path: root/testsuites (follow)
* Adapt to modified shell configurationThomas Doerfler2009-02-272-2/+6
* 2009-02-11 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-02-112-1/+8
| | | | * stackchk/stackchk.scn: Correct screen to match output.
* 2009-01-30 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-01-308-2/+160
| | | | | | | | * Makefile.am, configure.ac: Add sp48 which tests that configuring for unlimited objects when configured for a unified workspace works as expected. * sp48/.cvsignore, sp48/Makefile.am, sp48/init.c, sp48/sp48.doc, sp48/sp48.scn: New files.
* 2009-01-21 Nickolay Kolchin <nbkolchin@gmail.com>Joel Sherrill2009-01-218-1/+135
| | | | | | | Joel Sherrill <joel.sherrill@oarcorp.com> PR 1357/cpukit * rtems/src/tasks.c: Ensure creating a task with no ASR is honored.
* 2009-01-16 Jennifer Averett <jennifer.averett@OARcorp.com>Jennifer Averett2009-01-1611-2/+409
| | | | | | | | * Makefile.am, configure.ac: Add new test to test Watchdog display helper routines. These reach into the SuperCore. * spwatchdog/.cvsignore, spwatchdog/Makefile.am, spwatchdog/delay.c, spwatchdog/init.c, spwatchdog/prtime.c, spwatchdog/spwatchdog.scn, spwatchdog/system.h, spwatchdog/task1.c: New files.
* 2009-01-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-01-052-1/+5
| | | | * sp30/task1.c: Cast pointer to id as "void *" rather than task Id.
* 2009-01-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-01-057-14/+30
| | | | | | * sp09/screen05.c, sp09/screen07.c, sp09/screen10.c, sp09/screen11.c, sp09/screen12.c, sp09/screen14.c: Use rtems_build_id rather than hard-coded hex numbers for bad object Ids.
* 2009-01-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-01-053-3/+9
| | | | | | * sp15/system.h, sp19/system.h: Array of task names should be of type rtems_name not rtems_id. Similarly array of task ids should be rtems_id not rtems_name.
* 2009-01-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-01-052-1/+6
| | | | | * include/timesys.h: Array of task names should be of type rtems_name not rtems_id.
* 2009-01-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-01-053-4/+9
| | | | | | * psxmsgq02/init.c, psxmsgq02/psxmsgq02.scn: Open the message queue with create option so we are sure it will get a control block and proceed to allocate other memory. Clean up screen output.
* Remove tic4x.Ralf Corsepius2008-12-221-4/+0
* 2008-12-22 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-12-221-0/+4
| | | | * aclocal/canonical-target-name.m4: Remove tic4x.
* 2008-12-18 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-182-4/+8
| | | | * capture/test1.c: Add const to eliminate warning.
* 2008-12-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-162-1/+4
| | | | * spsize/size.c: Eliminate _TOD_Microseconds_per_tick.
* 2008-12-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-162-1/+5
| | | | * capture/test1.c: Eliminate all public use of TOD conversion routines.
* 2008-12-15 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-1512-95/+57
| | | | | | | | | | | | | | * Makefile.am, configure.ac, spfatal06/testcase.h, spfatal07/testcase.h, spfatal08/testcase.h, spfatal09/testcase.h, spsize/size.c: Eliminate pointers to API configuration tables in the main configuration table. Reference the main configuration table and the API configuration tables directly using the confdefs.h version rather than obtaining a pointer to it. This eliminated some variables, a potential fatal error, some unnecessary default configuration structures. Overall, about a 4.5% reduction in the code size for minimum and hello on the SPARC. * spfatal10/.cvsignore, spfatal10/Makefile.am, spfatal10/spfatal10.scn, spfatal10/testcase.h: Removed.
* 2008-12-15 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-152-1/+7
| | | | | | * malloctest/init.c: Change sizes of heap/region and allocated objects in heap to intptr_t so they can be larger than a single allocatable object (e.g. size_t).
* 2008-12-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-142-1/+5
| | | | * psx05/init.c: Add parameter to call to sched_get_priority_max().
