* | Modified to reflect new restrictions on mutex being released. | Joel Sherrill | 1998-02-20 | 1 | -1/+1 | |
* | Removed extra line. | Joel Sherrill | 1998-02-20 | 1 | -1/+0 | |
* | Increased stack space to let test run to completion. | Joel Sherrill | 1998-02-20 | 1 | -4/+4 | |
* | Increased stack space of tasks. | Joel Sherrill | 1998-02-19 | 1 | -1/+1 | |
* | Increased stack size of initialization task. | Joel Sherrill | 1998-02-19 | 1 | -0/+1 | |
* | Restructured so all times are placed in variables and printed in batch | Joel Sherrill | 1998-02-19 | 1 | -163/+193 | |
| | | | | | mode at the end of the test. This eliminates the possibility of IO blocking a task unexpectedly and messing up the test. | |||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 569 | -569/+569 | |
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 | |
* | Solaris port updates from Chris Johns | Joel Sherrill | 1998-01-23 | 2 | -0/+5 | |
* | Ralf Corsepius reported a number of missing CVS Id's: | Joel Sherrill | 1998-01-16 | 11 | -10/+12 | |
| | | | | | | | | | | > RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose. | |||||
* | Removed warning. | Joel Sherrill | 1997-11-18 | 1 | -1/+1 | |
* | New file. | Joel Sherrill | 1997-11-18 | 1 | -0/+45 | |
* | Added new test for termios style consoles from Eric Norum. | Joel Sherrill | 1997-10-23 | 1 | -0/+141 | |
* | Added test case for rtems_interrupt_catch checking that the pointer | Joel Sherrill | 1997-10-21 | 2 | -1/+11 | |
| | | | | for the returned old_isr_handler was non-NULL. | |||||
* | Fixed some spacing. | Joel Sherrill | 1997-10-09 | 2 | -4/+4 | |
* | Fix from Eric Norum so FPSP is installed before any FP code is actually | Joel Sherrill | 1997-10-08 | 1 | -0/+9 | |
| | | | | exercise. | |||||
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 571 | -1142/+1142 | |
* | Fixed some weird line duplications. Thanks to Chris Johns. | Joel Sherrill | 1997-10-06 | 1 | -18/+9 | |
* | Added Monitor test. | Joel Sherrill | 1997-09-21 | 2 | -0/+131 | |
* | Patches from Chris Johns to clean up test. | Joel Sherrill | 1997-08-26 | 5 | -19/+52 | |
* | Merged very large and much appreciated patch from Chris Johns | Joel Sherrill | 1997-07-31 | 7 | -0/+1208 | |
| | | | | | <cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test. | |||||
* | Merged very large and much appreciated patch from Chris Johns | Joel Sherrill | 1997-07-31 | 1 | -0/+6 | |
* | Added support for rtems_message_queue_get_number_pending. | Joel Sherrill | 1997-07-31 | 4 | -0/+21 | |
* | Used macro instead of hard coded number. | Joel Sherrill | 1997-07-09 | 1 | -1/+1 | |
* | updated with new license information per Tony Bennett. | Joel Sherrill | 1997-04-22 | 1 | -13/+5 | |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 563 | -2815/+2815 | |
| | | | | of switching to the modified GNU GPL. | |||||
* | Modified to reflect change from 255 posix priority levels to 254. | Joel Sherrill | 1997-04-18 | 3 | -6/+6 | |
* | enabled floating point and fixed confdef reference to initialization | Joel Sherrill | 1997-04-09 | 4 | -5/+9 | |
| | | | | tasks table. | |||||
* | new test | Joel Sherrill | 1997-04-09 | 12 | -0/+742 | |
* | corrected printf specifications and added casts as necessary to eliminate | Joel Sherrill | 1997-04-07 | 7 | -72/+79 | |
| | | | | warnings. | |||||
* | added ifdef to avoid warning for unused variable. | Joel Sherrill | 1997-04-07 | 1 | -2/+6 | |
* | corrected integer only definitions of "FP CHECK" routines to eliminate | Joel Sherrill | 1997-04-07 | 1 | -3/+10 | |
| | | | | warnings. | |||||
* | corrected printf format to avoid warning | Joel Sherrill | 1997-04-02 | 7 | -11/+11 | |
* | initialized variables or removed unused variables to remove warnings | Joel Sherrill | 1997-04-02 | 3 | -4/+3 | |
* | Made stopping for the pause an option which can be configured in the | Joel Sherrill | 1997-01-29 | 1 | -0/+12 | |
| | | | | targopts.h file. | |||||
* | _CPU_Trap_Table_area is now conditional based on whether or not | Joel Sherrill | 1997-01-08 | 1 | -2/+5 | |
| | | | | the application requires rtems to allocate a trap table | |||||
* | new files | Joel Sherrill | 1996-09-18 | 3 | -0/+205 | |
* | added cast | Joel Sherrill | 1996-09-18 | 1 | -1/+1 | |
* | address arithmetic changed to be more portable | Joel Sherrill | 1996-09-18 | 1 | -3/+7 | |
* | new test submitted by Craig Lebakken (lebakken@minn.net) and Derrick Ostertag | Joel Sherrill | 1996-09-18 | 3 | -0/+230 | |
| | | | | (ostertag@transition.com) | |||||
* | extended Task_id and Task_name arrays to avoid indexing past end of array. | Joel Sherrill | 1996-09-17 | 1 | -2/+2 | |
* | Fixed test to match change to pthread_cond_timedwait which now takes a wall | Mark Johannes | 1996-09-12 | 1 | -26/+32 | |
| | | | | | | | time. Commented out calls to pthread_cond_wait and pthread_cond_timedwait without the mutex locked before calling. | |||||
* | modified test to take into account change in default value of | Joel Sherrill | 1996-09-06 | 1 | -0/+5 | |
| | | | | | inheritsched pthread attribute from implicit to explicit scheduling parameters. | |||||
* | added printf of status when not successful | Joel Sherrill | 1996-09-05 | 1 | -1/+3 | |
* | nanosleep no longer consider a negative value of tv_sec to be an error. | Joel Sherrill | 1996-09-05 | 1 | -6/+7 | |
| | | | | Instead it is an indication of a request for a small delay. | |||||
* | Changed all EFAULTS to EINVALs | Mark Johannes | 1996-08-23 | 1 | -14/+20 | |
* | filled in screen | Mark Johannes | 1996-08-23 | 1 | -0/+11 | |
* | Filled in screen | Mark Johannes | 1996-08-23 | 2 | -0/+78 | |
* | Filled in the screen | Mark Johannes | 1996-08-23 | 9 | -0/+479 | |
* | Added build_time statement to provide a tm for the test | Mark Johannes | 1996-08-23 | 1 | -2/+4 | |
