* | Newlib01: Add tests for rand() and lrand48() | Matt Joyce | 2022-06-09 | 2 | -0/+53 |
| | | | | | | Check that the state of rand() and lrand48() is thread-specific, that they are properly initialized, and return the expected sequence of pseudo-random numbers for default seed values. | ||||
* | testsuite/libtests: Add exit03 to test exit() with C++ | Chris Johns | 2022-06-09 | 4 | -0/+199 |
| | | | | Updates #4661 | ||||
* | validation: Fix CallWithinISR() | Sebastian Huber | 2022-06-08 | 1 | -0/+2 |
| | | | | | | | Some BSPs require that Clear_tm27_intr() is called in the interrupt service routine. Update #3269. | ||||
* | sppps01: Improve default handler test | Gabriel Moyano | 2022-05-27 | 1 | -0/+6 |
| | | | | Update #2349. | ||||
* | testsuites/sptests: Add sppps01 test | Gabriel Moyano | 2022-05-23 | 1 | -0/+191 |
* | timepps.h: PPS_SYNC defined by default | Gabriel Moyano | 2022-05-23 | 1 | -1/+1 |
* | termios06: Fix warning | Sebastian Huber | 2022-04-28 | 1 | -2/+2 |
| | | | | Update #4493. | ||||
* | heap: Fix heap statistics with protection enabled | Sebastian Huber | 2022-04-28 | 1 | -0/+4 |
| | | | | Close #4644. | ||||
* | sp65/init.c: Add file header and license | Ryan Long | 2022-04-27 | 1 | -0/+15 |
| | | | | | This file had no file header, copyright, or license. Based on git history, added appropriate copyright and license. | ||||
* | sp47/init.c: Add file header and license | Ryan Long | 2022-04-27 | 1 | -0/+15 |
| | | | | | This file had no header, copyright, or license. Based on git history, added appropriate copyright and license. | ||||
* | sp44/init.c: Add file header and license | Ryan Long | 2022-04-27 | 1 | -0/+15 |
* | psxtmtests/psxtmcond*: Add file headers and licenses | Ryan Long | 2022-04-27 | 3 | -0/+45 |
| | | | | | These files had no file header, copyright, or license. Based on git history, added appropriate copyright and license. | ||||
* | ada/samples: Manually adding file headers and licenses | Ryan Long | 2022-04-27 | 2 | -0/+66 |
* | sptests/sp27*: Manually adding file headers and licenses | Ryan Long | 2022-04-27 | 2 | -0/+70 |
* | libtests/dl06: Manually adding file headers and licenses. | Ryan Long | 2022-04-27 | 2 | -0/+70 |
| | | | | | These files had no header, copyright, or license. Based on git history, added appropriate copyright and license. | ||||
* | support: Manually adding file headers and licenses | Ryan Long | 2022-04-27 | 1 | -0/+36 |
* | samples: Manually adding file headers and licenses | Ryan Long | 2022-04-27 | 3 | -0/+105 |
| | | | | | These files had no file header, copyright, or license. Based on git history, added appropriate copyrights and licenses. | ||||
* | psxtests: Adding file headers and licenses | Ryan Long | 2022-04-27 | 7 | -0/+245 |
* | libtests: Adding file headers and licenses | Ryan Long | 2022-04-27 | 5 | -0/+175 |
* | sptests: Manually adding file headers and licenses | Ryan Long | 2022-04-27 | 16 | -0/+560 |
| | | | | | Theses files had no file header, copyright, or license. Based on git history, added appropriate copyrights and licenses. | ||||
* | tmtests: Manually adding file headers and licenses | Ryan Long | 2022-04-27 | 8 | -0/+280 |
* | mptests: Manually adding file headers and licenses | Ryan Long | 2022-04-27 | 26 | -0/+910 |
* | psxtmtests/psxtmkey02/init.c: Manually change license to BSD-2 | Joel Sherrill | 2022-04-12 | 1 | -3/+20 |
| | | | | | | This has yet another typo in the license and was missed by the script. Updates #3053. | ||||
* | psxtmtests/psxtmthread06/init.c: Adjust formatting | Joel Sherrill | 2022-04-12 | 1 | -2/+1 |
* | testsuites/samples: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 28 | -84/+616 |
* | testsuites/psxtests/psxhdrs/unistd/*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 23 | -69/+506 |
* | testsuites/psxtests/psxhdrs/time/*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 24 | -72/+528 |
* | testsuites/psxtests/psxhdrs/sys/socket/*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 17 | -51/+374 |
* | testsuites/psxtests/psxhdrs/sys/mman/*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 11 | -33/+242 |
* | testsuites/psxtests/psxhdrs/signal*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 9 | -27/+198 |
* | testsuites/psxtests/psxhdrs/sched/*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 8 | -24/+176 |
* | testsuites/psxtests/psxhdrs/pthread/*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 67 | -465/+1540 |
* | testsuites/psxtests/psxhdrs/devctl/*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 1 | -3/+22 |
* | testsuites/psxtmtests: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 45 | -136/+990 |
* | testsuites/psxtests/include: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 1 | -3/+22 |
* | testsuites/psxtests/psx[n-z]*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 60 | -177/+1300 |
* | testsuites/psxtests/psx[g-m1]*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 52 | -156/+1144 |
* | testsuites/psxtests/psx[a-f]*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 58 | -168/+1236 |
* | testsuites/psxtests/psx[01]*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 55 | -153/+1130 |
* | fstests/fsdosfsname01/create_image.sh: Manually change license to BSD-2 | Joel Sherrill | 2022-04-12 | 1 | -3/+22 |
* | testsuites/fstests/*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 20 | -60/+438 |
* | testsuites/libtests/*/*.dts. stackchk02.doc: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 3 | -9/+66 |
* | testsuites/libtests/[m-z]*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 27 | -81/+594 |
* | testsuites/libtests/[a-l]*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 50 | -150/+1100 |
* | testsuites/support/*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 8 | -22/+155 |
* | testsuites/tmtests/*/*.py: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 3 | -9/+60 |
* | testsuites/tmtests/ remainder: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 4 | -3/+28 |
| | | | | | | | | | | + include + tmck + tmfine01 + tmonetoone + tmtimer01 Updates #3053. | ||||
* | testsuites/tmtests/tm[23]*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 17 | -51/+374 |
* | testsuites/rmtests/tm[01]*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 19 | -57/+418 |
* | testsuites/benchmarks/*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 3 | -9/+66 |
| | | | | Updates #3053. |
