* nsecs/init.c: Add include of unistd.h for sleep() prototype.
* nsecs/Makefile.am, nsecs/init.c: Move empty body to another file. The
loop was being optimized out on the PowerPC.
* nsecs/empty.c: New file.
* nsecs/init.c: Change name to avoid any hint of the timer driver.
* nsecs/init.c: Do not make this test depend on the benchmark timer
driver.
* nsecs/init.c, nsecs/nsecs.scn: Add set of loops so you can see the
time varaying in proportion to the length of the loop measured.
* sp20/task1.c, sp34/changepri.c, sp35/priinv.c: Build when using
buffered test IO.
* tztest/init.c: Build when using buffered test IO.
* sp21/sp21.scn, sp21/task1.c: rtems_io_register_driver and
rtems_io_unregister_driver did not have any test code.
* spsize/size.c: Eliminate maximum_drivers configuration parameter
since it was used to configure a no longer used feature. Device names
are now part of the filesystem not in a table. This also eliminated
the variables _IO_Number_of_devices and _IO_Driver_name_table from
RTEMS as well as the memory allocation used to populate
_IO_Driver_name_table.
* sp13/system.h, sp34/changepri.c, sp35/priinv.c: Avoid using
CONFIGURE_MEMORY_OVERHEAD and try to really account for the memory
properly.
* spsize/size.c: Eliminated the variables
_RTEMS_tasks_User_initialization_tasks and
_RTEMS_tasks_Number_of_initialization_tasks because they were only
used in one place after initialized. It was a waste of space.
the size of the BSS section when an optional manageer stub is used. Some tests showed about a 600 byte reduction in BSS size. Also eliminated the variables _RTEMS_tasks_User_initialization_tasks and _RTEMS_tasks_Number_of_initialization_tasks because they were only used in one place after initialized. It was a waste of space.
* ChangeLog, rtmonuse/task1.c: Clean up output and use FLUSH_OUTPUT()
macro instead of fflush() directly.
* nsecs/init.c: Remove stray "volatile int i".
* rtmonuse/init.c, rtmonuse/task1.c: Integrate Rate Monotonic
Statistics and Period Usage into Rate Monotonic Manager. Added the
following directives: rtems_rate_monotonic_get_statistics,
rtems_rate_monotonic_reset_statistics,
rtems_rate_montonic_reset_all_statistics,
rtems_rate_montonic_report_statistics, and rtems_object_get_name.
Obsoleted the rtems/rtmonuse.h file as a public interface.
* support/include/buffer_test_io.h: Add support for using printk for
output in tests. This should be followed up by disabling the console
driver and other support when the tests are using printk.
* cpuuse/Makefile.am, malloctest/Makefile.am, putenvtest/Makefile.am,
rtmonuse/Makefile.am, stackchk/Makefile.am, termios/Makefile.am: Add
optional managers to Makefiles. Clean up test cases so last output
line follows END OF pattern. Make sure test case all run. All tests
appeared ok on sis.
* base_sp/Makefile.am, hello/Makefile.am, iostream/Makefile.am,
loopback/Makefile.am, nsecs/Makefile.am,
pppd/Makefile.am, ticker/Makefile.am, ticker/system.h,
unlimited/Makefile.am: Add optional managers to Makefiles. Clean up
test cases so last output line follows END OF pattern. Make sure test
case all run. All tests appeared ok on sis.
* nsecs/init.c: Commit hack so test will compile when POSIX is
disabled. Remove hack when clock_gettime() is present even when
--disable-posix.
* tm05/Makefile.am, tm06/Makefile.am, tm07/Makefile.am,
tm08/Makefile.am, tm09/Makefile.am, tm10/Makefile.am,
tm11/Makefile.am, tm12/Makefile.am, tm13/Makefile.am,
tm14/Makefile.am, tm15/Makefile.am, tm16/Makefile.am,
tm17/Makefile.am, tm18/Makefile.am, tm19/Makefile.am,
tm20/Makefile.am, tm22/Makefile.am, tm23/Makefile.am,
tm24/Makefile.am, tm25/Makefile.am, tm26/Makefile.am,
tm27/Makefile.am, tm28/Makefile.am, tm29/Makefile.am,
tmck/Makefile.am, tmoverhd/Makefile.am: Add optional managers to
Makefiles. Clean up test cases so last output line follows END OF
pattern. Make sure test case all run. All tests appeared ok on sis.
