path: root/testsuites (follow)
* 2000-11-17 Jennifer Averett <jennifer@OARcorp.com>Jennifer Averett2000-11-201-0/+14
| | | | | | | | | | | | | | * psxstat/test.c, psxstat/psxstat.scn: Forced inode numbers to remain consistant across platforms and bsps by forcing a mount point in front of all paths. 2000-11-17 Jennifer Averret <jennifer@OARcorp.com> * psxmount/test.c, psxmount/psxmount.scn: Improve output to report expected error condition in one case. * psxreaddir/test.c, psxreaddir.scn: Added test cases to exercise readdir() of root of mounted filesystem. Also corrected the screen file for some mistakes noticed in this effort.
* 2000-11-17 Jennifer Averret <jennifer@OARcorp.com>Jennifer Averett2000-11-202-17/+16
* 2000-11-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-202-0/+6
| | | | * itrontask01/system.h: Configure enough stack memory.
* 2000-11-17 Jennifer Averret <jennifer@OARcorp.com>Jennifer Averett2000-11-172-290/+267
* 2000-11-17 Jennifer Averret <jennifer@OARcorp.com>Jennifer Averett2000-11-174-81/+143
* 2000-11-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-153-2/+6
| | | | * psxmount/psxmount.scn, psxmount/test.c: Correct spelling.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-0924-12/+60
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-021-0/+4
| | | | * stubdr/Makefile.am: Replace leaf.cfg w/ automake/lib.am.
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-0224-12/+60
* 2000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-012-1/+7
| | | | | | * malloctest/task1.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>.
* 2000-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-312-1/+9
| | | | | | | | * POSIX include files merged into newlib. This resulted in some definitions moving to other files and thus some secondary effects in RTEMS source code. * paranoia/paranoia.c: Commented out incorrect and conflicting prototype of read().
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-276-3/+18
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-273-2/+8
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * itrontests.am: Remove DEFS.
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * libtests.am: Remove DEFS.
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * mptests.am: Remove DEFS.
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * psxtests.am: Remove DEFS.
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * sample.am: Remove DEFS.
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * sptests.am: Remove DEFS.
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * tmitrontests.am: Remove DEFS.
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * tmtests.am: Remove DEFS.
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-272-1/+8
| | | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * configure.in: Replace AC_CONFIG_SUBDIRS with RTEMS_CONFIG_BUILD_SUBDIRS.
* 2000-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-253-0/+7
| | | | | * psxmount/test.c, psxstat/test.c: Include <imfs.h> to get IMFS_ops. It was formerly incorrectly prototyped in <libio.h>.
* 2000-09-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-293-5/+19
| | | | | * sp20/sp20.scn: Corrected to reflect new addition. * sp20/system.h: Removed comment reflecting history.
* 2000-09-29 Stephan Merker <merker@decrc.abb.de>Joel Sherrill2000-09-295-13/+64
| | | | | | * sp20/getall.c, sp20/init.c, sp20/system.h, sp20/task1.c: Added new task to test sequence of altering a period's length while it is still active.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+4
| | | | * stubdr/Makefile.am, wrapup/Makefile.am: Include compile.am
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-0510-0/+16
| | | | | | | * base_mp/node1/Makefile.am, base_mp/node2/Makefile.am, base_sp/Makefile.am, cdtest/Makefile.am, hello/Makefile.am, minimum/Makefile.am, paranoia/Makefile.am, ticker/Makefile.am, unlimited/Makefile.am: Include compile.am
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-052-0/+5
| | | | * tmitronsem01/Makefile.am: Include compile.am
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-0524-0/+34
| | | | | | | | | | | * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psxcancel/Makefile.am, psxfile01/Makefile.am, psxhdrs/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxreaddir/Makefile.am, psxsem01/Makefile.am, psxstat/Makefile.am, psxtime/Makefile.am, psxtimer/Makefile.am: Include compile.am
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-059-0/+14
| | | | | | * cpuuse/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am, termios/Makefile.am: Include compile.am
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-0510-0/+17
| | | | | | | | * itronhello/Makefile.am, itronmbf01/Makefile.am, itronmbox01/Makefile.am, itronsem01/Makefile.am, itrontask01/Makefile.am, itrontask02/Makefile.am, itrontask03/Makefile.am, itrontask04/Makefile.am, itrontime01/Makefile.am: Include compile.am
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-0529-0/+45
| | | | | | | | | | | | | | | | | * mp01/node1/Makefile.am, mp01/node2/Makefile.am, mp02/node1/Makefile.am, mp02/node2/Makefile.am, mp03/node1/Makefile.am, mp03/node2/Makefile.am, mp04/node1/Makefile.am, mp04/node2/Makefile.am, mp05/node1/Makefile.am, mp05/node2/Makefile.am, mp06/node1/Makefile.am, mp06/node2/Makefile.am, mp07/node1/Makefile.am, mp07/node2/Makefile.am, mp08/node1/Makefile.am, mp08/node2/Makefile.am, mp09/node1/Makefile.am, mp09/node2/Makefile.am, mp10/node1/Makefile.am, mp10/node2/Makefile.am, mp11/node1/Makefile.am, mp11/node2/Makefile.am, mp12/node1/Makefile.am, mp12/node2/Makefile.am, mp13/node1/Makefile.am, mp13/node2/Makefile.am, mp14/node1/Makefile.am, mp14/node2/Makefile.am: Include compile.am
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-0532-0/+45
| | | | | | | | | | | | | | * tm01/Makefile.am, tm02/Makefile.am, tm03/Makefile.am, tm04/Makefile.am, tm05/Makefile.am, tm06/Makefile.am, tm07/Makefile.am, tm08/Makefile.am, tm09/Makefile.am, tm10/Makefile.am, tm11/Makefile.am, tm12/Makefile.am, tm13/Makefile.am, tm14/Makefile.am, tm15/Makefile.am, tm16/Makefile.am, tm17/Makefile.am, tm18/Makefile.am, tm19/Makefile.am, tm20/Makefile.am, tm21/Makefile.am, tm22/Makefile.am, tm23/Makefile.am, tm24/Makefile.am, tm25/Makefile.am, tm26/Makefile.am, tm27/Makefile.am, tm28/Makefile.am, tm29/Makefile.am, tmck/Makefile.am, tmoverhd/Makefile.am: Include compile.am
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-0530-0/+42
| | | | | | | | | | | | | * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, spfatal/Makefile.am, spsize/Makefile.am: Include compile.am
* 2000-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-0117-16/+25
| | | | | | | | | | * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psxcancel/Makefile.am, psxmsgq01/Makefile.am, psxsem01/Makefile.am, psxsem01/Makefile.am, psxtimer/Makefile.am: Use AM_CPPFLAGS += instead of AM_CPPFLAGS =
* Adding ChangeLogs.Joel Sherrill2000-08-1012-0/+34
* Added ifdef on C4x to avoid invalid address alignment checks since thereJoel Sherrill2000-07-263-0/+28
| | | | is no such thing on the C4x.
