* | fsdosfsformat01.doc: Add contents | Cynthia Rempel | 2014-01-07 | 1 | -4/+18 | |
* | fsbdpart01.doc: Add contents | Cynthia Rempel | 2014-01-07 | 1 | -4/+21 | |
* | rhealstone: Add rh prefix to all test names | Joel Sherrill | 2014-01-05 | 26 | -152/+159 | |
| | | | | This makes them easier to spot as a group in wildcard searches. | |||||
* | rhealstone/*.c: Add Print_Warning() call to indicate debug enabled | Joel Sherrill | 2014-01-05 | 6 | -1/+11 | |
* | rhealstone/README: Formatting | Joel Sherrill | 2014-01-05 | 1 | -4/+5 | |
* | Added Rhealstone benchmark to testsuites | Daniel Ramirez | 2014-01-05 | 22 | -1/+1233 | |
| | | | | | | | The Rhealstone benchmarks six operations that are critical components of a real-time system. It allows for an objective analysis to be performed, and allows for comparisons between systems. See rhealstone/README for more information. | |||||
* | sp09: Remove partition specific parts | Joel Sherrill | 2014-01-04 | 4 | -46/+9 | |
* | spregion_err01: Clean up comments | Joel Sherrill | 2014-01-04 | 1 | -1/+0 | |
* | sppartition_err01: Remove dead parts, reduce, and clean up. | Joel Sherrill | 2014-01-04 | 14 | -1017/+356 | |
| | | | | Also fix naming issues. | |||||
* | psxtime: Added doc file. | Shaily Sangwan | 2014-01-03 | 1 | -0/+24 | |
* | pskey09, sp17: documentation cleanup. | Mandar Juvekar | 2014-01-03 | 2 | -9/+11 | |
* | sptests: Refactor sp09 into sppartition_err01 and sp09. | Mandar Juvekar | 2014-01-02 | 17 | -6/+777 | |
* | sp09: Remove region test references | Joel Sherrill | 2013-12-30 | 5 | -56/+10 | |
* | spregion_err01: Remove unneeded fluff copied from sp09 | Joel Sherrill | 2013-12-30 | 13 | -1135/+448 | |
| | | | | | The goal is to shrink the individual tests to have no unneeded resources and to follow the structure of a normal test. | |||||
* | spregion_err01: New test refactored from sp09 | Mandar Juvekar | 2013-12-30 | 17 | -6/+826 | |
* | Test suite documentations corrections and fixes. | Toma Radu | 2013-12-28 | 5 | -43/+47 | |
| | | | | Correct the sp02.doc, sp05.doc, sp06.doc, sp07.doc, sp08.doc files. | |||||
* | psx03: Add doc file | Rishi Sharma | 2013-12-26 | 1 | -0/+27 | |
* | utf8proc1/spedgsched01: minor fixes in test document files | Mandar Juvekar | 2013-12-25 | 2 | -23/+33 | |
* | psxtests/psx14: Add doc file | Mandar Juvekar | 2013-12-24 | 1 | -0/+28 | |
* | sptests: refactor sp09/screen13 into a new test spclock_err02 | Chirayu Desai | 2013-12-24 | 10 | -34/+88 | |
* | cpukit/rtems: Add rtems_clock_get_uptime_nanoseconds to the RTEMS API. | Chris Johns | 2013-12-24 | 2 | -0/+4 | |
| | | | | | | Add Timestamp support in the score to return a timestamp in nanoseconds. Add a test. Update the RTEMS API documentation. | |||||
* | psxtests/psxfatal01: add doc file | Mandar Juvekar | 2013-12-20 | 1 | -0/+18 | |
* | libcsupport: Accept NULL for zero-length entries | Sebastian Huber | 2013-12-20 | 1 | -2/+2 | |
* | Filesystem: Add readv/writev handlers | Sebastian Huber | 2013-12-20 | 1 | -2/+47 | |
| | | | | | | | | | The readv() and writev() support was implemented in terms of multiple calls to the read and write handlers. This imposes a problem on device files which use an IO vector as single request entity. For example a low-level network device (e.g. BPF(4)) may use an IO vector to create one frame from multiple protocol layers each with its own IO vector entry. | |||||
* | libcsupport: Add and use rtems_libio_iovec_eval() | Sebastian Huber | 2013-12-20 | 2 | -6/+35 | |
* | sptests/spcpuset*: Add tests for fixed size cpu_set_t operations. | Jennifer Averett | 2013-12-19 | 8 | -0/+4411 | |
| | | | | | | This adds five tests for <sys/cpuset.h>. It does not include tests for CPU_XXX_S methods. The autotools should be able to avoid enabling the tests unless the toolset has <sys/cpuset.h>. | |||||
* | psxtests: add psxcleanup/psxcleanup.doc | Anukul Sangwan | 2013-12-18 | 1 | -0/+18 | |
* | psxtests/configure.ac: Probe for SMP affinity methods | Joel Sherrill | 2013-12-13 | 1 | -0/+21 | |
* | sptests: refactored sp09/screen14.c into two new tests | Daniel Ramirez | 2013-12-11 | 17 | -419/+618 | |
* | sptests/spfifo01: Add test case for mknod() | Sebastian Huber | 2013-12-11 | 1 | -5/+8 | |
