* malloctest/init.c: Tasks should be floating point.
* configure.ac: Remove RTEMS_OUTPUT_BUILD_SUBDIRS.
* psx01/psx01.scn, psx02/psx02.scn, psx03/psx03.scn, psx04/psx04.scn,
psx05/psx05.scn, psx06/psx06.scn, psx07/psx07.scn, psx08/psx08.scn,
psx09/psx09.scn, psx10/psx10.scn, psx11/psx11.scn, psx12/psx12.scn:
Per PR239 update the IDs in the various screens.
* sp02/sp02.scn, sp15/sp15.scn, sp16/sp16.scn, sp20/sp20.scn,
sp22/sp22.scn, sp23/sp23.scn, sp25/sp25.scn, sp31/sp31.scn: Per PR239
update the IDs in the screens.
* configure.ac: Unconditionally check for CXX (Hack to bug in
autoconf > 2.54).
* base_mp/apptask.c: Removed warning.
* base_mp/apptask.c: Add include of <unistd.h> to eliminate warning.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* sp32/.cvsignore: New file.
* PR271 was not applicable against the current source but included
a nice test that Joel decided to add to the tree as sp32.
* sp32/Makefile.am, sp32/init.c, sp32/sp32.scn: New file.
* Makefile.am, configure.ac: Modified to reflect addition.
* Makefile.am: Merge in former include/Makefile.am.
Take out unnecessary autoconf macros.
* base_mp/node1/Makefile.am: Use .$(OBJEXT) instead of .o.
* base_mp/node2/Makefile.am: Use .$(OBJEXT) instead of .o.
* base_sp/Makefile.am: Use .$(OBJEXT) instead of .o.
* cdtest/Makefile.am: Use .$(OBJEXT) instead of .o.
* hello/Makefile.am: Use .$(OBJEXT) instead of .o.
* minimum/Makefile.am: Use .$(OBJEXT) instead of .o.
* paranoia/Makefile.am: Use .$(OBJEXT) instead of .o.
* ticker/Makefile.am: Use .$(OBJEXT) instead of .o.
* unlimited/Makefile.am: Use .$(OBJEXT) instead of .o.
* itronhello/Makefile.am: Use .$(OBJEXT) instead of .o.
* itronmbf01/Makefile.am: Use .$(OBJEXT) instead of .o.
* itronmbox01/Makefile.am: Use .$(OBJEXT) instead of .o.
* itronsem01/Makefile.am: Use .$(OBJEXT) instead of .o.
* itrontask01/Makefile.am: Use .$(OBJEXT) instead of .o.
* itrontask02/Makefile.am: Use .$(OBJEXT) instead of .o.
* itrontask03/Makefile.am: Use .$(OBJEXT) instead of .o.
* itrontask04/Makefile.am: Use .$(OBJEXT) instead of .o.
* itrontime01/Makefile.am: Use .$(OBJEXT) instead of .o.
* tmitronsem01/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx01/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx02/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx03/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx04/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx05/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx06/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx07/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx08/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx09/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx10/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx11/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx12/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx13/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxcancel/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxchroot01/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxfile01/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxhdrs/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxmount/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxmsgq01/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxreaddir/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxsem01/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxstat/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxtime/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxtimer/Makefile.am: Use .$(OBJEXT) instead of .o.
* sp01/Makefile.am: Use $(OBJEXT) instead of .o.
* sp02/Makefile.am: Use $(OBJEXT) instead of .o.
* sp03/Makefile.am: Use $(OBJEXT) instead of .o.
* sp04/Makefile.am: Use $(OBJEXT) instead of .o.
* sp05/Makefile.am: Use $(OBJEXT) instead of .o.
* sp06/Makefile.am: Use $(OBJEXT) instead of .o.
* sp07/Makefile.am: Use $(OBJEXT) instead of .o.
* sp08/Makefile.am: Use $(OBJEXT) instead of .o.
* sp09/Makefile.am: Use $(OBJEXT) instead of .o.