* 2008-12-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-142-2/+13
| | | | | | | | | | * unlimited/init.c: Run all tests successfully with maxixum number of priorities as 16 instead of 256. This was done by temporarily modifying the score priority.h maximum. This allowed testing of all API code to ensure that it worked properly with a reduced number of priorities. Most modifications were to switch from hard-coded maximum to using the API provided methods to determine maximum number of priority levels.
* 2008-12-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-146-30/+72
| | | | | | | | | | * psx05/init.c, psx07/init.c, psx09/init.c, psx11/init.c, psx12/init.c: Run all tests successfully with maxixum number of priorities as 16 instead of 256. This was done by temporarily modifying the score priority.h maximum. This allowed testing of all API code to ensure that it worked properly with a reduced number of priorities. Most modifications were to switch from hard-coded maximum to using the API provided methods to determine maximum number of priority levels.
* 2008-12-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-142-3/+15
| | | | | | | | | | * itrontask04/init.c: Run all tests successfully with maxixum number of priorities as 16 instead of 256. This was done by temporarily modifying the score priority.h maximum. This allowed testing of all API code to ensure that it worked properly with a reduced number of priorities. Most modifications were to switch from hard-coded maximum to using the API provided methods to determine maximum number of priority levels.
* 2008-12-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-1429-178/+227
| | | | | | | | | | | | | | | * tm01/task1.c, tm02/task1.c, tm03/task1.c, tm04/task1.c, tm05/task1.c, tm06/task1.c, tm07/task1.c, tm08/task1.c, tm09/task1.c, tm10/task1.c, tm11/task1.c, tm12/task1.c, tm13/task1.c, tm14/task1.c, tm16/task1.c, tm17/task1.c, tm18/task1.c, tm19/task1.c, tm20/task1.c, tm21/task1.c, tm23/task1.c, tm24/task1.c, tm25/task1.c, tm26/task1.c, tm27/task1.c, tm28/task1.c, tm29/task1.c, tmoverhd/testtask.c: Run all tests successfully with maxixum number of priorities as 16 instead of 256. This was done by temporarily modifying the score priority.h maximum. This allowed testing of all API code to ensure that it worked properly with a reduced number of priorities. Most modifications were to switch from hard-coded maximum to using the API provided methods to determine maximum number of priority levels.
* 2008-12-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-1413-30/+61
| | | | | | | | | | | | * sp07/init.c, sp12/init.c, sp12/pridrv.c, sp12/pritask.c, sp12/system.h, sp16/system.h, sp25/system.h, sp26/task1.c, sp28/init.c, sp29/init.c, sp35/priinv.c, sp42/init.c: Run all tests successfully with maxixum number of priorities as 16 instead of 256. This was done by temporarily modifying the score priority.h maximum. This allowed testing of all API code to ensure that it worked properly with a reduced number of priorities. Most modifications were to switch from hard-coded maximum to using the API provided methods to determine maximum number of priority levels.
* 2008-12-09 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-092-2/+40
| | | | | * fileio/init.c: Add explicit creation of /etc/passwd and /etc/group so we have a test case for real password checking.
* 2008-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-083-3/+18
| | | | | * psxtimer01/psxtimer.c, psxtimer02/psxtimer.c: Obtain TOD with clock_gettime() NOT by reaching into the SuperCore.
* 2008-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-082-1/+5
| | | | * tm26/task1.c: Fix typo.
* 2008-12-04 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-042-0/+9
| | | | * sp46/sp46.scn: Add screen missed earlier.
* 2008-12-04 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-048-2/+185
| | | | | | | | PR 1348/cpukit * Makefile.am, configure.ac: Add test of special case of resetting cpu usage information while a period is running. * sp46/.cvsignore, sp46/Makefile.am, sp46/init.c, sp46/sp46.doc, sp46/sp46.scn: New files.
* 2008-12-03 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-032-0/+130
| | | | * sp45/init.c: New file.
* 2008-12-03 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-12-0310-4/+81
| | | | | | | | | PR 1347/cpukit * Makefile.am, configure.ac, sp30/resume.c, sp30/task1.c, sp31/delay.c: Rework Timer Server to ensure that the context allows for blocking, allocating memory, and acquiring semaphores and mutexes. * sp45/.cvsignore, sp45/Makefile.am, sp45/sp45.doc, sp45/sp45.scn: New files.
