* tmck/task1.c: Remove support for "unix".
* aclocal/canonical-target-name.m4:
Remove posix/unix simulator.
* cpuuse/init.c, cpuuse/system.h: Use minimum stack size.
* psx05/init.c, psx05/psx05.scn: Add test for bad mutex type.
* psxcleanup/system.h: Fix typo.
* Makefile.am, configure.ac: Add new test for exercising pushing
and popping a clean up handler without actually executing it.
* psxcleanup01/.cvsignore, psxcleanup01/Makefile.am,
psxcleanup01/init.c, psxcleanup01/psxcleanup01.doc,
psxcleanup01/psxcleanup01.scn: New files.
* Makefile.am, configure.ac: Add new test to ensure that canceling an
alarm works as defined.
* psxalarm01/.cvsignore, psxalarm01/Makefile.am, psxalarm01/init.c,
psxalarm01/psxalarm01.doc, psxalarm01/psxalarm01.scn: New files.
* psxtimer01/psxtimer.c: Actually pass the pointer we initialized.
* psxtimer01/psxtimer.c: Make sure we have null and not-null as return
parameter to timer_settime().
* psxtimer01/psxtimer.c: Modify so it passes in a NULL to
timer_settime() for previous value. We are not using the
value in this particular case and this path must be exercised.
* psxtimer01/psxtimer01.scn: Update so it matches output on sis.
* Makefile.am, configure.ac: Add new test to exercise when the ticks
since boot wraps around 0 and the timer server must deal with that
condition.
* sp67/.cvsignore, sp67/Makefile.am, sp67/init.c, sp67/sp67.doc,
sp67/sp67.scn: New files.
* sp40/init.c, sp40/sp40.doc, sp40/sp40.scn: New test cases.
* spintrcritical09/init.c, spintrcritical10/init.c,
spintrcritical11/init.c: Fixed potentially infinite loops.
* sptests/spintrcritical09/init.c, sptests/spintrcritical10/init.c,
sptests/spintrcritical11/init.c: Fixed potentially infinite loops.
* sp20/system.h: Increased micro seconds per tick in order to be more
independent of the console output speed.
* sp07/init.c, sp07/sp07.scn, sp09/init.c, sp09/screen01.c,
sp09/sp09.scn, sp28/init.c, sp62/init.c, sp62/sp62.scn, sp64/init.c,
sp64/sp64.scn: Add more test cases highlighted on SPARC at -O2, x86
at -Os and m68k at -Os. Fix typos.
* sp54/init.c: Use rtems_build_id to make building Objects_Id
RTEMS_USE_16_BIT_OBJECT clean.
* hello/init.c: Remove call to devFS_Show() which had accidentally
gotten committed.
* Makefile.am, configure.ac, termios01/termios_testdriver.c: Do not use
CONSOLE_USE_INTERRUPTS. That is in use by BSPs and we should not use
it.
* termios02/.cvsignore, termios02/Makefile.am, termios02/init.c,
termios02/termios02.doc, termios02/termios02.scn: New files.
termios02 is a test for tcdrain().
* termios01/init.c, termios01/termios_testdriver.c:
Reflect changes to termios.
* Makefile.am, configure.ac: Add new test to exercise when notepads are
not configured.
* spnotepad01/.cvsignore, spnotepad01/Makefile.am, spnotepad01/init.c,
spnotepad01/spnotepad01.doc, spnotepad01/spnotepad01.scn: New files.
* psxcancel/init.c, psxcancel/psxcancel.scn, psxcancel01/init.c,
psxcancel01/psxcancel01.scn: Add missing pthread cancellation test
cases.
* Makefile.am, configure.ac: Add new test for calling pthread_cancel()
from an ISR.
* psxcancel01/.cvsignore, psxcancel01/Makefile.am, psxcancel01/init.c,
psxcancel01/psxcancel01.doc, psxcancel01/psxcancel01.scn: New files.
* sp09/screen01.c, sp09/screen02.c, sp09/screen03.c, sp09/screen05.c,
sp09/screen09.c, sp09/screen14.c, sp09/sp09.scn, sp28/init.c,
sp28/sp28.scn, sp43/init.c: Add more error cases uncovered by uC5282
coverage runs.
* sp09/screen02.c, sp09/screen04.c, sp09/screen07.c, sp09/screen09.c,
sp09/screen10.c, sp09/screen11.c, sp09/screen12.c, sp09/sp09.scn: Add
some error cases uncovered by uC5282 coverage runs.
* sp33/init.c, sp33/sp33.scn: Add some barrier error cases uncovered by
* sp59/init.c, spintrcritical15/init.c, spintrcritical16/init.c:
Correct minor issues uncovered on uC5282.