sp07/Makefile.am, sp07/tdelete.c, sp08/Makefile.am, sp09/Makefile.am,
sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am,
sp35/Makefile.am, spfatal/Makefile.am, spsize/Makefile.am,
spsize/size.c: Add optional managers to Makefiles. Clean up test
cases so last output line follows END OF pattern. Make sure test case
* psxsem01/init.c, psxsem01/psxsem01.scn, psxtimer/psxtimer.c,
psxtimer/psxtimer.scn: Add optional managers to Makefiles. Clean up
* itronmbf01/init.c, itronmbf01/itronmbf01.scn, itrontask02/init.c,
itrontask03/itrontask03.scn, itrontask03/task1.c,
itrontask04/itrontask04.scn, itrontask04/task3.c: Add optional
managers to Makefiles. Clean up test cases so last output line
appeared ok on sis.
* ticker/Makefile.am, ticker/init.c, ticker/system.h, ticker/tasks.c:
Test needs clock manager. Should use rtems_test_exit() instead of
exit().
* minimum/Makefile.am, minimum/init.c: Switch back to using optional
manager support. Also add use of CONFIGURE_DISABLE_NEWLIB_REENTRANCY
to demonstrate that the newlib reentrancy support is optional.
* nsecs/init.c: Remove private decl of _Timespec_Subtract use the
version from rtems/score/timespec.h.
* spsize/size.c: _TOD_Seconds_since_epoch eliminated as a variable.
* nsecs/init.c: Provide timespec manipulation routines in the
SuperCore. Use them everywhere possible. Perhaps they should be part
of the public API so this test and others can use them without
peeking into the bowels.
* psx01/init.c, psx01/psx01.scn: Adjust test to account for nanosleep()
behavior more closely matching GNU/Linux.
* sp34/changepri.c, sp35/priinv.c: Change all obsoleted
CONFIGURE_TEST_NEEDS_XXX configuration constants to
CONFIGURE_APPLICATION_NEEDS_XXX.
* loopback/init.c: Change all obsoleted CONFIGURE_TEST_NEEDS_XXX
configuration constants to CONFIGURE_APPLICATION_NEEDS_XXX.
* spsize/size.c: Eliminate TOD_Ticks_per_second variable.
* spsize/size.c: Convert from Classic API style TOD_Control as
fundamental time structure to POSIX struct timespec. Add
clock_get_uptime().
* Makefile.am, configure.ac: Convert from Classic API style TOD_Control
as fundamental time structure to POSIX struct timespec. Add
clock_get_uptime().
* nsecs/.cvsignore, nsecs/Makefile.am, nsecs/init.c, nsecs/nsecs.doc,
nsecs/nsecs.scn: New files.
* monitor/init.c, rtmonuse/task1.c: Use rtems_task_argument.
* sp06/task1.c, sp20/task1.c: Use rtems_task_argument.
* mp12/node2/mp12-node2.scn: Redo screen to not have cvs conflict
marker.
* sp35/priinv.c: Remove warning.
* loopback/init.c: Add CVS Id.
PR 1230/tests
* minimum/init.c: Minimum should not configure console driver.
* tztest/init.c: Call tzset() even though it may be called for us
implicitly along the way.
* tztest/.cvsignore: New file.
* Makefile.am, configure.ac: Added timezone test.
* tztest/Makefile.am, tztest/init.c, tztest/tztest.doc,
tztest/tztest.scn: New files.
* sp26/system.h: Remove incorrect and duplicate
CONFIGURE_EXTRA_TASK_STACKS.
PR 1222/cpukit
* Makefile.am, configure.ac: Enhance so that when the prioirity of a
thread that is blocked on a priority based thread queue is changed,
that its placement in the queue is reevaluated based upon the new
priority. This enhancement includes modifications to the SuperCore as
well as new test cases.
* sp34/.cvsignore, sp34/Makefile.am, sp34/changepri.c, sp34/sp34.doc,
sp34/sp34.scn, sp35/.cvsignore, sp35/Makefile.am, sp35/priinv.c,
sp35/sp35.doc, sp35/sp35.scn: New files.
* malloctest/init.c: Be explicit about need for default and floating
point attributes. This is just a style change.
* sp26/system.h: Correct memory required for stack sizes.
