PR 1162/rtems
* unlimited/system.h: Reserve enough memory for the stacks wanted.
* mp01/node1/Makefile.am, mp01/node2/Makefile.am,
mp02/node1/Makefile.am, mp02/node2/Makefile.am,
mp03/node1/Makefile.am, mp03/node2/Makefile.am,
mp04/node1/Makefile.am, mp04/node2/Makefile.am,
mp05/node1/Makefile.am, mp05/node2/Makefile.am,
mp06/node1/Makefile.am, mp06/node2/Makefile.am,
mp07/node1/Makefile.am, mp07/node2/Makefile.am,
mp08/node1/Makefile.am, mp08/node2/Makefile.am,
mp09/node1/Makefile.am, mp09/node2/Makefile.am,
mp10/node1/Makefile.am, mp10/node2/Makefile.am,
mp11/node1/Makefile.am, mp11/node2/Makefile.am,
mp12/node1/Makefile.am, mp12/node2/Makefile.am,
mp13/node1/Makefile.am, mp13/node2/Makefile.am,
mp14/node1/Makefile.am, mp14/node2/Makefile.am: Eliminate scndir,
docdir. Use rtems_testsdir instead.
* tm01/Makefile.am, tm02/Makefile.am, tm03/Makefile.am,
tm04/Makefile.am, tm05/Makefile.am, tm06/Makefile.am,
tm07/Makefile.am, tm08/Makefile.am, tm09/Makefile.am,
tm10/Makefile.am, tm11/Makefile.am, tm12/Makefile.am,
tm13/Makefile.am, tm14/Makefile.am, tm15/Makefile.am,
tm16/Makefile.am, tm17/Makefile.am, tm18/Makefile.am,
tm19/Makefile.am, tm20/Makefile.am, tm21/Makefile.am,
tm22/Makefile.am, tm23/Makefile.am, tm24/Makefile.am,
tm25/Makefile.am, tm26/Makefile.am, tm27/Makefile.am,
tm28/Makefile.am, tm29/Makefile.am, tmck/Makefile.am,
tmoverhd/Makefile.am: Eliminate scndir, docdir. Use rtems_testsdir
instead.
* tmitronsem01/Makefile.am: Eliminate scndir, docdir. Use
sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am,
spfatal/Makefile.am, spsize/Makefile.am: Eliminate scndir, docdir.
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am,
base_sp/Makefile.am, cdtest/Makefile.am, fileio/Makefile.am,
hello/Makefile.am, iostream/Makefile.am, loopback/Makefile.am,
minimum/Makefile.am, paranoia/Makefile.am, ticker/Makefile.am,
unlimited/Makefile.am: Eliminate scndir, docdir. Use rtems_testsdir
instead.
* cpuuse/Makefile.am, malloctest/Makefile.am, rtems++/Makefile.am,
rtmonuse/Makefile.am, stackchk/Makefile.am: Eliminate scndir,
psx13/Makefile.am, psxcancel/Makefile.am, psxchroot01/Makefile.am,
psxfile01/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am,
psxreaddir/Makefile.am, psxsem01/Makefile.am, psxstat/Makefile.am,
psxtime/Makefile.am, psxtimer/Makefile.am: Eliminate scndir, docdir.
* itronhello/Makefile.am, itronmbf01/Makefile.am,
itronmbox01/Makefile.am, itronsem01/Makefile.am,
itrontask01/Makefile.am, itrontask02/Makefile.am,
itrontask03/Makefile.am, itrontask04/Makefile.am,
itrontime01/Makefile.am: Eliminate scndir, docdir. Use
* aclocal/version.m4: Updated to rtems-4.6.99.3.
Victor V. Vengerov <Victor.Vengerov@oktetlabs.ru>
* spsize/size.c: Victor spotted the problem that
_MPCI_Receive_server_tcb and _Thread_MP_Receive were duplicate
variables and needed to be set to the same value. I took that
idea and just removed _Thread_MP_Receive. All uses are now
_MPCI_Receive_server_tcb.
* rtems++/Task1.cc: Fix warnings.
* cdtest/main.cc: Fix warnings.
PR 855/tests
* support/include/tmacros.h: Fix typo.
* aclocal/enable-bare.m4: Remove (Unused).
* aclocal/env-rtemsbsp.m4:
Remove RTEMS_ENABLE_BARE,
BARE_CPU_CFLAGS, BARE_CPU_MODEL.
* configure.ac: Remove RTEMS_ENABLE_BARE,
* automake/compile.am: Remove .obj.
* automake/compile.am: Remove .coff.
* automake/local.am: Remove depend.
* automake/host.am: Remove depend.
* automake/subdirs.am: Remove preinstall, preinstall-recursive.
* automake/local.am: Remove preinstall-am.
* aclocal/env-rtemsbsp.m4: Remove includedir. Remove libdir.
Set rtems_testsdir to $libdir/rtems-4.7/tests.
* configure.ac: Remove AMPOLISH3 (Unused).
* aclocal/env-rtemsbsp.m4: Remove RTEMS_CPU_MODEL.
* automake/compile.am: Remove LINK_OBJS. Remove LINK_FILES.
Remove ARCH. Remove LINK_LIBS.
Extend clean-local to catch most temporary files make-exe is
creating.
tm03/Makefile.am, tm04/Makefile.am,
tm09/Makefile.am, tm10/Makefile.am,
tm15/Makefile.am, tm16/Makefile.am,
tm21/Makefile.am, tm22/Makefile.am,
tm27/Makefile.am, tm28/Makefile.am,
tmoverhd/Makefile.am: Convert to using *_PROGRAMS.
* tmitronsem01/Makefile.am: Convert to using *_PROGRAMS.
psxfile01/Makefile.am, psxhdrs/Makefile.am, psxmount/Makefile.am,
psxmsgq01/Makefile.am, psxreaddir/Makefile.am, psxsem01/Makefile.am,
psxstat/Makefile.am, psxtime/Makefile.am, psxtimer/Makefile.am:
minimum/Makefile.am, paranoia/Makefile.am, pppd/Makefile.am,
ticker/Makefile.am, unlimited/Makefile.am:
