This scheme is easier to decode.
Joel Sherrill <joel@rtems.org> modified the patch to
add autoconf logic to avoid building this new test
unless the tool chain include <ndbm.h>. The ensures
that git bisect continues to work and that the addition
of this test does not immediately force the entire
community to update their tools.
- No need to dump globals syms in test dl01 when tracing
Closes #3775
Process only the jobs initially registered on the processing list. This
makes it possible to add jobs for the current processor in a job
handler. These jobs are processed with the next
SMP_MESSAGE_PERFORM_JOBS message. The lock is only acquired and
released once.
Move resposibility to disable thread dispatching to the caller of
_SMP_Multicast_action(). Using an interrupt disable for this purpose is
questionable.
- Load symbols before allocation.
- Parse reloc records and place any reloc recs in a cache to use
while the allocator is locked.
- Relocate symbols after section allocation.
- Split section loading into allocation/locating and loading.
- Update all arch back-ends with a new reloc interface to control
tramp handling.
- Add `-a` and `-t` to the object list shell command.
Closes #3741
If the caller already disabled interrupts, then do not disable thread
dispatching. Calling _SMP_Multicast_action() with interrupts disabled
is a questionable use case.
Let it work during system initialization.
Use a FIFO list of jobs per processor to carry out the SMP multicast
action. Use a done indicator per job to reduce the bus traffic a bit.
Processor_mask is the internal data type to deal with processor sets.
Add _ISR_lock_Set_name() to optimize the initialization of
zero-initialized locks.
Rename _SMP_Get_processor_count() in _SMP_Get_processor_maximum() to be
in line with the API level rtems_scheduler_get_processor_maximum().
Update #3732.
Update #3734.
Update #3732.
Add rtems_scheduler_get_processor() as a replacement for
rtems_get_current_processor(). The rtems_get_current_processor() is a
bit orphaned. Adopt it by the Scheduler Manager. This is in line with
the glibc sched_getcpu() function.
Deprecate rtems_get_current_processor().
Update #3731.
This is an example test using the RTEMS Test Framework. It tests also
the framework itself.
Add T_FILE_NAME command line define to get rid of the full file path.
This is important to reduce the read-only data of test files and make
them build system independent.
Update #3199.
One reason to move the test support into a dedicated library are the
standard output __wrap_*() functions. They may conflict with
application level wrappers.
Update #3199.
- The archive command lists archives, symbols and any duplicate
symbols.
- Change the RTL shell commands to the rtems_printer to allow
the output to be captured.
Update #3665.
- Add a small memory test config file.
- Update the small memory PowerPC BSPs to use the new test config.
Remove the priority node only in case it is active.
Update #3334.
Recursive usage of the same pthread_once_t results now in a deadlock.
Previously, an error of EINVAL was returned. This usage scenario is
invalid according to the POSIX pthread_once() specification.
Close #3334.
This file is unused and makes trouble on Windows.
Updates #3638.
- Add support for architecure sections that can be handled by the
architecture back end.
- Add trampoline/fixup support for PowerPC. This means the PowerPC
now supports large memory loading of applications.
- Add a bit allocator to manage small block based regions of memory.
- Add small data (sdata/sbss) support for the PowerPC. The support
makes the linker allocated small data region of memory a global
resource available to libdl loaded object files.
Updates #3687
Updates #3685
- Add trampolines to support relocs that are out of range on
support architectures.
- Support not loading separate text/data sections in an object
file if the symbol provided in the section is a duplicate.
A base image may have pulled in part of an object and another
part needs to be dynamically loaded.
- Refactor the unresolved handling to scale to hundreds of
unresolved symbols when loading large number of files.
Updates #3685
- Trampolines or fixups for veneers provide long jump support
for instruciton sets that implement short relative address
branches. The linker provides trampolines when creating a
static image. This patch adds trampoline support to libdl
and the ARM architecture.
- The dl09 test requires enough memory so modules are outside
the relative branch instruction ranges for the architecture.
Updates #3685
- Fix the handling of pending objects.
- Add a constructor flags in objects to track then being called.
Closes #2921
- Create 2 archives.
- Load 1 object file which loads 6 object files from the libraries.
Updates #3686
Updates #3686
Updates #3686