* sp11/Makefile.am: Use $(OBJEXT) instead of .o.
* sp12/Makefile.am: Use $(OBJEXT) instead of .o.
* sp13/Makefile.am: Use $(OBJEXT) instead of .o.
* sp14/Makefile.am: Use $(OBJEXT) instead of .o.
* sp15/Makefile.am: Use $(OBJEXT) instead of .o.
* sp16/Makefile.am: Use $(OBJEXT) instead of .o.
* sp17/Makefile.am: Use $(OBJEXT) instead of .o.
* sp19/Makefile.am: Use $(OBJEXT) instead of .o.
* sp20/Makefile.am: Use $(OBJEXT) instead of .o.
* sp21/Makefile.am: Use $(OBJEXT) instead of .o.
* sp22/Makefile.am: Use $(OBJEXT) instead of .o.
* sp23/Makefile.am: Use $(OBJEXT) instead of .o.
* sp24/Makefile.am: Use $(OBJEXT) instead of .o.
* sp25/Makefile.am: Use $(OBJEXT) instead of .o.
* sp26/Makefile.am: Use $(OBJEXT) instead of .o.
* sp27/Makefile.am: Use $(OBJEXT) instead of .o.
* sp28/Makefile.am: Use $(OBJEXT) instead of .o.
* sp29/Makefile.am: Use $(OBJEXT) instead of .o.
* sp30/Makefile.am: Use $(OBJEXT) instead of .o.
* sp31/Makefile.am: Use $(OBJEXT) instead of .o.
* spfatal/Makefile.am: Use $(OBJEXT) instead of .o.
* spsize/Makefile.am: Use $(OBJEXT) instead of .o.
* cpuuse/Makefile.am: Use $(OBJEXT) instead of .o.
* malloctest/Makefile.am: Use $(OBJEXT) instead of .o.
* monitor/Makefile.am: Use $(OBJEXT) instead of .o.
* putenvtest/Makefile.am: Use $(OBJEXT) instead of .o.
* rtems++/Makefile.am: Use $(OBJEXT) instead of .o.
* rtmonuse/Makefile.am: Use $(OBJEXT) instead of .o.
* stackchk/Makefile.am: Use $(OBJEXT) instead of .o.
* termios/Makefile.am: Use $(OBJEXT) instead of .o.
* tm01/Makefile.am: Use $(OBJEXT) instead of .o.
* tm02/Makefile.am: Use $(OBJEXT) instead of .o.
* tm03/Makefile.am: Use $(OBJEXT) instead of .o.
* tm04/Makefile.am: Use $(OBJEXT) instead of .o.
* tm05/Makefile.am: Use $(OBJEXT) instead of .o.
* tm06/Makefile.am: Use $(OBJEXT) instead of .o.
* tm07/Makefile.am: Use $(OBJEXT) instead of .o.
* tm08/Makefile.am: Use $(OBJEXT) instead of .o.
* tm09/Makefile.am: Use $(OBJEXT) instead of .o.
* tm10/Makefile.am: Use $(OBJEXT) instead of .o.
* tm11/Makefile.am: Use $(OBJEXT) instead of .o.
* tm12/Makefile.am: Use $(OBJEXT) instead of .o.
* tm13/Makefile.am: Use $(OBJEXT) instead of .o.
* tm14/Makefile.am: Use $(OBJEXT) instead of .o.
* tm15/Makefile.am: Use $(OBJEXT) instead of .o.
* tm16/Makefile.am: Use $(OBJEXT) instead of .o.
* tm17/Makefile.am: Use $(OBJEXT) instead of .o.
* tm18/Makefile.am: Use $(OBJEXT) instead of .o.
* tm19/Makefile.am: Use $(OBJEXT) instead of .o.
* tm20/Makefile.am: Use $(OBJEXT) instead of .o.
* tm21/Makefile.am: Use $(OBJEXT) instead of .o.
