* aclocal/canonical-target-name.m4: Remove tic4x.
* capture/test1.c: Add const to eliminate warning.
* spsize/size.c: Eliminate _TOD_Microseconds_per_tick.
* capture/test1.c: Eliminate all public use of TOD conversion routines.
* Makefile.am, configure.ac, spfatal06/testcase.h,
spfatal07/testcase.h, spfatal08/testcase.h, spfatal09/testcase.h,
spsize/size.c: Eliminate pointers to API configuration tables in the
main configuration table. Reference the main configuration table and
the API configuration tables directly using the confdefs.h version
rather than obtaining a pointer to it. This eliminated some
variables, a potential fatal error, some unnecessary default
configuration structures. Overall, about a 4.5% reduction in the code
size for minimum and hello on the SPARC.
* spfatal10/.cvsignore, spfatal10/Makefile.am, spfatal10/spfatal10.scn,
spfatal10/testcase.h: Removed.
* malloctest/init.c: Change sizes of heap/region and allocated objects
in heap to intptr_t so they can be larger than a single allocatable
object (e.g. size_t).
* psx05/init.c: Add parameter to call to sched_get_priority_max().
* unlimited/init.c: Run all tests successfully with maxixum number of
priorities as 16 instead of 256. This was done by temporarily
modifying the score priority.h maximum. This allowed testing of all
API code to ensure that it worked properly with a reduced number of
priorities. Most modifications were to switch from hard-coded maximum
to using the API provided methods to determine maximum number of
priority levels.
* psx05/init.c, psx07/init.c, psx09/init.c, psx11/init.c, psx12/init.c:
Run all tests successfully with maxixum number of priorities as 16
instead of 256. This was done by temporarily modifying the score
priority.h maximum. This allowed testing of all API code to ensure
that it worked properly with a reduced number of priorities. Most
modifications were to switch from hard-coded maximum to using the API
provided methods to determine maximum number of priority levels.
* itrontask04/init.c: Run all tests successfully with maxixum number of
priority levels.
* tm01/task1.c, tm02/task1.c, tm03/task1.c, tm04/task1.c, tm05/task1.c,
tm06/task1.c, tm07/task1.c, tm08/task1.c, tm09/task1.c, tm10/task1.c,
tm11/task1.c, tm12/task1.c, tm13/task1.c, tm14/task1.c, tm16/task1.c,
tm17/task1.c, tm18/task1.c, tm19/task1.c, tm20/task1.c, tm21/task1.c,
tm23/task1.c, tm24/task1.c, tm25/task1.c, tm26/task1.c, tm27/task1.c,
tm28/task1.c, tm29/task1.c, tmoverhd/testtask.c: Run all tests
successfully with maxixum number of priorities as 16 instead of 256.
This was done by temporarily modifying the score priority.h maximum.
This allowed testing of all API code to ensure that it worked
properly with a reduced number of priorities. Most modifications were
to switch from hard-coded maximum to using the API provided methods
* sp07/init.c, sp12/init.c, sp12/pridrv.c, sp12/pritask.c,
sp12/system.h, sp16/system.h, sp25/system.h, sp26/task1.c,
sp28/init.c, sp29/init.c, sp35/priinv.c, sp42/init.c: Run all tests
* fileio/init.c: Add explicit creation of /etc/passwd and /etc/group so
we have a test case for real password checking.
* psxtimer01/psxtimer.c, psxtimer02/psxtimer.c: Obtain TOD with
clock_gettime() NOT by reaching into the SuperCore.
* tm26/task1.c: Fix typo.
* sp46/sp46.scn: Add screen missed earlier.
PR 1348/cpukit
* Makefile.am, configure.ac: Add test of special case of resetting cpu
usage information while a period is running.
* sp46/.cvsignore, sp46/Makefile.am, sp46/init.c, sp46/sp46.doc,
sp46/sp46.scn: New files.
* sp45/init.c: New file.
