* spsize/size.c: Reflect SPARC modifcation to get rid of
NO_TABLE_MOVE and references to _CPU_Trap_Table_area.
* Per PR147 addressed problems when reseting and inserting a timer
into a timer chain that did not honor time passage since the last
time the timer server was scheduled and the new insertion.
* sp31/sp31.scn, sp31/task1.c: Added test code to detect this case.
* Side-effect of PR132.
* sp21/system.h: Now must explicitly request NULL driver.
* tm01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm05/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm06/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm07/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm08/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm09/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm10/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm11/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm12/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm13/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm14/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm15/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm16/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm17/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm18/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm19/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm20/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm21/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm22/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm23/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm24/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm25/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm26/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm27/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm28/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm29/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tmck/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tmoverhd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tmitronsem01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp05/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp06/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp07/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp08/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp09/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp11/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp12/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp13/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp14/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp15/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp16/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp17/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp19/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp20/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp21/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp22/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp23/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp24/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp25/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp26/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp27/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp28/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp29/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp30/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp31/Makefile.am: Remove AUTOMAKE_OPTIONS.
* spfatal/Makefile.am: Remove AUTOMAKE_OPTIONS.
* spsize/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_mp/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_mp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_mp/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_sp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* cdtest/Makefile.am: Remove AUTOMAKE_OPTIONS.
* hello/Makefile.am: Remove AUTOMAKE_OPTIONS.
* minimum/Makefile.am: Remove AUTOMAKE_OPTIONS.
* paranoia/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ticker/Makefile.am: Remove AUTOMAKE_OPTIONS.
* unlimited/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx05/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx06/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx07/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx08/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx09/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx10/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx11/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx12/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx13/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxcancel/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxchroot01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxfile01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxhdrs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxmount/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxmsgq01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxreaddir/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxsem01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxstat/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxtime/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxtimer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp01/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp01/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp02/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp02/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp03/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp03/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp04/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp04/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp05/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp05/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp05/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp06/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp06/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp06/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp07/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp07/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp07/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp08/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp08/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp08/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp09/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp09/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp09/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp10/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp10/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp10/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp11/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp11/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp11/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp12/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp12/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp12/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp13/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp13/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp13/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp14/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp14/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp14/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* malloctest/Makefile.am: Remove AUTOMAKE_OPTIONS.
* putenvtest/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems++/Makefile.am: Remove AUTOMAKE_OPTIONS.
* termios/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itronhello/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itronmbf01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itronmbox01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itronsem01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontask01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontask02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontask03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontask04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontime01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* PR145.
* sp04/task1.c, sp04/tswitch.c: Test fails if other tasks present
in system (e.g. driver tasks). Also exit on minimum number of
switches not precise number.
* Fixed bug where resetting a timer that was not at the head
of one of the task timer chains resulted in the Timer Server
task waking up too far in the future.
* Added rtems_timer_get_information() directive to support testing.
* sp31/init.c, sp31/system.h, sp31/task1.c: Modified to test for
above condition.
* sp09/screen14.c, sp09/sp09.scn, sp30/init.c, sp31/init.c: Modified
because priority added as argument to rtems_timer_initiate_server().
* Added tests for task-based timers. This included the new tests
sp30 and sp31.
* Makefile.am, configure.ac: Modified to reflect new tests and files.
* sp09/screen14.c, sp09/sp09.scn: Modified to add error checks
for task-based timer services.
* sp30/.cvsignore, sp30/Makefile.am, sp30/init.c, sp30/resume.c,
sp30/sp30.doc, sp30/sp30.scn, sp30/system.h, sp30/task1.c,
sp31/.cvsignore, sp31/Makefile.am, sp31/delay.c, sp31/init.c,
sp31/prtime.c, sp31/sp31.doc, sp31/sp31.scn, sp31/system.h,
sp31/task1.c: New files.
* cdtest/main.cc: Remove RTEMS_TEST_IO_STREAM.
This fix is response to test results reported by Jerry Needell
<jerry.needell@unh.edu> for the SPARC/ERC32 and tracked as PR80.
* tm27/task1.c: Account for overhead in starting and stopping
the timer.
Reported by Ibragimov Ilya <ibr@oktet.ru> and tracked as PR63.
* psxstat/test.c: Fix test ENOTDIR to correspond to chdir() change.
Since we check permissions before evaluating enough to see if it
a regular file or directory, this hack is needed to make the regular
file executable.