* tm22/Makefile.am: Use $(OBJEXT) instead of .o.
* tm23/Makefile.am: Use $(OBJEXT) instead of .o.
* tm24/Makefile.am: Use $(OBJEXT) instead of .o.
* tm25/Makefile.am: Use $(OBJEXT) instead of .o.
* tm26/Makefile.am: Use $(OBJEXT) instead of .o.
* tm27/Makefile.am: Use $(OBJEXT) instead of .o.
* tm28/Makefile.am: Use $(OBJEXT) instead of .o.
* tm29/Makefile.am: Use $(OBJEXT) instead of .o.
* tmck/Makefile.am: Use $(OBJEXT) instead of .o.
* tmoverhd/Makefile.am: Use $(OBJEXT) instead of .o.
* mp01/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp01/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp02/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp02/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp03/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp03/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp04/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp04/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp05/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp05/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp06/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp06/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp07/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp07/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp08/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp08/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp09/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp09/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp10/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp10/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp11/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp11/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp12/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp12/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp13/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp13/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp14/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp14/node2/Makefile.am: Use $(OBJEXT) instead of .o.
enable this support.
* cdtest/init.c: Modified.
* cpuuse/task2.c, malloctest/task1.c, putenvtest/init.c,
rtmonuse/task1.c, termios/init.c: Modified.
* tmitronsem01/init.c: Modified.
* itronhello/init.c, itronmbf01/init.c, itronmbox01/init.c,
itronsem01/init.c, itrontask01/task1.c, itrontask02/init.c,
itrontask03/task1.c, itrontask04/task3.c, itrontime01/init.c: Modified.
* include/pmacros.h, psx01/task.c, psx02/init.c, psx02/task.c,
psx03/init.c, psx04/init.c, psx05/init.c, psx06/init.c, psx07/init.c,
psx08/task3.c, psx09/init.c, psx10/init.c, psx11/init.c,
psx12/init.c, psx13/Makefile.am, psx13/main.c, psx13/test.c,
psxcancel/init.c, psxchroot01/Makefile.am, psxchroot01/main.c,
psxchroot01/test.c, psxfile01/Makefile.am, psxfile01/main.c,
psxfile01/test.c, psxfile01/test_cat.c, psxfile01/test_extend.c,
psxfile01/test_write.c, psxmount/Makefile.am, psxmount/main.c,
psxmount/test.c, psxmsgq01/init.c, psxreaddir/Makefile.am,
psxreaddir/main.c, psxreaddir/test.c, psxsem01/init.c,
psxstat/Makefile.am, psxstat/main.c, psxstat/test.c, psxtime/main.c,
psxtime/test.c, psxtimer/psxtimer.c: Modified.
* mp01/task1.c, mp02/task1.c, mp03/task1.c, mp04/task1.c, mp05/task1.c,
mp06/task1.c, mp07/task1.c, mp08/task1.c, mp09/task1.c, mp10/init.c,
mp11/init.c, mp12/init.c, mp13/init.c, mp13/task2.c: Modified.
* include/timesys.h, tm01/task1.c, tm02/task1.c, tm03/task1.c,
tm04/task1.c, tm05/task1.c, tm06/task1.c, tm07/task1.c, tm08/task1.c,
tm09/task1.c, tm10/task1.c, tm11/task1.c, tm12/task1.c, tm13/task1.c,
tm14/task1.c, tm15/task1.c, tm16/task1.c, tm17/task1.c, tm18/task1.c,
tm19/task1.c, tm20/task1.c, tm21/task1.c, tm22/task1.c, tm23/task1.c,
tm24/task1.c, tm25/task1.c, tm26/task1.c, tm27/task1.c, tm28/task1.c,
tm29/task1.c, tmck/task1.c, tmoverhd/testtask.c: Modified.
