This patches some issues with the capture engine:
1. Check is the engine is open in ctrace commands.
2. Check all record open and appends for overflow.
3. Fix the record open to take the size of user data and
not the record header.
4. Use packed structs for data being written to the per
cpu buffers.
5. Remove direct struct access to the capture buffers to
avoid misaligned accesses.
6. Add support to extract records, no struct access to the
capture buffers.
7. Update ctrace to extract records from the capture buffers.
8. Add support to ctrace to always print the task name if it
has one.
9. Add support to manage names or the lack of a name.
10. Range of minor fixes.
11. Fix a long standing bug in ctset's handling of args.
Closes #2780.
According to POSIX priority value returned from pthread_getschedparam()
shall be the value specified by the most recent pthread_setschedparam(),
pthread_setschedprio(), or pthread_create() call affecting the target
thread. Read this as though a temporary lower priority due to the
sporadic server policy shall not be visible through
pthread_getschedparam(). Thus, use rtems_task_set_priority() to get the
current priority of the threads.
Use a priority ceiling mutex to prevent sporadic server priority
adjustments.
Return if the inserted node is the new minimum node or not.
This is old and there are better design patterns for threading and C++.
We recommend you use the new C++ standards based support.
Closes #2777.
We always build a C++ compiler and building with C++ does not effect
RTEMS or the runtime. This patch always enabled the support. There is
no need to manually enable it any more.
You can disable C++ with '--disable-cxx'.
If an architecture does not have a C++ compiler support is automatically
disabled.
This patch parses the mode field in the tar header and sets the
directory or file to the mode value in the header.
Closes #2768.
This helps to detect double insert and extract errors.
The newly created macro adds any kind of variable into a linker set. It
allows (for example) the saving an execution state of a function using
the following method:
- put a group of different variables into one linker set
- save the memory area containing the group of variables before the
execution of a function
- restore the memory area after the function has been executed
The mutex objects use the owner field of the thread queues for the mutex
owner. Use this and add a deadlock detection to
_Thread_queue_Enqueue_critical() for thread queues with an owner.
Update #2412.
Update #2556.
Close #2765.
The _Thread_Lock_acquire() function had a potentially infinite run-time
due to the lack of fairness at atomic operations level.
Update #2412.
Update #2556.
Update #2765.
updates #2732
Update #2765.
Update #2752.
* double insert, append, prepend errors, and
* get from empty chain errors.
This enables fatal extensions to continue program execution after some
fatal errors.
Task priorities are only valid within a scheduler instance. The
rtems_task_set_scheduler() directive moves a task from one scheduler
instance to another using the current priority of the thread. However,
the current task priority of the source scheduler instance is undefined
in the target scheduler instance. Add a third parameter to specify the
priority.
Close #2749.
This implementation just falls back to giving a string representation of
the IP. It supports IPv4 only.
Add test for getnameinfo().
The dummy for setgroups() allows applications using it to build (for example
civetweb webserver).
A 32-bit Priority_Control limits the uptime to 49 days with a 1ms clock
tick in case the EDF scheduler is used. Increase it to 64-bit to enable
proper operation of the EDF scheduler,
Close 2173.
Increase the invalid priority values to support test runs with
alternative schedulers offering a significant higher maximum priority
value, e.g. EDF.
This is an implementation detail of the EDF scheduler.
This test uses scheduler-specific data structures, thus it must use the
right scheduler.
Commit 77ff5599e0d8e6d91190a379be21a332f83252b0 introduced a change in
the rtems_semaphore_create() behaviour for MrsP semaphores. The ceiling
priorities for all schedulers except the scheduler of the executing
thread are initialized to zero.
The thread priority is manifest in two independent areas. One area is
the user visible thread priority along with a potential thread queue.
The other is the scheduler. Currently, a thread priority update via
_Thread_Change_priority() first updates the user visble thread priority
and the thread queue, then the scheduler is notified if necessary. The
priority is passed to the scheduler via a local variable. A generation
counter ensures that the scheduler discards out-of-date priorities.
This use of a local variable ties the update in these two areas close
together. For later enhancements and the OMIP locking protocol
implementation we need more flexibility. Add a thread priority
information block to Scheduler_Node and synchronize priority value
updates via a sequence lock on SMP configurations.
Update #2556.
Introduce map/unmap priority scheduler operations to map thread priority
values from/to the user domain to/from the scheduler domain. Use the
map priority operation to validate the thread priority. The EDF
schedulers use this new operation to distinguish between normal
priorities and priorities obtain through a job release.
Update #2173.
Update #2556.
Use same structure as POSIX API for thread priority conversion to/from
SuperCore.
Accept all priority values in pthread_mutexattr_setprioceiling(). This
is in line with POSIX and FreeBSD. The priority is validated in
pthread_mutex_init(). Validate the priority only for priority ceiling
mutexes.
This avoids test failures due to slow output devices.
The RTEMS print user need to know nothing about a particular printer
implementation. In particular get rid of the <stdio.h> include which
would be visible via <rtems.h>.
Rename RTEMS_PRINTF_ATTRIBUTE() into RTEMS_PRINTFLIKE() (similar to
<sys/cdefs.h> __printflike()) and move it to <rtems/score/basedefs.h>.
Resurrect workaround accidentially removed by
3e2a3c49480b9888362d016dd202edd562d9e069.
updates #2608.
