* | sppps01: Add test case for early returns of pps_event() | Gabriel Moyano | 2022-07-05 | 1 | -3/+46 |
| | | | | Update #2349. | ||||
* | score: Add _CPU_Use_thread_local_storage() | Sebastian Huber | 2022-07-04 | 1 | -4/+16 |
| | | | | | | | | | | | | At some point during system initialization, the idle threads are created. Afterwards, the boot processor basically executes within the context of an idle thread with thread dispatching disabled. On some architectures, the thread-local storage area of the associated thread must be set in dedicated processor registers. Add the new CPU port function to do this: void _CPU_Use_thread_local_storage( const Context_Control *context ) Close #4672. | ||||
* | libtests/crypt01: Avoid stack overflows | Sebastian Huber | 2022-07-04 | 1 | -1/+5 |
| | | | | | The SHA512 functions may use huge amounts of stack space if compiled without optimization. | ||||
* | samples/minimum: Prevent a stack overflow | Sebastian Huber | 2022-07-04 | 1 | -0/+5 |
| | | | | Prevent a stack overflow if RTEMS_COVERAGE is enabled. | ||||
* | build: Add RTEMS_GCOV_COVERAGE option | Sebastian Huber | 2022-07-04 | 2 | -2/+2 |
| | | | | Update #4670. | ||||
* | gcov: Add functions to dump the gcov information | Sebastian Huber | 2022-07-04 | 1 | -1/+2 |
* | samples/cdtest: Test exceptions during system init | Sebastian Huber | 2022-07-04 | 1 | -9/+35 |
| | | | | | Update #4668. Update #4672. | ||||
* | spcpuset01: Account for <sys/cpuset.h> API changes | Sebastian Huber | 2022-06-23 | 1 | -0/+10 |
| | | | | Update #4667. | ||||
* | score: Use right clock for threadq timeouts | Sebastian Huber | 2022-06-23 | 1 | -2/+8 |
| | | | | | | | | Use CLOCK_REALTIME and CLOCK_MONOTONIC for relative thread queue timeouts instead of CLOCK_REALTIME_COARSE and CLOCK_MONOTONIC_COARSE. This fixes an issue with clock_nanosleep() in combination with clock_gettime(). Close #4669. | ||||
* | TFTPFS: Fix test configuration for FP targets | Sebastian Huber | 2022-06-21 | 1 | -0/+2 |
| | | | | | | The test uses snprintf(). Update #4666. | ||||
* | TFTPFS: Reduce test configuration | Sebastian Huber | 2022-06-21 | 1 | -3/+2 |
* | TFTPFS: Add tests | Frank Kühndel | 2022-06-21 | 5 | -0/+9475 |
* | testsuite: Fix gcc 12 warnings | Chris Johns | 2022-06-21 | 62 | -89/+96 |
* | sptests/spglobalcon01/init.cc: Change license to BSD-2 | Joel Sherrill | 2022-06-14 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | samples/iostream/init.cc: Change license to BSD-2 | Joel Sherrill | 2022-06-14 | 1 | -3/+22 |
* | sptests/*/*.doc: Change license to BSD-2 | Joel Sherrill | 2022-06-14 | 1 | -3/+20 |
* | mptests/*/*.doc: Change license to BSD-2 | Joel Sherrill | 2022-06-14 | 26 | -78/+572 |
* | smptests/*/*.doc: Change license to BSD-2 | Joel Sherrill | 2022-06-14 | 10 | -30/+220 |
* | psxtmtests/*/*.doc: Change license to BSD-2 | Joel Sherrill | 2022-06-14 | 45 | -135/+990 |
* | samples/*/*.doc: Change license to BSD-2 | Joel Sherrill | 2022-06-14 | 12 | -33/+244 |
* | smptests/*/*.py: Change license to BSD-2 | Joel Sherrill | 2022-06-14 | 4 | -12/+88 |
| | | | | | | Manually adjusted location of SPDX annotation so #! remains first line. Updates #3053. | ||||
* | Newlib01: Add tests for rand() and lrand48() | Matt Joyce | 2022-06-09 | 2 | -0/+53 |
| | | | | | | Check that the state of rand() and lrand48() is thread-specific, that they are properly initialized, and return the expected sequence of pseudo-random numbers for default seed values. | ||||
* | testsuite/libtests: Add exit03 to test exit() with C++ | Chris Johns | 2022-06-09 | 4 | -0/+199 |
| | | | | Updates #4661 | ||||
