2020-09-11 | Remove tmoverhd which existed to produce the obsolete coverhd.h | Joel Sherrill | 17 | -4638/+0 | |
Closes #4040. | |||||
2020-09-10 | spintrcritical08: Increase clock tick interval | Sebastian Huber | 1 | -1/+1 | |
On some simulators, a clock tick interval of 1ms seems to be too short. For example, the test failed on sparc/erc32 using the SIS. | |||||
2020-08-31 | score: Add <rtems/score/freechainimpl.h> | Sebastian Huber | 1 | -1/+1 | |
Hide implementation details. Update #3959. | |||||
2020-08-31 | rtems: Add _RTEMS_Name_to_id() | Sebastian Huber | 1 | -2/+2 | |
Simplify object name to identifier directives. Using _RTEMS_Name_to_id() to implement the directives enables a tail call optimization. Change license to BSD-2-Clause according to file history. Update #3053. | |||||
2020-08-21 | spintrcritical22: Use right thread wait flags | Sebastian Huber | 1 | -1/+1 | |
2020-08-21 | spintrcritical16: Use right thread wait flags | Sebastian Huber | 1 | -1/+1 | |
2020-08-21 | mp03: Include missing header file | Sebastian Huber | 1 | -0/+2 | |
2020-08-20 | spintrcritical23: Fix unused variable warnings | Sebastian Huber | 1 | -2/+2 | |
2020-08-20 | sp37: Fix unused variable warnings | Sebastian Huber | 1 | -0/+2 | |
2020-08-20 | psxkey01: Fix configuration | Aschref Ben Thabet | 1 | -1/+1 | |
Key_ID array must have the right size, it shall have a value greater than zero. Note: In Standard C and C++, zero-size array is not allowed.. | |||||
2020-08-18 | libtest: Add T_push_plan() and T_pop_plan() | Sebastian Huber | 2 | -2/+23 | |
Update #3199. | |||||
2020-08-18 | libtest: Change T_step() and T_assert_step() | Sebastian Huber | 3 | -12/+12 | |
Normally, the expected test step must be a compile time constant. Allow variable expected test steps for the T_step() and T_assert_step(). This can be used for parameterized test loops with individual fixtures. Remove the ability to use custom failure messages due to some implementation constraints. Update #3199. | |||||
2020-08-18 | libtest: Add fixture steps | Sebastian Huber | 3 | -21/+22 | |
Support a new test plan for each nested fixture. Update #3199. | |||||
2020-08-18 | libtest: Change fixture scope method | Sebastian Huber | 1 | -4/+4 | |
Return the produced character count. There is no need for a NUL termination. Update #3199. | |||||
2020-08-11 | spintrcritical23: Restore runner priority | Sebastian Huber | 1 | -0/+8 | |
2020-08-11 | libtests/dl10: Delete unused functions | Aschref Ben Thabet | 1 | -22/+0 | |
2020-08-11 | libtest: Add T_thread_switch_record() | Sebastian Huber | 1 | -0/+66 | |
Add support to record thread switch events. This can be used to check that a blocking operation results in the expected sequence of thread switches. Update #3199. | |||||
2020-08-06 | libtest: Fix T_interrupt_test() in SMP configs | Sebastian Huber | 1 | -0/+54 | |
2020-08-05 | psxhdrs/strncpy/stpncpy: Fix string turncation warning | Aschref Ben Thabet | 2 | -8/+6 | |
Since we need to test the strncpy function, using a character array with a fixed array size in this case in place of character pointer can avoid the string turncation warning. | |||||
2020-08-04 | smpschededf02: Document reset() function | Sebastian Huber | 1 | -1/+13 | |
2020-07-30 | psxhdrs/strncat: Fix string truncation warning | Aschref Ben Thabet | 1 | -1/+1 | |
2020-07-24 | spmisc01: Include missing header file | Sebastian Huber | 1 | -0/+2 | |
Update #4032. | |||||
2020-07-24 | score: Add RTEMS_WEAK | Sebastian Huber | 4 | -1/+108 | |
2020-07-23 | spintrcritical_support: Remove | Sebastian Huber | 2 | -224/+0 | |
This test support was replaced by T_interrupt_test() is no longer used. | |||||
2020-07-23 | spintrcritical24: Use T_interrupt_test() | Sebastian Huber | 3 | -39/+119 | |
2020-07-23 | spintrcritical23: Use T_interrupt_test() | Sebastian Huber | 3 | -44/+88 | |
2020-07-23 | spintrcritical22: Use T_interrupt_test() | Sebastian Huber | 3 | -40/+87 | |
2020-07-23 | spintrcritical21: Use T_interrupt_test() | Sebastian Huber | 4 | -140/+149 | |
2020-07-23 | spintrcritical20: Use T_interrupt_test() | Sebastian Huber | 3 | -59/+115 | |
2020-07-23 | spintrcritical18: Use T_interrupt_test() | Sebastian Huber | 3 | -49/+128 | |
2020-07-23 | spintrcritical16: Use T_interrupt_test() | Sebastian Huber | 3 | -60/+115 | |
2020-07-23 | spintrcritical15: Use T_interrupt_test() | Sebastian Huber | 3 | -54/+117 | |
2020-07-23 | spintrcritical13/14: Use T_interrupt_test() | Sebastian Huber | 4 | -67/+147 | |
2020-07-23 | spintrcritical11/12: Use T_interrupt_test() | Sebastian Huber | 4 | -51/+126 | |
2020-07-23 | spintrcritical10: Use T_interrupt_test() | Sebastian Huber | 3 | -126/+109 | |
2020-07-23 | spintrcritical09: Use T_interrupt_test() | Sebastian Huber | 3 | -50/+103 | |
2020-07-23 | spintrcritical08: Use T_interrupt_test() | Sebastian Huber | 3 | -83/+157 | |
2020-07-23 | spintrcritical06/spintrcritical07: Remove tests | Sebastian Huber | 9 | -242/+0 | |
These two tests check conditions which no longer exist in the thread queue implementation. The are obsolete since the change to use red-black trees for the priority queues. | |||||
2020-07-23 | spintrcritical01/2/3/4/5: Use T_interrupt_test() | Sebastian Huber | 8 | -104/+194 | |
2020-07-23 | psxintrcritical01: Use T_interrupt_test() | Sebastian Huber | 3 | -50/+121 | |
2020-07-23 | libtest: Add T_interrupt_test() | Sebastian Huber | 5 | -0/+232 | |
2020-07-23 | libtest: Make check message optional | Sebastian Huber | 2 | -2/+25 | |
This macro magic is in line with C11 and C++11, but limits the maximum count of arguments. Update #3199. | |||||
2020-07-23 | libtest: Add push/pop fixture support | Sebastian Huber | 2 | -9/+100 | |
2020-07-23 | libtest: Support custom scope messages via fixture | Sebastian Huber | 2 | -9/+17 | |
2020-07-23 | libtest: Add T_get_one_clock_tick_busy() | Sebastian Huber | 1 | -1/+1 | |
2020-07-23 | libtest: Add T_busy() | Sebastian Huber | 1 | -1/+2 | |
2020-07-23 | libtest: Move <t.h> to <rtems/test.h> | Sebastian Huber | 19 | -19/+19 | |
2020-07-23 | libtest: <rtems/test.h> to <rtems/test-info.h> | Sebastian Huber | 65 | -65/+65 | |
Rename this header file to later move <t.h> to <rtems/test.h>. The main feature provided by <rtems/test-info.h> is the output of standard test information which is consumed by the RTEMS Tester. Update #3199. | |||||
2020-07-14 | rtems: Remove deprecated rtems_io_lookup_name() | Sebastian Huber | 1 | -21/+0 | |
Close #3420. | |||||
2020-06-30 | Change version to RTEMS 6 | Sebastian Huber | 1 | -2/+2 | |
Update #4020. |