* Port of RTEMS to the Texas Instruments C3x/C4x DSP families includingJoel Sherrill2000-07-262-0/+17
| | | | | | | | | | | a BSP (c4xsim) supporting the simulator included with gdb. This port was done by Joel Sherrill and Jennifer Averett of OAR Corporation. Also included with this port is a space/time optimization to eliminate FP context switch management on CPUs without hardware or software FP. An issue with this port was that sizeof(unsigned32) = sizeof(unsigned8) on this CPU. This required addressing alignment checks and assumptions as well as fixing code that assumed sizeof(unsigned32) == 4.
* Switch logical in conditional.Joel Sherrill2000-07-131-1/+1
* Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-1338-60/+76
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_TEST_NO_PAUSE a tests/ subpackage specific option. - Remove RTEMS_TEST_NO_PAUSE from custom/*.cfg, targopts.h and cpuopts.h. - Add autoconf macros RTEMS_*_RTEMS_TEST_NO_PAUSE (aclocal/rtems-test-no-pause.m4). - Add RTEMS_*_RTEMS_TEST_NO_PAUSE support to sptests/configure.ins and tmtests/configure.in. These are the only subdirectories which currently apply RTEMS_TEST_NO_PAUSE. - Add autoconf-DEFS support to all test subpackages' configure.ins below tests/. I.e. AC_DEFINES now get explicitly propagated as preprocessor defines into Makefiles, cf. AM_CPPFLAGS in tests/*/*.am, instead of using a global config-files. - Remove NDEBUG from custom/*.cfg. * AC_DEFINE POSIX_API, ITRON_API and MULTIPROCESSING in exec/configure.in, only. - All other sources now should relay on the values from cpuopts.h and should not define them themselves. - Several related changes to many configure.ins * Bug-fixes to RTEMS_*_RTEMS_DEBUG macros (Actually workarounds to quoting bugs in autoconf). Notes: * This patch is rather immature and only tested for a small subset of BSPs (requires the tests to be enabled and therefore takes an tremendous amount of disc space and time.) * The patches to *cfg were generated by a script. Expect file formating changes :)
* Patch rtems-rc-20000702-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-031-7/+15
| | | | | that is a hack to workaround a switch generation compiler bug for the SH2 and cleaned up some warnings.
* Thread iterate not ready for submission -- removed.Joel Sherrill2000-06-141-1/+1
* Patch from John Cotton <john.cotton@nrc.ca>, Charles-Antoine GauthierJoel Sherrill2000-06-123-2/+8
| | | | | | | | | | | | | | | <charles.gauthier@iit.nrc.ca>, and Darlene A. Stewart <Darlene.Stewart@nrc.ca> to add support for a number of very significant things: + BSPs for many variations on the Motorola MBX8xx board series + Cache Manager including initial support for m68040 and PowerPC + Rework of mpc8xx libcpu code so all mpc8xx CPUs now use same code base. + Rework of eth_comm BSP to utiltize above. John reports this works on the 821 and 860
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-12300-1161/+2529
* New file.Joel Sherrill2000-05-241-0/+0
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-13169-0/+472
| | | | adds .cvsignore.
* Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-082-2/+2
* Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-31138-139/+0
| | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams).
* Patch from Eric Norum <eric@cls.usask.ca> to implement this:Joel Sherrill2000-01-211-14/+12
| | | | | | | | | | | | | | | | | | | | I'd like to propose a change to RTEMS task variables that I think would make them more useful. I think that it is early enough in their existence to still make changes to their API. 1) Change type from `int' to `void *'. 2) Add extra argument to task_variable_add -- if non-NULL, a pointer to a `destructor' function to be called when the task exits. This function would be called with that task's value of the task variable as its argument. In many cases, the `dtor' function could be `free'. rtems_status_code rtems_task_variable_add ( rtems_id tid, void **ptr, void (*dtor)(void *)); rtems_status_code rtems_task_variable_delete (rtems_id tid, void **ptr); This would be all we'd need to cleanly and efficiently support C++ per-thread exception information without dragging in all that POSIX API stuff.
* Updated to reflect final test output.Joel Sherrill2000-01-141-3/+15
* Updated screen to reflect final test output.Joel Sherrill2000-01-141-24/+114