* 2008-11-25 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-11-252-1/+12
| | | | | * sp25/system.h: Add warning and temporary m32c conditional until size type addressed.
* 2008-11-24 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-11-242-22/+28
| | | | * paranoia/paranoia.c: Add missing prototypes.
* 2008-10-28 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-10-283-2/+9
| | | | * tm22/system.h, tm22/task1.c: Account for message buffers used.
* 2008-10-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-10-142-2/+22
| | | | | * malloctest/init.c: Do not generate alignment factors larger that will not fit in a native integer.
* 2008-10-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-10-147-14/+47
| | | | | | | | | | | * sp09/screen07.c: Use INT_MAX as number of messages so always properly sized and no overflow on constant. * sp09/screen10.c: Delay so on targets with simulator idle clock tick driver this will work. * sp09/screen11.c, sp09/system.h: Move badly aligned objects to odd byte boundaries rather than two byte boundaries. * sp09/screen03.c, sp09/screen14.c: Skip tests which try to allocate more memory than size_t holds on m32c.
* 2008-10-13 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-10-132-1/+5
| | | | * unlimited/system.h: Tighten configuration for stack space.
* Fix up ChangeLog.Ralf Corsepius2008-10-031-0/+4
* 2008-10-02 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-10-022-0/+7
| | | | | * fileio/init.c: When USE_SHELL not defined, do not attempt to configure shell.
* 2008-10-02 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-10-022-2/+6
| | | | * unlimited/system.h: 10000 task ids is too many for some targets.
* 2008-10-02 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-10-023-6/+12
| | | | | * include/timesys.h: Use inttypes.h. * tmck/task1.c: Use uint32_t for count.
* 2008-10-02 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-10-0210-22/+34
| | | | | | | | | * sp09/screen01.c, sp09/screen12.c, sp25/system.h, sp25/task1.c, sp28/init.c, sp39/init.c, sp41/init.c, spfatal01/testcase.h, spfatal08/testcase.h: Change size_t to ssize_t on all Heap, Workspace and Region calls. On 16-bit architectures, size_t can be 16-bits which would limit sizes to 64K. Also address constants which overflowed on 16-bit integer targets.
* 2008-10-01 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-10-012-1/+5
| | | | * psx01/psx01.scn: Bump version to 4.9.99.0
| | | | * sp43/sp43.scn: Bump version to 4.9.99.0
* 2008-09-22 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-222-2/+7
| | | | | * aclocal/version.m4: Bump RTEMS_API to 4.10. Bump _RTEMS_VERSION to 4.9.99.0.
* 2008-09-18 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-182-1/+7
| | | | | | * unlimited/system.h: Support up to 10K tasks in loop. With 64MB on pc386 and configured for unified workspace, you can get close to this.
* 2008-09-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-174-2/+12
| | | | | * include/timesys.h: Rename STACK_CHECKER_ON to more appropriate CONFIGURE_STACK_CHECKER_ENABLED.
* 2008-09-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-172-1/+6
| | | | | * fileio/system.h: Rename STACK_CHECKER_ON to more appropriate CONFIGURE_STACK_CHECKER_ENABLED.
| | | | | * stackchk/system.h: Rename STACK_CHECKER_ON to more appropriate CONFIGURE_STACK_CHECKER_ENABLED.
* 2008-09-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-173-0/+22
| | | | | | * minimum/init.c, unlimited/system.h: Add support for optionally having a unified work area. In other words, the RTEMS Workspace and C Program Heap are the same pool of memory.
* 2008-09-17 Miao Yan <yanmiaobest@gmail.com>Joel Sherrill2008-09-174-4/+12
| | | | | | | | * hello/system.h, minimum/Makefile.am, minimum/init.c: Merge GSOC project code to add simple device only filesystem (devfs), optionally completely drop out filesystem, and to clean up disabling newlib reentrancy support. This dropped 17K from the minimum.exe for sparc/sis and arm/rtl22xx_t now has a 15K code space.
