PR 1629/cpukit
* psx04/init.c: sigsuspend() was not completely following the POSIX
specification.
PR 1631/testing
* gxx02/init.c, gxx02/gxx02.scn, gxx02/gxx02.doc,
gxx02/Makefile.am, gxx02/gxx_wrappers.h: New test added
* Makefile.am, configure.ac: Changes to accommodate new tests
PR 1632/testing
* Makefile.am, configure.ac: Make dedicated fatal error test for
/dev/null already registered. Using code from Bharath in new test
framework.
* devnullfatal01/.cvsignore, devnullfatal01/Makefile.am,
devnullfatal01/devnullfatal01.doc, devnullfatal01/devnullfatal01.scn,
devnullfatal01/testcase.h: New files.
PR 1632/testing
* devfs04/init.c, devfs04/test_driver.c: Added cases to exercise
null_initialize() and null_write().
* Makefile.am, configure.ac: Add test to extract a task blocked with
timeout on a priority ordered thread queue.
* sp72/.cvsignore, sp72/Makefile.am, sp72/init.c, sp72/sp72.doc,
sp72/sp72.scn: New files.
* gxx01/gxx01.scn, gxx01/init.c: Remove local _exit().
* gxx01/gxx01.scn, gxx01/init.c: Add test f0r rtems_gxx_key_dtor().
* gxx01/gxx01.scn, gxx01/init.c: Add more testcases.
* devfs02/init.c, devfs02/devfs02.doc, devfs02/devfs02.scn,
devfs02/Makefile.am: New tests added
* devfs03/init.c, devfs03/devfs03.doc, devfs03/devfs03.scn,
devfs03/Makefile.am: New tests added
* devfs04/init.c, devfs04/devfs04.doc, devfs04/devfs04.scn,
devfs04/Makefile.am: New tests added
* Makefile.am, configure.ac: Changes to accommodate the above
newly added tests.
* Makefile.am, configure.ac, termios06/init.c: Add initial tests for
XON/XOFF and VMIN/VMAX cases.
* termios07/.cvsignore, termios07/Makefile.am, termios07/init.c,
termios07/termios07.doc, termios07/termios07.scn,
termios08/.cvsignore, termios08/Makefile.am, termios08/init.c,
termios08/termios08.doc, termios08/termios08.scn: New files.
PR 1623/testing
* psx13/test.c, psx13/psx13.scn: New cases to improve coverage of
utime() and fpathconf().
* psxfile01/test.c, psxfile01/psxfile01.scn: New cases to improve
coverage of rmdir(), unlink(), mknod(), link(), open(), read(),
write().
* psxstat/test.c, psxstat/psxstat.scn: New case to improve
coverage of readlink().
* Makefile.am, configure.ac: Add tar test for error cases.
* tar03/.cvsignore, tar03/Makefile.am, tar03/init.c, tar03/tar03.doc,
tar03/tar03.scn: New files.
* stringto01/init.c, stringto01/stringto01.scn,
stringto01/stringto_test_template.h: Attempt to pick up a few more
error paths.
PR 1622/testing
* psxchroot01/test.c, psxchroot01/psxchroot01.scn: Added two test
cases to completely cover chroot().
PR 1617/testing
* spmountmgr01/init.c, spmountmgr01/spmountmgr01.scn,
spmountmgr01/spmountmgr01.doc: Added cases to exercise
mount-mktgt.c.
* psxfile01/test.c: Avoid NULL pointer access.
PR 1617/testing
* psxfile01/test.c, psxfile01/psxfile01.scn: Added new cases to
exercise_link_r and _unlink_r
* psxstat/test.c, psxstat/psxstat.scn: Added new cases to exercise
_lstat_r and _stat_r.
* psxtime/test.c, psxtime/psxtime.scn: Added new cases to exercise
_gettimeofday.
PR 1617/testing
* malloctest/init.c: Added new case to exercise _realloc_r.
PR 1617/testing
* spmountmgr01/init.c, spmountmgr01/Makefile.am,
spmountmgr/.cvsignore, spmountmgr01/spmountmgr01.doc,
spmountmgr01/spmountmgr01.scn: New test which improves coverage
of mount-mgr.c under libcsupport.
* Makefile.am, configure.ac: Changes to accommodate the new test.
* malloctest/init.c: Added test for
rtems_heap_allocate_aligned_with_boundary().
* psxstat/test.c: Avoid NULL pointer access.
* Makefile.am, configure.ac: Add new test to exercise devFS_Show().
* devfs01/.cvsignore, devfs01/Makefile.am, devfs01/devfs01.doc,
devfs01/devfs01.scn, devfs01/init.c: New files.
malloc_get_statistics().
* malloc05/.cvsignore, malloc05/Makefile.am, malloc05/init.c,
malloc05/malloc05.doc, malloc05/malloc05.scn: New files.
PR 1535/tests
* malloc04/init.c, malloc04/malloc04.scn: Address issues in test. A mix
of work by Ralf and Joel.
* spprintk/init.c, spprintk/spprintk.doc, spprintk/spprintk.scn: Clean
up and add test of getchark().
* spfatal21/Makefile.am: Fix typo.
* support/include/test_support.h, support/src/test_support.c: Add
Allocate_majority_of_heap().
* Makefile.am, configure.ac: Add tests for sbrk fatal error case and
libio initialization fatal error case.