* sp01/task1.c, sp02/task1.c, sp03/task2.c, sp04/task1.c, sp05/task1.c,
sp06/task1.c, sp07/taskexit.c, sp08/task1.c, sp09/task1.c,
sp11/task1.c, sp12/pritask.c, sp12/task5.c, sp13/task1.c,
sp14/task2.c, sp15/task1.c, sp16/task1.c, sp17/task1.c,
sp19/fptask.c, sp20/task1.c, sp21/task1.c, sp22/task1.c,
sp23/task1.c, sp24/task1.c, sp25/task1.c, sp26/init.c, sp26/task1.c,
sp30/task1.c, sp31/task1.c, spsize/init.c, spsize/size.c: Modified.
* include/buffer_test_io.h: New file.
* spsize/size.c: Don't reference the RTEMS allocated interrupt
stack if the port doesn't configure using it.
* psxcancel/Makefile.am, psxcancel/init.c, psxcancel/psxcancel.scn:
Updated as part of PR164 which reported problems with the RTEMS
implementation of pthread_cancel.
* Jump table for single entry point removed.
* spsize/size.c: Modified to reflect above.
* unlimited/test1.c: Corrected use of _Objects_Information_table
now that it is a two dimensional array based upon API and class.
* sp29/init.c: Corrected definitions for task stack usage.
* spsize/size.c: _Thread_queue_Extract_table removed.
* sp21/task1.c (INVALID_DRIVER_MAJOR): Change definition to reflect
number of staticly configured device drivers.
* sp21/task1.c: Correct INVALID_DRIVER_MAJOR so it is precisely 1 more
than the configured number of drivers.
* psxmsgq01/init.c: Reflect changes made to address PR81 that
reworked POSIX message queues to add a descriptor separate from
the underlying message queue. This allows non-blocking to follow
the "open" not the underlying queue.
* base_sp/apptask.c: Include <stdlib.h>.
* hello/init.c: Ditto.
* paranoia/init.c: Ditto.
* ticker/tasks.c: Ditto.
* unlimited/init.c: Ditto.
* unlimited/test1.c: Ditto.
* unlimited/test2.c: Ditto.
* unlimited/test3.c: Ditto.
* spsize/size.c: Reflect SPARC modifcation to get rid of
NO_TABLE_MOVE and references to _CPU_Trap_Table_area.
* Per PR147 addressed problems when reseting and inserting a timer
into a timer chain that did not honor time passage since the last
time the timer server was scheduled and the new insertion.
* sp31/sp31.scn, sp31/task1.c: Added test code to detect this case.
* Side-effect of PR132.
* sp21/system.h: Now must explicitly request NULL driver.
* tm01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm05/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm06/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm07/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm08/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm09/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm10/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm11/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm12/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm13/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm14/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm15/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm16/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm17/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm18/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm19/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm20/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm21/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm22/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm23/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm24/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm25/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm26/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm27/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm28/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm29/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tmck/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tmoverhd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tmitronsem01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp05/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp06/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp07/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp08/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp09/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp11/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp12/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp13/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp14/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp15/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp16/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp17/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp19/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp20/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp21/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp22/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp23/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp24/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp25/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp26/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp27/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp28/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp29/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp30/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp31/Makefile.am: Remove AUTOMAKE_OPTIONS.
* spfatal/Makefile.am: Remove AUTOMAKE_OPTIONS.
* spsize/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_mp/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_mp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_mp/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_sp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* cdtest/Makefile.am: Remove AUTOMAKE_OPTIONS.
* hello/Makefile.am: Remove AUTOMAKE_OPTIONS.
* minimum/Makefile.am: Remove AUTOMAKE_OPTIONS.
* paranoia/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ticker/Makefile.am: Remove AUTOMAKE_OPTIONS.
* unlimited/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx05/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx06/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx07/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx08/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx09/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx10/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx11/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx12/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx13/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxcancel/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxchroot01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxfile01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxhdrs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxmount/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxmsgq01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxreaddir/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxsem01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxstat/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxtime/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxtimer/Makefile.am: Remove AUTOMAKE_OPTIONS.