* | PR2160: imfs: Use ENOSYS for unsupported nodes | Sebastian Huber | 2013-12-11 | 1 | -15/+4 | |
| | | | | | Return an error status with errno set to ENOSYS during node creation for nodes not available in the current configuration. | |||||
* | psxsignal06: Fix bug where mutex not locked and add EPERM error check | Joel Sherrill | 2013-12-10 | 1 | -1/+4 | |
| | | | | | | | This test formerly had a bug in that it attempted to wait on a condition variable with a Mutex that was not locked. This is undefined by POSIX. But a recent change to match GNU/Linux behavior resulted in finding a bug in the test. | |||||
* | psxtmcond01: Fix bug where mutex not locked and add EPERM error check | Joel Sherrill | 2013-12-10 | 3 | -4/+20 | |
* | psxtmtests: added psxtmcond07 test | Daniel Ramirez | 2013-12-09 | 6 | -1/+183 | |
* | tmtests: refactored timesys.h, removed declarations | Daniel Ramirez | 2013-12-09 | 11 | -3/+21 | |
* | tmtests_plan.csv: New planning file | Joel Sherrill | 2013-12-07 | 1 | -0/+158 | |
* | tmoverhd/testtask.c: Fix output to be consistent | Joel Sherrill | 2013-12-07 | 1 | -71/+71 | |
* | tmoverhd/empty.c: formatting | Joel Sherrill | 2013-12-07 | 1 | -2/+1 | |
* | tm19: Clean up output | Joel Sherrill | 2013-12-07 | 1 | -2/+2 | |
* | psxtmtests_plan.csv: Update messages | Joel Sherrill | 2013-12-07 | 1 | -120/+120 | |
* | timesys.h: Benchmark output now includes a dash for easier parsing | Joel Sherrill | 2013-12-07 | 1 | -6/+10 | |
* | psxtmtests: Make output more uniform | Joel Sherrill | 2013-12-07 | 43 | -125/+125 | |
* | tmtests: Make output more uniform | Joel Sherrill | 2013-12-07 | 29 | -134/+136 | |
* | sppagesize: fix copyright | Gedare Bloom | 2013-12-06 | 2 | -7/+5 | |
* | sptests: add a test for page size | Chirayu Desai | 2013-12-06 | 6 | -2/+89 | |
| | | | | Bug: https://www.rtems.org/bugzilla/show_bug.cgi?id=1216 | |||||
* | sptest: sp2038: Add a test for leap year | Chirayu Desai | 2013-12-05 | 1 | -0/+32 | |
| | | | | Bug test case for PR 1422 | |||||
* | Update to Mongoose 3.9 at the last point before the MIT -> GPL license change | Nick Withers | 2013-12-04 | 1 | -25/+21 | |
| | | | | | | | | | | | | | | | | | | | | [That is, https://github.com/cesanta/mongoose/commit/04fc209644b414d915c446bb1815b55e9fe63acc. See https://groups.google.com/forum/#!topic/mongoose-users/aafbOnHonkI] The RTEMS patches described in the following emails and made to the previous Mongoose base have been applied: - http://www.rtems.org/pipermail/rtems-devel/2012-July/001345.html - http://www.rtems.org/pipermail/rtems-devel/2012-July/001343.html - http://www.rtems.org/pipermail/rtems-devel/2012-July/001346.html (except to mongoose.1, see below) ...as well as a patch very similar to that discussed at http://forums.bannister.org/ubbthreads.php?ubb=showflat&topic=7600&gonew=1 to provide poll() (which might be able to go away soon, with incoming RTEMS poll() support) mg_connect(), mg_url_encode() and mg_vprintf() were additionally marked "static" to silence warnings. mongoose.1 appears to have been removed from the upstream distribution. Note that the API's changed, for example: - A struct mg_callbacks must now be provided to mg_start(). Initialise members to NULL to disable various types of callbacks - Callback interfaces have changed significantly in general - The short form of options (e.g., "u" instead of "run_as_user") are no longer available (upstream) - The "max_request_size" options has been removed | |||||
* | psxtmtests: added new psxtmthread04 test | Daniel Ramirez | 2013-12-02 | 6 | -2/+153 | |
* | posix: Use cleanup contexts on the stack | Sebastian Huber | 2013-12-02 | 1 | -7/+0 | |
| | | | | | | | | | | Provide support for latest Newlib <pthread.h> change. The cleanup contexts are stored on the thread stack. This is conformant with the POSIX requirements for the pthread_cleanup_push() and pthread_cleanup_pop() statement pair. Passing an invalid pointer as the routine to pthread_cleanup_push() is now a usage error and the behaviour is undefined. | |||||
* | pstmtests_plan.csv: Update to reflect psxtmcond 09 and 10 exit | Daniel Ramirez | 2013-12-01 | 1 | -2/+2 | |