PR 1347/cpukit
* Makefile.am, configure.ac, sp30/resume.c, sp30/task1.c, sp31/delay.c:
Rework Timer Server to ensure that the context allows for blocking,
allocating memory, and acquiring semaphores and mutexes.
* sp45/.cvsignore, sp45/Makefile.am, sp45/sp45.doc, sp45/sp45.scn:
New files.
* sp25/system.h: Add warning and temporary m32c conditional until size
type addressed.
* paranoia/paranoia.c: Add missing prototypes.
* tm22/system.h, tm22/task1.c: Account for message buffers used.
* malloctest/init.c: Do not generate alignment factors larger that will
not fit in a native integer.
* sp09/screen07.c: Use INT_MAX as number of messages so always
properly sized and no overflow on constant.
* sp09/screen10.c: Delay so on targets with simulator idle clock
tick driver this will work.
* sp09/screen11.c, sp09/system.h: Move badly aligned objects to odd
byte boundaries rather than two byte boundaries.
* sp09/screen03.c, sp09/screen14.c: Skip tests which try to
allocate more memory than size_t holds on m32c.
* unlimited/system.h: Tighten configuration for stack space.
* fileio/init.c: When USE_SHELL not defined, do not attempt to
configure shell.
* unlimited/system.h: 10000 task ids is too many for some targets.
* include/timesys.h: Use inttypes.h.
* tmck/task1.c: Use uint32_t for count.
* sp09/screen01.c, sp09/screen12.c, sp25/system.h, sp25/task1.c,
sp28/init.c, sp39/init.c, sp41/init.c, spfatal01/testcase.h,
spfatal08/testcase.h: Change size_t to ssize_t on all Heap, Workspace
and Region calls. On 16-bit architectures, size_t can be 16-bits
which would limit sizes to 64K. Also address constants which
overflowed on 16-bit integer targets.
* psx01/psx01.scn: Bump version to 4.9.99.0
* sp43/sp43.scn: Bump version to 4.9.99.0
* aclocal/version.m4: Bump RTEMS_API to 4.10.
Bump _RTEMS_VERSION to 4.9.99.0.
* unlimited/system.h: Support up to 10K tasks in loop. With 64MB on
pc386 and configured for unified workspace, you can get close to
this.
* include/timesys.h: Rename STACK_CHECKER_ON to more appropriate
CONFIGURE_STACK_CHECKER_ENABLED.
* fileio/system.h: Rename STACK_CHECKER_ON to more appropriate
* stackchk/system.h: Rename STACK_CHECKER_ON to more appropriate
* minimum/init.c, unlimited/system.h: Add support for optionally having
a unified work area. In other words, the RTEMS Workspace and C
Program Heap are the same pool of memory.
* hello/system.h, minimum/Makefile.am, minimum/init.c: Merge GSOC
project code to add simple device only filesystem (devfs), optionally
completely drop out filesystem, and to clean up disabling newlib
reentrancy support. This dropped 17K from the minimum.exe for
sparc/sis and arm/rtl22xx_t now has a 15K code space.
* tm09/system.h, tm09/task1.c: Account for message buffer memory.
* mp09/recvmsg.c, mp09/task1.c, mp10/task1.c, mp13/task1.c,
mp14/msgtask1.c: Correct types to eliminate warnings.
* sp34/sp34.scn, sp35/sp35.scn: Convert to UNIX CR/LF style.
* support/src/test_support.c: Convert to "bool".
* malloctest/init.c: Convert to "bool".
* psxcleanup/psxcleanup.c, psxfatal_support/init.c,
psxfatal_support/system.h: Convert to "bool".
* capture/system.h, capture/test1.c, fileio/init.c,
unlimited/init.c, unlimited/system.h, unlimited/test1.c:
Convert to "bool".
* sp35/priinv.c, sp37/init.c, sp38/init.c, sp39/init.c, sp41/init.c,
sp42/init.c, sp43/init.c, spfatal/fatal.c, spfatal/system.h,
spfatal_support/init.c, spfatal_support/system.h:
Convert to "bool".
