path: root/testsuites (follow)
* Correctd name length to account for new IMFS max name length of 32.Jennifer Averett1999-03-291-1/+3
* These files were not added as part of a recent patch fromJoel Sherrill1999-03-241-0/+16
| | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
* Automake II patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. EmailJoel Sherrill1999-03-232-0/+309
* Unlimited objects patch from Chris Johns <ccj@acm.org>. Email follows:Joel Sherrill1999-03-177-0/+1068
| | | | | | | | | | | | | | | | | | | | | | | | | First, the unlimited patch. I have compiled the unlmited patch for the Linux posix BSP only and it seems to work cleanly. I would like a really major application run on this change before commiting as the changes are very core and significant. I am currently building all the tests to run. I have no targets suitable to test on at the moment. I have tested the patch for inline functions and macros. Turning macros on has found some core bugs. I have fixed these but have not run all the tests. Please review the patch for these changes. They are: 1) The conditional compilation for MP support broke the core messages code. You cannot embed a conditional macro in another macro. The Send and Urgent Send calls are macros. 2) User extensions handler initialisation now has two parameters. I have updated the macros to support the extra parameter. The patch also contains the gcc-target-default.cfg fix required to build the kernel. More of a by product than a fix for you.
* Commented out test case that no long works since addition of POSIX timers.Joel Sherrill1999-03-161-5/+10
* Added this file.Joel Sherrill1999-02-101-0/+8
* Patch from John S Gwynne <jsg@donet.com> for malloctest. His comments:Joel Sherrill1999-02-032-6/+12
| | | | | | | | | | I have a few patches for the efi332 bsp. If you let me know when you expect the next snapshot release, I will try to have them to you before then. Also, the malloctest has some problems that I would think would prevent it from running on almost any platform. I have enclose patches below to fix (1) Task_id and Task_name dimensioning, (2) end of test message, (3) the amount of memory malloc'ed, and (4) retry on unsuccessful (out of memory) molloc's.
* New files from Juan Zamorano Flores <jzamora@avellano.datsi.fi.upm.es>Joel Sherrill1999-02-033-0/+445
| | | | that are part of the addition of POSIX timers.
* Removed unneeded include of libio_.h.Joel Sherrill1999-01-311-2/+0
* Removed spaces.Joel Sherrill1998-12-033-14/+0
* Changed to account for ownership only being tracked when a priorityJoel Sherrill1998-12-031-0/+8
| | | | blocking protocol is used.
* Removed all ^M from the file.Jennifer Averett1998-12-031-156/+156
* Removed all ^M from the scn file.Jennifer Averett1998-12-031-1253/+1253
* Cleaned up test.Jennifer Averett1998-12-037-320/+480
| | | | Updated scn files to match present expected test output.
* Added Comment that a result is valid at 4 or 5 seconds.Jennifer Averett1998-12-031-13/+1
* Updated scn files to match present expected test output.Jennifer Averett1998-12-034-11/+267
* Insure that the same output occurs when multiprocessing is disabled.Joel Sherrill1998-12-035-1/+41
* Moved cpuuse.h to rtems subdirectory.Joel Sherrill1998-12-031-1/+1
* Include files now installed as <rtems/*.h>.Joel Sherrill1998-12-012-3/+3
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-5/+17
| | | | | | | | | | | | | | | | | | | | | | | | overhaul of the RTEMS system call interface. This base file system is the "In-Memory File System" aka IMFS. The design and implementation was done by the following people: + Joel Sherrill (joel@OARcorp.com) + Jennifer Averett (jennifer@OARcorp.com) + Steve "Mr Mount" Salitasc (salitasc@OARcorp.com) + Kerwin Wade (wade@OARcorp.com) PROBLEMS ======== + It is VERY likely that merging this will break the UNIX port. This can/will be fixed. + There is likely some reentrancy/mutual exclusion needed. + Eventually, there should be a "mini-IMFS" description table to eliminate links, symlinks, etc to save memory. All you need to have "classic RTEMS" functionality is technically directories and device IO. All the rest could be left out to save memory.
* Added new tests in support of the file system infrastructure.Joel Sherrill1998-11-233-0/+155
* Added tests in support of the file system infrastructure.Joel Sherrill1998-11-2315-0/+4577
* Added --disable-multiprocessing flag and modified a lot of files to makeJoel Sherrill1998-11-231-3/+35
| | | | it work.
* New file based on information from Eric Norum <eric@skatter.usask.ca>.Joel Sherrill1998-10-051-0/+42
* Fixed use of incorrect macro for minimum stack size.Joel Sherrill1998-10-051-1/+1
* IDLE task stack size now specified as a field in the CPU Table for allJoel Sherrill1998-09-231-1/+1
| | | | ports.
* Under allcoated task stacks.Joel Sherrill1998-08-031-1/+1
* Turned stack checker on.Joel Sherrill1998-07-171-0/+2
* Patch from Eric Norum to avoid printing from context switch user extension.Joel Sherrill1998-06-123-7/+37
| | | | The array is too long and needs to be shortened.
* Fixed comment block at the beginning of the file for a copyright dateJoel Sherrill1998-06-09135-271/+270
| | | | problem and an English problem.
* Fixed prototype of Fatal_Extension.Joel Sherrill1998-05-042-18/+15
| | | | Fixed interface to cofndefs.h for initial extension set.
* Added CONFIGURE_EXTRA_TASK_STACKS definition to make memory requirementsJoel Sherrill1998-04-2724-3/+49
| | | | more accurate.
* Fixed screen to match actual output.Joel Sherrill1998-04-271-3/+2
* Reset the pthread attributes structure so the proper error would beJoel Sherrill1998-04-271-1/+5
| | | | generated.
* Initial sets of user extensions now have memory allocated on the flyJoel Sherrill1998-04-151-2/+1
| | | | for them.
* Increased stack size so test would run in debug mode.Joel Sherrill1998-04-065-5/+6
* Rename hppa1_1 to hppa1.1 and switched to using __XXX__ macros forJoel Sherrill1998-03-242-9/+7
| | | | the CPU family name constants.
* Corrected typo in copyright notice.Joel Sherrill1998-03-211-1/+1
* Corrected to indicate test cases which were skipped.Joel Sherrill1998-03-031-2/+2
* Modified to reflect new restrictions on mutex being released.Joel Sherrill1998-02-201-1/+1
* Removed extra line.Joel Sherrill1998-02-201-1/+0
* Increased stack space to let test run to completion.Joel Sherrill1998-02-201-4/+4
* Increased stack space of tasks.Joel Sherrill1998-02-191-1/+1
* Increased stack size of initialization task.Joel Sherrill1998-02-191-0/+1
* Restructured so all times are placed in variables and printed in batchJoel Sherrill1998-02-191-163/+193
| | | | | mode at the end of the test. This eliminates the possibility of IO blocking a task unexpectedly and messing up the test.
* updated copyright to 1998Joel Sherrill1998-02-17569-569/+569
* Solaris port updates from Chris JohnsJoel Sherrill1998-01-232-0/+5
* Ralf Corsepius reported a number of missing CVS Id's:Joel Sherrill1998-01-1611-10/+12
| | | | | | | | | | > RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose.
* Removed warning.Joel Sherrill1997-11-181-1/+1