* | validation: Fix CallWithinISR() | Sebastian Huber | 2022-06-08 | 1 | -0/+2 |
| | | | | | | | Some BSPs require that Clear_tm27_intr() is called in the interrupt service routine. Update #3269. | ||||
* | sppps01: Improve default handler test | Gabriel Moyano | 2022-05-27 | 1 | -0/+6 |
* | testsuites/sptests: Add sppps01 test | Gabriel Moyano | 2022-05-23 | 1 | -0/+191 |
* | timepps.h: PPS_SYNC defined by default | Gabriel Moyano | 2022-05-23 | 1 | -1/+1 |
* | termios06: Fix warning | Sebastian Huber | 2022-04-28 | 1 | -2/+2 |
| | | | | Update #4493. | ||||
* | heap: Fix heap statistics with protection enabled | Sebastian Huber | 2022-04-28 | 1 | -0/+4 |
| | | | | Close #4644. | ||||
* | sp65/init.c: Add file header and license | Ryan Long | 2022-04-27 | 1 | -0/+15 |
| | | | | | This file had no file header, copyright, or license. Based on git history, added appropriate copyright and license. | ||||
* | sp47/init.c: Add file header and license | Ryan Long | 2022-04-27 | 1 | -0/+15 |
| | | | | | This file had no header, copyright, or license. Based on git history, added appropriate copyright and license. | ||||
* | sp44/init.c: Add file header and license | Ryan Long | 2022-04-27 | 1 | -0/+15 |
* | psxtmtests/psxtmcond*: Add file headers and licenses | Ryan Long | 2022-04-27 | 3 | -0/+45 |
| | | | | | These files had no file header, copyright, or license. Based on git history, added appropriate copyright and license. | ||||
* | ada/samples: Manually adding file headers and licenses | Ryan Long | 2022-04-27 | 2 | -0/+66 |
* | sptests/sp27*: Manually adding file headers and licenses | Ryan Long | 2022-04-27 | 2 | -0/+70 |
* | libtests/dl06: Manually adding file headers and licenses. | Ryan Long | 2022-04-27 | 2 | -0/+70 |
| | | | | | These files had no header, copyright, or license. Based on git history, added appropriate copyright and license. | ||||
* | support: Manually adding file headers and licenses | Ryan Long | 2022-04-27 | 1 | -0/+36 |
* | samples: Manually adding file headers and licenses | Ryan Long | 2022-04-27 | 3 | -0/+105 |
| | | | | | These files had no file header, copyright, or license. Based on git history, added appropriate copyrights and licenses. | ||||
* | psxtests: Adding file headers and licenses | Ryan Long | 2022-04-27 | 7 | -0/+245 |
* | libtests: Adding file headers and licenses | Ryan Long | 2022-04-27 | 5 | -0/+175 |
* | sptests: Manually adding file headers and licenses | Ryan Long | 2022-04-27 | 16 | -0/+560 |
| | | | | | Theses files had no file header, copyright, or license. Based on git history, added appropriate copyrights and licenses. | ||||
* | tmtests: Manually adding file headers and licenses | Ryan Long | 2022-04-27 | 8 | -0/+280 |
* | mptests: Manually adding file headers and licenses | Ryan Long | 2022-04-27 | 26 | -0/+910 |
* | psxtmtests/psxtmkey02/init.c: Manually change license to BSD-2 | Joel Sherrill | 2022-04-12 | 1 | -3/+20 |
| | | | | | | This has yet another typo in the license and was missed by the script. Updates #3053. | ||||
* | psxtmtests/psxtmthread06/init.c: Adjust formatting | Joel Sherrill | 2022-04-12 | 1 | -2/+1 |
* | testsuites/samples: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 28 | -84/+616 |
* | testsuites/psxtests/psxhdrs/unistd/*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 23 | -69/+506 |
* | testsuites/psxtests/psxhdrs/time/*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 24 | -72/+528 |
* | testsuites/psxtests/psxhdrs/sys/socket/*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 17 | -51/+374 |
* | testsuites/psxtests/psxhdrs/sys/mman/*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 11 | -33/+242 |
| | | | | Updates #3053. |