* spfatal21/.cvsignore, spfatal21/Makefile.am, spfatal21/spfatal21.doc,
spfatal21/spfatal21.scn, spfatal21/testcase.h, spfatal22/.cvsignore,
spfatal22/Makefile.am, spfatal22/spfatal22.doc,
spfatal22/spfatal22.scn, spfatal22/testcase.h: New files.
* termios01/init.c, termios01/termios01.scn: Fully exercise tcsetattr.
* spintrcritical06/init.c: Switch semaphore obtain timeouts of
variants. Cleanup.
* spintrcritical05/spintrcritical05.scn,
spintrcritical06/spintrcritical06.scn,
spintrcritical07/spintrcritical07.scn,
spintrcritical11/spintrcritical11.scn,
spintrcritical12/spintrcritical12.scn,
spintrcritical13/spintrcritical13.scn,
spintrcritical14/spintrcritical14.scn: Update.
PR 1613/testing
* psxfchx01/init.c, psxfchx01/Makefile.am, psxfchx01/.cvsignore,
psxfchx01/psxfchx01.doc, psxfchx01/psxfchx01.scn: New
tests. Improves coverage of fchdir, fchmod, fchown directives.
* configure.ac, Makefile.am: Changes to accommodate new test.
* psxstat/test.c, psxstat/psxstat.scn: Added new test case to test
statvfs routine under libcsupport.
PR 1610/testing
* psx13/test.c, psx13/psx13.scn: Remove the test cases which
exercise pipe. These are new a new test under psxpipe01/
* psxpipe01/init.c, psxpipe01/Makefile.am,
psxpipe01/psxpipe01.scn, psxpipe01/psxpipe01.doc: Added new test.
* Makefile.am, configure.ac: Changes due to addition of new test:
psxpipe01.
* Makefile.am, configure.ac: Add test for exercising sbrk() extension
to Malloc Family.
* malloc04/.cvsignore, malloc04/Makefile.am, malloc04/init.c,
malloc04/malloc04.doc, malloc04/malloc04.scn: New files.
* Makefile.am, configure.ac: Readd spfatal09 as a malloc initialization
fatal error.
* spfatal09/.cvsignore, spfatal09/Makefile.am, spfatal09/spfatal09.doc,
spfatal09/spfatal09.scn, spfatal09/testcase.h: New files.
PR 1608/testing
* psxfile01/init.c: Add a simple test case: Open file as read-only
and attemp to truncate. Improves coverage.
PR 1603/testing
* spassoc01/init.c, spassoc01/Makefile.am,
spassoc01/spassoc01.doc, spassoc01/spassoc01.scn: Added new test.
* Makefile.am, configure.ac: Added new test spassoc01 for
rtems_assoc routines.
PR 1606/cpukit
* psxfatal_support/init.c: Remove
INTERNAL_ERROR_INVALID_WORKSPACE_ADDRESS since it is not generated.
PR 1606/cpukit
* spfatal_support/init.c: Remove
* minimum/init.c: Use fatal error extension to prevent infinite
runtime.
* psxfatal_support/init.c: Print end of test message in case of
success. Stop multitasking in the fatal error extension.
* psxfatal01/psxfatal01.scn, psxfatal02/psxfatal02.scn: Update.
spfatal09/spfatal09.doc, spfatal09/spfatal09.scn,
spfatal09/testcase.h: Removed files.
* Makefile.am, configure.ac: Reflect changes above.
* spfatal_support/init.c: Print end of test message in case of
* spfatal03/testcase.h, spfatal07/testcase.h: Use printk() instead of
puts().
* spfatal01/spfatal01.scn, spfatal02/spfatal02.scn,
spfatal03/spfatal03.scn, spfatal04/spfatal04.scn,
spfatal05/spfatal05.scn, spfatal06/spfatal06.scn,
spfatal07/spfatal07.scn, spfatal08/spfatal08.scn,
spfatal10/spfatal10.scn, spfatal11/spfatal11.scn,
spfatal12/spfatal12.scn, spfatal13/spfatal13.scn,
spfatal14/spfatal14.scn, spfatal15/spfatal15.scn,
spfatal16/spfatal16.scn, spfatal17/spfatal17.scn,
spfatal18/spfatal18.scn, spfatal19/spfatal19.scn,
spfatal20/spfatal20.scn: Update.
* sp21/init.c, sp21/sp21.scn: Tidy up with one last case to get 100%
coverage of rtems_io_lookup_name().
* sp21/Makefile.am, sp21/init.c, sp21/sp21.scn: Add
rtems_io_lookup_name() and simplify test.
* sp21/system.h, sp21/task1.c: Removed.
* termios06/init.c, termios06/termios06.scn: Add a couple more PPPDISC
cases. Coverage of these paths is near complete.
* psxtimes01/init.c: Added missing declaration.
* Makefile.am, configure.ac: Add new fatal error test for termios
initialize.
* spfatal20/.cvsignore, spfatal20/Makefile.am, spfatal20/spfatal20.doc,
spfatal20/spfatal20.scn, spfatal20/testcase.h: New files.
* malloctest/system.h: Enable malloc statistics.
* Makefile.am, configure.ac: Add test for various forms of times() and
getrusage().
* psxgetrusage01/.cvsignore, psxgetrusage01/Makefile.am,
psxgetrusage01/init.c, psxgetrusage01/psxgetrusage01.doc,
psxgetrusage01/psxgetrusage01.scn, psxtimes01/.cvsignore,
psxtimes01/Makefile.am, psxtimes01/init.c, psxtimes01/psxtimes01.doc,
psxtimes01/psxtimes01.scn: New files.
* Makefile.am, configure.ac: tar01 and tar02 not merged yet.