* psxfatal_support/init.c, psxfatal_support/system.h: Eliminate use of
deprecated rtems_extension.
* sp04/tswitch.c, sp07/system.h, sp07/taskexit.c, sp07/tdelete.c,
sp07/tstart.c, spfatal_support/init.c, spfatal_support/system.h:
Eliminate use of deprecated rtems_extension.
* cpuuse/tswitch.c: Eliminate use of deprecated rtems_extension.
* sp14/asr.c, sp14/sp14.doc, sp14/task1.c, sp14/task2.c: Adjust test to
run when IO speed varies.
* stackchk01/stackchk01.doc: Add content.
* Makefile.am, configure.ac: Add initial test for
rtems_stack_checker_is_blown.
* stackchk01/.cvsignore, stackchk01/Makefile.am, stackchk01/init.c,
stackchk01/stackchk01.doc, stackchk01/stackchk01.scn: New files.
* psxclock/init.c, psxclock/psxclock.scn: Add test case for negative
nanoseconds.
* psxsysconf/init.c, psxsysconf/psxsysconf.scn: Add test for
getpagesize().
* sp43/init.c, sp43/sp43.scn: Minor correction to test case so it hits
the intended code.
* configure.ac: Revert accidentally committed lines.
* Makefile.am, configure.ac, sp65/init.c: Add new test to exercise very
simple priority ceiling case that was previously only tested via the
POSIX API.
* sp66/.cvsignore, sp66/Makefile.am, sp66/init.c, sp66/sp66.doc,
sp66/sp66.scn: New files.
* psxtests/psxclock/init.c, psxtests/psxclock/psxclock.scn: Add test
case for nanosleep of a very small delay which mathematically is less
than a clock tick.
* capture/test1.c: Use size_t for sizes.
* psxclock/init.c, psxclock/psxclock.scn, psxenosys/init.c,
psxenosys/psxenosys.scn, psxsignal03/Makefile.am, psxsignal03/init.c,
psxsignal04/Makefile.am: Move test cases which needed to be executed
when POSIX is disabled to psxclock so they will be.
* configure.ac: Some POSIX tests exercise functionality which is
enabled when the POSIX threading is disabled. So build this suite all
the time and let the psxtests select the specific tests to build.
* sp43/Makefile.am, sp43/init.c, sp43/sp43.scn, sp43/system.h: Add test
for Id which is in range for the object class but not allocated yet.
* Makefile.am, configure.ac, psx01/init.c, psx01/psx01.scn: Add new
test to exercise clock and delay services enabled when POSIX threads
are disabled. This is split from psx01. POSIX test suite now enabled
when POSIX threads are disabled so only enable tests which are
appropriate.
* psxclock/.cvsignore, psxclock/Makefile.am, psxclock/init.c,
psxclock/psxclock.doc, psxclock/psxclock.scn: New files.
* sp46/init.c, sp46/sp46.scn: Fix numbering.
* heapwalk/heapwalk.scn, heapwalk/init.c: Add missing _Heap_Walk test
cases to get back to 100% object coverage.
* heapwalk/init.c, heapwalk/heapwalk.scn, malloctest/init.c,
malloctest/malloctest.scn: New test cases.
* stackchk/blow.c, stackchk/stackchk.scn: Update for heap API changes.
* spintrcritical_support/intrcritical.c: Fixed timing rountines.
* malloctest/init.c: New test cases. Update for heap API changes.
* stackchk/blow.c: Update for heap API changes.
* spfatal01/spfatal01.scn, spfatal01/testcase.h,
spfatal02/spfatal02.scn, spfatal02/testcase.h,
spfatal03/spfatal03.scn, spfatal03/testcase.h,
spfatal04/spfatal04.scn, spfatal04/testcase.h,
spfatal05/spfatal05.scn, spfatal05/testcase.h,
spfatal06/spfatal06.scn, spfatal06/testcase.h,
spfatal07/spfatal07.scn, spfatal07/testcase.h,
spfatal08/spfatal08.scn, spfatal08/testcase.h,
spfatal09/spfatal09.scn, spfatal09/testcase.h, spfatal10/Makefile.am,
spfatal10/spfatal10.scn, spfatal11/Makefile.am,
spfatal11/spfatal11.scn, spfatal12/Makefile.am,
spfatal12/spfatal12.scn, spfatal_support/init.c: Make all fatal error
tests use testcase.h and spfatal_support framework. Print test name
herald in all cases.
* spfatal10/testcase.h, spfatal11/testcase.h, spfatal12/testcase.h:
New files.
* spfatal10/init.c, spfatal11/init.c, spfatal12/init.c: Removed.
* spfatal07/testcase.h: Indicate test is not applicable on some
architectures.
