal03/init.c:
Print sigval.sival_ptr instead of "union sigval".
* loopback/init.c: Adjust return-type of rtems_bsdnet_loopattach to
int to match with rtems/rtems_bsdnet.h.
* psxstat/test.c: Apply PRI* macros to print struct stat fields.
* psxreaddir/test.c: Apply PRI* macros to print struct stat fields.
* psxfile01/test.c: Remove obsure #ifdef's.
* support/include/tmacros.h: Add PRIxino_t, PRIdoff_t,
PRIxblksize_t, PRIxblkcnt_t.
Comment cleanups.
Comment cleanups.
* termios/init.c: Remove sh2 hacks.
* tm26/task1.c: Use true/false instead of TRUE/FALSE for "bool"s.
* tm15/task1.c: Make time_set a "bool".
Eliminate TRUE/FALSE.
* include/pmacros.h: Change TM_OCTOBER to 9, TM_NOVEMBER to 10,
TM_DECEMBER to 11 (tm_mon months start with JAN = 0).
* include/pmacros.h: November is the 11th month.
* itrontime01/init.c: Use %ld to print "time"s.
* mp03/task1.c, mp10/init.c, mp13/task1.c: Use
rtems_clock_get_ticks_per_second() instead of the obsoleted
TICKS_PER_SECOND.
* include/timesys.h: Use PRId32.
