* configure.ac: Remove itron.
* spfifo01/init.c, spfifo01/spfifo01.doc, spfifo02/init.c,
spfifo02/spfifo02.doc, spfifo03/init.c, spfifo03/spfifo03.doc,
spfifo04/init.c, spfifo04/spfifo04.doc: Modified copyright.
* sp16/task1.c: Update for heap extend changes.
* spfifo01/init.c, spfifo01/spfifo01.scn: Update for IMFS API changes.
* spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am,
spfifo04/Makefile.am: Merged fifo main and test files into the
standard init file. Fixed copyright information.
* spfifo01/init.c, spfifo02/init.c, spfifo03/init.c, spfifo04/init.c:
New files.
* spfifo01/main.c, spfifo01/test.c, spfifo02/main.c, spfifo02/test.c,
spfifo03/main.c, spfifo03/test.c, spfifo04/main.c, spfifo04/test.c:
Removed.
* spmkdir/.cvsignore, spmkdir/Makefile.am, spmkdir/init.c,
spmkdir/spmkdir.doc, spmkdir/spmkdir.scn: New files.
* Makefile.am, configure.ac: Reflect changes above.
* spfifo01/.cvsignore, spfifo02/.cvsignore, spfifo03/.cvsignore,
spfifo04/.cvsignore: New files.
* psxfile01/test.c: Update for IMFS API changes.
* spfifo01/main.c: New file.
PR PR1542
* spfifo01/Makefile.am: New file.
* aclocal/version.m4: Bump RTEMS_API to 4.11.
Bump _RTEMS_VERSION to 4.10.99.0.
PR PR1542
* Makefile.am, configure.ac: Coverage improvement: fifo_open.
* spfifo01/spfifo01.doc, spfifo01/spfifo01.scn, spfifo01/test.c,
spfifo02/Makefile.am, spfifo02/main.c, spfifo02/spfifo02.doc,
spfifo02/spfifo02.scn, spfifo02/test.c, spfifo03/Makefile.am,
spfifo03/main.c, spfifo03/spfifo03.doc, spfifo03/spfifo03.scn,
spfifo03/test.c, spfifo04/Makefile.am, spfifo04/main.c,
spfifo04/spfifo04.doc, spfifo04/spfifo04.scn, spfifo04/test.c: New
files.
* termios01/init.c, termios01/termios01.scn, termios02/init.c,
termios02/termios02.scn: Add tests for cfigetspeed(), cfogetspeed(),
cfisetspeed(), cfosetspeed(), ctermid(), tcflow(), tcflush(),
tcsendbreak(), tcsetpgrp(), and tcgetpgrp(). Some of these methods
are minimal implementations so the tests will have to grow as the
methods grow.
* heapwalk/init.c, malloctest/init.c: Update for heap extend changes.
* sp09/screen12.c: Update for heap extend changes.
* iostream/init.cc: Remove the hack.
* psxfile01/test.c, psxmount/test.c, psxreaddir/test.c,
psxstat/test.c: Update to the new mount API.
* fileio/init.c: Update to new mount API.
* iostream/init.cc: Hack to work around confdefs.h in C++.
* iostream/system.h: Add comment about base miniIMFS.
* configure.ac: Add AC_CHECK_SIZEOF(off_t).
* include/pmacros.h: Add PRIdoff_t.
* support/include/tmacros.h: Remove PRIdoff_t.
* psxfile01/test.c, psxfile01/psxfile01.scn: This file now
exercises the _rename_r in libcsupport. For now, it also
provides two fsmount_me_h handlers to enable certain error
checking paths
PR 1433/cpukit
* block08/bdbuf_tests.c: Enabled tests 1.1, 1.2 and 1.3.
* block08/bdbuf_test1_1.c, block08/bdbuf_test1_2.c,
block08/bdbuf_test1_3.c: Use RTEMS_IO_ERROR instead of
RTEMS_NO_MEMORY.
* block01/init.c, block02/init.c, block03/init.c, block04/init.c,
block05/init.c, block06/init.c, block07/init.c, block09/init.c,
block10/init.c: Changed CONFIGURE_MAXIMUM_SEMAPHORES defines.
* Makefile.am: Move POSIX in front of other tests.
* support/include/tmacros.h: Changed check_dispatch_disable_level() to
treat all non-zero values of _Thread_Dispatch_disable_level equally.
* psxfile01/test.c: Add check for errno on chdir(NULL).
* psxrdwrv/test.c: Use SIZE_MAX not SSIZE_MAX.
* psx07/init.c, psx07/task.c: Introduce enough of a delay so the Init()
thread can reliably reach the pthread_join() call.
* psxreaddir/psxreaddir.scn, psxreaddir/test.c: Do not test for
rewinddir(NULL) since we are now using newlib's implementation and it
does not check for NULL. This causes a fault on some targets.
* bspcmdline01/init.c: Fix assert conditional.
* POSIX/flockfile.c, POSIX/funlockfile.c, POSIX/ftrylockfile.c: New.
* POSIX/Makefile.am: Add flockfile, funlockfile, ftrylockfile.
* capture/init.c: Remove unused variable "out".
* psx07/init.c, psx09/init.c, psx12/init.c, psxhdrs/pthread11.c,
psxhdrs/pthread22.c, psxhdrs/sched01.c, psxhdrs/sched03.c:
Reflect POSIX changes to sched_param.
* sp62/init.c, sp65/init.c: #include <unistd.h>.
* psxhdrs/proc01.c, psxhdrs/proc02.c, psxhdrs/proc07.c,
psxhdrs/proc08.c, psxhdrs/proc09.c, psxhdrs/proc10.c,
psxhdrs/proc11.c, psxhdrs/proc12.c, psxhdrs/proc13.c,
psxhdrs/proc14.c, psxhdrs/signal20.c, psxhdrs/signal21.c:
* sp43/init.c: Readdress use of ctype methods per recommendation from
D.J. Delorie on the newlib mailing list. We should pass an unsigned
char into these methods.
* fileio/init.c: Remove deprecation warnings.