Tracked as PR72 but related to the object id problem (PR36)
reported by Todor.Todorov@barco.com.
* include/tmacros.h: Added fatal_directive_check_status_only().
but discovered independently.
* mp03/delay.c: Dispatch disable level is actually 1 not 0.
* mp13/system.h: Configure enough tasks (CONFIGURE_MAXIMUM_TASKS=3).
* mp14/delay.c: Dispatch disable level may be arbitrarily > 0.
* sp26/system.h: Properly account for stack memory used by
this test. Reported by Jerry Needell <jerry.needell@unh.edu>
and processed as PR78.
* rtems++/Makefile.am: Make sure debug variant of librtems++
is linked against. Reported by Jerry Needell <jerry.needell@unh.edu>
* rtems++/Makefile.am: Pick up -lrtems++ even when debug.
* cdtest/system.h: Configure 1 semaphore. This probably covers
up not defining one for the GCC C++ Run-Time Libraries.
* paranoia/Makefile.am: Use LD_LIBS = -lm to make automake-1.5 happy.
* configure.ac: Apply RTEMS_CPU_SUBDIRS for potential CPU-subdirs.
* unlimited/init.c, unlimited/system.h, unlimited/test1.c,
unlimited/test2.c, unlimited/test3.c, unlimited/unlimited.doc:
Fixed typo.
* configure.in: Remove.
* libtests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* rtems++/Makefile.am: LD_FLAGS = -lrtems++.
* tmtests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* tmitrontests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* sptests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* minimum/Makefile.am: Fix comments to make automake-1.5 happy.
* sample.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* cdtest/Makefile.am: Remove LD_LIBS.
* psxtests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* mptests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* rtems++/Makefile: Remove LD_LIBS.
* itrontests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* tm27/Makefile.am: include leaf.am instead of leaf.cfg.
* tm26/Makefile.am: include leaf.am instead of leaf.cfg.
* tm24/Makefile.am: include leaf.am instead of leaf.cfg.
* tm16/Makefile.am: include leaf.am instead of leaf.cfg.
* tm18/Makefile.am: include leaf.am instead of leaf.cfg.
* tm02/Makefile.am: include leaf.am instead of leaf.cfg.
* tm10/Makefile.am: include leaf.am instead of leaf.cfg.
* tm11/Makefile.am: include leaf.am instead of leaf.cfg.
* tm15/Makefile.am: include leaf.am instead of leaf.cfg.
* tm19/Makefile.am: include leaf.am instead of leaf.cfg.
* tm04/Makefile.am: include leaf.am instead of leaf.cfg.
* tm17/Makefile.am: include leaf.am instead of leaf.cfg.
* tm28/Makefile.am: include leaf.am instead of leaf.cfg.
* tmck/Makefile.am: include leaf.am instead of leaf.cfg.
* tm08/Makefile.am: include leaf.am instead of leaf.cfg.
* tm12/Makefile.am: include leaf.am instead of leaf.cfg.
* tm03/Makefile.am: include leaf.am instead of leaf.cfg.
* tm13/Makefile.am: include leaf.am instead of leaf.cfg.
* tm29/Makefile.am: include leaf.am instead of leaf.cfg.
* tmoverhd/Makefile.am: include leaf.am instead of leaf.cfg.
* tm20/Makefile.am: include leaf.am instead of leaf.cfg.
* tm09/Makefile.am: include leaf.am instead of leaf.cfg.
* tm01/Makefile.am: include leaf.am instead of leaf.cfg.
* tm21/Makefile.am: include leaf.am instead of leaf.cfg.
* tm07/Makefile.am: include leaf.am instead of leaf.cfg.
* tm25/Makefile.am: include leaf.am instead of leaf.cfg.
* tm22/Makefile.am: include leaf.am instead of leaf.cfg.
* tm06/Makefile.am: include leaf.am instead of leaf.cfg.
* tm05/Makefile.am: include leaf.am instead of leaf.cfg.
* tm14/Makefile.am: include leaf.am instead of leaf.cfg.
* tm23/Makefile.am: include leaf.am instead of leaf.cfg.
* tmitronsem01/Makefile.am: include leaf.am instead of leaf.cfg.
* sp20/Makefile.am: include leaf.am instead of leaf.cfg.
* sp02/Makefile.am: include leaf.am instead of leaf.cfg.
* sp19/Makefile.am: include leaf.am instead of leaf.cfg.
* sp11/Makefile.am: include leaf.am instead of leaf.cfg.
* sp25/Makefile.am: include leaf.am instead of leaf.cfg.
* sp04/Makefile.am: include leaf.am instead of leaf.cfg.
* spsize/Makefile.am: include leaf.am instead of leaf.cfg.
* sp01/Makefile.am: include leaf.am instead of leaf.cfg.
* sp16/Makefile.am: include leaf.am instead of leaf.cfg.
* sp05/Makefile.am: include leaf.am instead of leaf.cfg.
* sp09/Makefile.am: include leaf.am instead of leaf.cfg.
* spfatal/Makefile.am: include leaf.am instead of leaf.cfg.
* sp06/Makefile.am: include leaf.am instead of leaf.cfg.
* sp23/Makefile.am: include leaf.am instead of leaf.cfg.
* sp28/Makefile.am: include leaf.am instead of leaf.cfg.
* sp03/Makefile.am: include leaf.am instead of leaf.cfg.
* sp29/Makefile.am: include leaf.am instead of leaf.cfg.
* sp13/Makefile.am: include leaf.am instead of leaf.cfg.
* sp27/Makefile.am: include leaf.am instead of leaf.cfg.
* sp14/Makefile.am: include leaf.am instead of leaf.cfg.
* sp07/Makefile.am: include leaf.am instead of leaf.cfg.
* sp15/Makefile.am: include leaf.am instead of leaf.cfg.
* sp17/Makefile.am: include leaf.am instead of leaf.cfg.
* sp22/Makefile.am: include leaf.am instead of leaf.cfg.
* sp12/Makefile.am: include leaf.am instead of leaf.cfg.
* sp26/Makefile.am: include leaf.am instead of leaf.cfg.
* sp21/Makefile.am: include leaf.am instead of leaf.cfg.
* sp24/Makefile.am: include leaf.am instead of leaf.cfg.
* sp08/Makefile.am: include leaf.am instead of leaf.cfg.
* unlimited/Makefile.am: include leaf.am instead of leaf.cfg.
* base_mp/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* base_mp/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* hello/Makefile.am: include leaf.am instead of leaf.cfg.
* base_sp/Makefile.am: include leaf.am instead of leaf.cfg.
* paranoia/Makefile.am: include leaf.am instead of leaf.cfg.
* cdtest/Makefile.am: include leaf.am instead of leaf.cfg, use
make-cxx-exe.
* ticker/Makefile.am: include leaf.am instead of leaf.cfg.
* minimum/Makefile.am: include leaf.am instead of leaf.cfg.
* psx01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx11/Makefile.am: include leaf.am instead of leaf.cfg.
* psxcancel/Makefile.am: include leaf.am instead of leaf.cfg.
* psx02/Makefile.am: include leaf.am instead of leaf.cfg.
* psx13/Makefile.am: include leaf.am instead of leaf.cfg.
* psxtime/Makefile.am: include leaf.am instead of leaf.cfg.
* psxchroot01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx07/Makefile.am: include leaf.am instead of leaf.cfg.
* psxmsgq01/Makefile.am: include leaf.am instead of leaf.cfg.
* psxtimer/Makefile.am: include leaf.am instead of leaf.cfg.
* psx10/Makefile.am: include leaf.am instead of leaf.cfg.
* psx08/Makefile.am: include leaf.am instead of leaf.cfg.
* psxhdrs/Makefile.am: include leaf.am instead of leaf.cfg.
* psxfile01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx05/Makefile.am: include leaf.am instead of leaf.cfg.
* psx09/Makefile.am: include leaf.am instead of leaf.cfg.
* psxmount/Makefile.am: include leaf.am instead of leaf.cfg.
* psxstat/Makefile.am: include leaf.am instead of leaf.cfg.
* psx12/Makefile.am: include leaf.am instead of leaf.cfg.
* psxreaddir/Makefile.am: include leaf.am instead of leaf.cfg.
* psxsem01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx03/Makefile.am: include leaf.am instead of leaf.cfg.
* psx04/Makefile.am: include leaf.am instead of leaf.cfg.
* psx06/Makefile.am: include leaf.am instead of leaf.cfg.
* mp02/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp02/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp04/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp04/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp14/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp14/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp06/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp06/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp08/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp08/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp03/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp03/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp10/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp10/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp05/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp05/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp13/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp13/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp01/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp01/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp07/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp07/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp11/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp11/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp12/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp12/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp09/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp09/node1/Makefile.am: include leaf.am instead of leaf.cfg.
